1969 K10 Rear Suspension Mount Location
The front mounts for my 1969 K10 SWB rear leaf springs have obviously been previously modified (this truck is a hillbilly engineered mutt), but I'm trying to figure out if there was a reason why... or if not what the proper placement is... before replacing my sagging leaf springs.
Anyone have insight, pics of stock locations, or even better yet--dimensions? The only insight I've found in the service manual is the image attached. |
![]() Join Date: Jul 2015
Re: 1969 K10 Rear Suspension Mount Location
Maybe the frame was cracking so they welded it? I have a 72 frame and the location looks to be the same.
![]() ![]() Join Date: Oct 2015
Pictures from a 71 K1500...
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
The OP's hangers look more like 2x4 setup than the 4x4. What's the spring width OP?
Tags |
1969 k10, frame mount, leaf spring, shackle, suspension mount |
