Old 09-30-2018, 09:21 AM   #851
68 TT
Still plays with trucks
68 TT's Avatar
Re: SPID Picture thread?
Originally Posted by Patch View Post
Here is the SPID from the parts donor that I just picked up the disc brake frontend off of.....WOW!!!!
Mine is loaded compared to yours. I have one option since the heater doesn't count on the 67's
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-04-2018, 02:49 PM   #852
Travisarmenta
Travisarmenta's Avatar
Crazy color combo
Travisarmenta is offline   Reply With Quote
Old 10-06-2018, 01:21 PM   #853
69_hafton
Sleep-Deprived
69_hafton's Avatar
Been through this entire thread refining the contents of this 71 Cheyenne's SPID but am having trouble with some of the suffixes. I think I'm doing pretty good with what I am working with; the tire suffixes are very hard to read and the ammeter-oil-temp I'm not sure on the suffix either. Would the suffix indicate a tach cluster or is the tach alway listed separately? Any help or expert knowledge here would be greatly appreciated before I have this reproduced.
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
69_hafton is offline   Reply With Quote
Old 11-19-2018, 11:09 PM   #854
Cali72K20
Cali72K20's Avatar
I purchased this in a CL lot buy, the seller said this was the best piece. My question is, was there a LS9 350 offered in a K20 with a 4 speed? Was there ever a LS9 small block 350 option then? Thanks in advance!
Casey
Cali72K20 is offline   Reply With Quote
Old 11-19-2018, 11:14 PM   #855
davischevy
davischevy's Avatar
Yes sir, LS9 was the option code for a 350 4 bbl engine in a 1972 truck.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-19-2018, 11:15 PM   #856
Cali72K20
Cali72K20's Avatar
Didn't look at the one above first, it has it but with more letters, all the research I have seen with an LS9 are the 1998 and newer engines.
Old 11-19-2018, 11:15 PM   #857
Cali72K20
Cali72K20's Avatar
Thank you Larry!
Old 11-19-2018, 11:28 PM   #858
davischevy
davischevy's Avatar
Here's mine.
other Larry
Old 12-05-2018, 08:06 PM   #859
2014sierraAT
2014sierraAT's Avatar
Navy truck spid..I have a buddy that has lots of 67-72 trucks. Was out looking today and just happened to pop the glove box this is one of the more interesting spids I’ve seen.
2014sierraAT is offline   Reply With Quote
Old 12-05-2018, 08:34 PM   #860
ghalperin
ghalperin's Avatar
Still the winner for the least amount of options. Negative 1.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline   Reply With Quote
Old 12-06-2018, 02:41 PM   #861
Keith Seymore
Keith Seymore's Avatar
That's because the RPOs get reused. You have to find the codes from the same timeframe as the model year of interest.
For example: The LS6 that I know and love was a 1970 450HP 454 big block.
I was on a powertrain road trip where the pickups were equipped with GenIII LS6 small block engines.
They almost kicked me off the trip when I referred to them as a "weenie small block".
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-06-2018, 02:42 PM   #862
Keith Seymore
That....is going to be tough to beat.
K
1979-1986
1986 - 2019
Old 12-06-2018, 08:40 PM   #863
pryorstemmed
4wd Enthusiast
pryorstemmed's Avatar
I thought I added this before, but it didn't upload. Here is my 72's.
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt
*1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps
*1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed
*1970 Olds 442 W-30 M-21 4-speed
*1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1
*1986 K30 Silverado Crew Cab 502/TH400
*2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles
*2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver
pryorstemmed is offline   Reply With Quote
Old 12-06-2018, 08:50 PM   #864
CG
BlahBlahBlah
My 71 Cheyenne Super C30
Old 12-07-2018, 07:36 AM   #865
72c10porter
72 c10
67 c20
72c10porter is offline   Reply With Quote
Old 01-06-2019, 07:56 PM   #866
jcwren
Originally Posted by SS Tim View Post
Here is a typical cutaway and service procedure for the oil bath cleaner. The factory chassis service manual is a great thing to have and learn from. Buy one or at least download a pdf until you find a paper copy.
Tim, do you have the rest of the images or a PDF of the brochure the right hand picture came from?
jcwren is offline   Reply With Quote
Old 01-07-2019, 02:36 AM   #867
MACO
MACO's Avatar
69 c20
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green.
MACO is offline   Reply With Quote
Old 01-07-2019, 08:14 AM   #868
He's an interesting one, C/20 cab & chassis with dual rear wheel option and no leaf spring option.
Old 01-07-2019, 08:56 AM   #869
Eric Johnson
Eric Johnson's Avatar
Here is mine with a pick of the 67
1967 GMC 3/4 ton custom. 283 4 speed unrestored
Eric Johnson is offline   Reply With Quote
Old 01-07-2019, 09:41 AM   #870
That truck is just too much! I wonder about that D32 Option with LH in the description. I know D32 is the "RH" mirror option and the LH mirror is standard. I've seen where members have had shorter mirrors than others is what makes me curious. We always figured someone shortened them.
Old 01-07-2019, 09:47 AM   #871
Eric Johnson
Me too! I am thinking someone put the smaller mirrors on. It had a slide in camper on it so I am thinking the mirrors were probably bigger you would think. What about my SPID. Shows Ivory on "Paint" on top instead of a code. Does the SPID look real? I have a lot of documentatiuon so I am thinking it is but?! .....
Old 01-07-2019, 10:03 AM   #872
too much stuff
Roadtrip!
too much stuff's Avatar
My opinion is your spid is a reproduction from your build sheet. A lot of 67s didn't have a spid sheet. Not saying yours did or didn't. An original would have been "paper" with out the clear over the top. Nice truck regardless!
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-07-2019, 10:49 AM   #873
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1546872279
Here’s the label off my 67 parts truck. Nice truck in its day purchased new from Jack Carter Chevrolet Calgary.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 01-07-2019, 10:55 AM   #874
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by MACO View Post
69 c20
Seems strange to specify "single speed rear axle", since that's the standard. What is special about that axle, any idea?
~Steven
Simi Valley, CA
Old 01-07-2019, 02:09 PM   #875
Me too! I am thinking someone put the smaller mirrors on. It had a slide in camper on it so I am thinking the mirrors were probably bigger you would think .....
As far as the mirrors go, The bigger mirrors would have been RV JRs, which were small west coast style mirrors that came in pairs. RPO D29
The type on your truck are what were standard, but in '67 only the driver side was standard. Your truck has the optional passenger side. The original ones were painted and there are chrome and stainless replacements. I'm wondering if the factory offered two lengths in this style mirror or did they just call these "short mirrors"?
There are RPO DG6 and DG7 which are short passenger and driver side mirrors. There is RPO DG8 which I think is the same mirror both sides. THEN.... there is RPO DG9! Want to guess what that is? LONG passenger side mirror. I wonder what's what. I was thinking these could be larger truck codes, but then there are the DH series of mirror codes. There is DH1 which has the same description of DG9. DH2 is long driver side and DH3 is long mirror both sides.
Different codes for same descriptions, long/short, I dunno. Codes cover all trucks. I guess this is a topic for a new thread.
