Old 10-20-2018, 08:58 AM   #1
Auroch
Auroch's Avatar
1970 c10 distributor upgrade recommendations
Hello good people, so I’m swapping engines currently and I figured I should also change my distributor, I’d like to upgrade to an HEI. Any tips I should be aware of? Brands? Thanks in advance.
Engine: 350 5.7L v8
Auroch is offline   Reply With Quote
Old 10-20-2018, 09:00 AM   #2
Shinysideup
Shinysideup's Avatar
Re: 1970 c10 distributor upgrade recommendations
There are many out there but my advise is buy name brand not the cheap knock-off versions for longevity. Whats your engine setup/intentions?
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 10-20-2018, 09:06 AM   #3
Auroch
Auroch's Avatar
Yeah I definitely want to get something decent. So the new engine is a 350 class 1 crate rated at 305hp, edelbrock 1406 carb over 2701 intake manifold.
Old 10-20-2018, 09:12 AM   #4
geezer#99
geezer#99's Avatar
Is the intended 350 a one or two piece rear main seal?
Old 10-20-2018, 09:23 AM   #5
crabman
crabman's Avatar
Look at Skip White Performance in TN. They have billet HEI for a very good price. I bought one for my 69 C10 396 and was amazed at the quality and price. Works like a champ too. 65K volt coil and brass terminals in cap and rotor, all while being machined billet.
1969 CST/10 396
crabman is offline   Reply With Quote
Old 10-20-2018, 10:50 AM   #6
Auroch
Auroch's Avatar
Man, you got me there. What’s the difference?
Old 10-20-2018, 10:51 AM   #7
68 P.O.S.
No, don't even bother with Skip White. You get what you pay for with that cheap crap. You definitely want a HEI and one with an adjustable vacuum advance. What's your budget for it?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-20-2018, 10:52 AM   #8
Auroch
Auroch's Avatar
Man $50!? That may be tough to beat.
Old 10-20-2018, 10:56 AM   #9
Auroch
Auroch's Avatar
Yeah, $50 is suspiciously cheap in comparison to what I’ve seen. I’d like to stay under $150, but I’m open to suggestions.
Old 10-20-2018, 11:09 AM   #10
Auroch
Auroch's Avatar
Any thoughts on this one? Seems like a good value.
https://www.summitracing.com/parts/sum-850001-1
Old 10-20-2018, 11:21 AM   #11
Boog
laying low
Boog's Avatar
Check your local parts store or Summit or Jegs for whats available. You should be able to buy a GM hei for $125 or so and be able to buy parts most anywhere when needed. Hard to beat.
I bought one of those skip whites for $50 a few years ago for a fresh 350. Its pretty alright. The engine ran in the shop only as the truck is not road ready yet and the module went bad with only some hours run time on it. I pulled the
module from the old OE hei and put in the SW. It still hasn’t made it to the road but it still starts every time.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-20-2018, 11:24 AM   #12
hjewell2
hjewell2's Avatar
Not going to preach, but ya get what ya pay for.. stay away from MSD crap.
hjewell2 is offline   Reply With Quote
Old 10-20-2018, 11:32 AM   #13
Shinysideup
Thats no name junk.
Im using this style https://www.summitracing.com/parts/d...make/chevrolet
Check your appication.
._____________
Old 10-20-2018, 11:39 AM   #14
68 P.O.S.
I haven't used the Summit one you linked, but have heard decent things. I've had good luck with the Accel 59107 and it's in your price range. It has the correct weights & centerplate you need and it has an adjustable vac advance. You can never go wrong with MSD as they're the leader in ignition systems, but they're pricey.
Old 10-20-2018, 11:44 AM   #15
68 P.O.S.
When you convert over to HEI make sure you replace the resisted power wire. You need a full 12 volts to it. It's an easy conversion and there's several threads on it.
Old 10-20-2018, 11:45 AM   #16
Auroch
Auroch's Avatar
Thats no name junk.
A little pricey, any significant advantages?
Old 10-20-2018, 11:45 AM   #17
Auroch
Auroch's Avatar
Good to know, thanks man.
Old 10-20-2018, 11:52 AM   #18
68 P.O.S.
Not if your using it for daily driving. It's overkill
Old 10-20-2018, 12:06 PM   #19
hjewell2
hjewell2's Avatar
Thats no name junk.
those are the best but thinking he is not using for performance.
Old 10-20-2018, 12:08 PM   #20
geezer#99
geezer#99's Avatar
The drive gear on the distributor.
Usually the one piece has a roller cam which needs a melonized gear.
Old 10-20-2018, 12:14 PM   #21
Auroch
Auroch's Avatar
Right, I’m going more for reliability.
Old 10-20-2018, 12:27 PM   #22
Auroch
Auroch's Avatar
Im thinking this might be it.
https://www.summitracing.com/parts/msd-8362
Old 10-20-2018, 01:00 PM   #23
Auroch
Auroch's Avatar
Old 10-20-2018, 01:02 PM   #24
Auroch
Auroch's Avatar
Old 10-20-2018, 01:14 PM   #25
geezer#99
geezer#99's Avatar
If you had every one of those distributors torn down to reveal specs and part numbers you’d likely find they were all the same.
I read a test years ago between the Msd and skip white and they were exactly the same except the Msd was 300 at the time and the skip white was 40 bucks.
You want the best and don’t sweat the price then get one here.
http://performancedistributors.com/
Do you have a spec sheet on your 350?
