Old 11-14-2018, 08:28 PM   #101
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC Project
Got my piece made up for the firewall. Accidentally cut too much off of it in one spot by about a quarter inch. But before I scrapped it and started over I thought I would try to weld a little quarter by half inch piece in there. I can't believe it actually worked.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 11-15-2018, 08:09 PM   #102
Kronald_70GMC
Piece is in! On to kick panel
Kyle
IG: kyle_ronald
Old 11-16-2018, 08:54 PM   #103
Kronald_70GMC
Made it to the local autobody supply today after work to get some rust conversion paint and ended up spending $80 by the time I walked through there... Should have known that would happen Got the kick panel patch cut down and this side actually fit without having to splice in a 1/4" strip so that was pretty sweet. Now I can prep and spray the rust conversion paint in the lower pillar and clean up the patch panel. Then drill a few holes, shoot with weld through primer and I can weld in that piece. Then it's time to fit the sloppy shaped floor pan. This side is coming together much quicker than the driver side.
Kyle
IG: kyle_ronald
Old 11-17-2018, 01:30 AM   #104
Getter-Done
Getter-Done's Avatar
Nice work.
I will be repairing my cab soon.
I am in for the build.
84 Chevy K-20
Old 11-17-2018, 01:46 AM   #105
Kronald_70GMC
Originally Posted by Getter-Done View Post
Nice work.
Thanks for tagging along and for the compliments. Do you have a build tread? I'd like to check it out. Crew cab sounds crazy cool.
Kyle
IG: kyle_ronald
Old 11-17-2018, 11:00 PM   #106
Kronald_70GMC
I pulled my engine out of the corner in my garage today so I could put it on an engine dolly instead of the stand it was on. Now I can tuck it in closer to the wall. I also got the kick panel all cleaned up and welded in today. Today was a good day
Kyle
IG: kyle_ronald
Old 11-19-2018, 12:20 AM   #107
ryans69chevy
Kick panel looks good! What's next?
ryans69chevy is offline   Reply With Quote
Old 11-19-2018, 12:34 AM   #108
Kronald_70GMC
Next I have to re create the brake at the front of the goofy aftermarket floor pan along with plenty of other mods that I'm sure I will be needing to do to it to make it fit. Then after that's done, I can do the side skirt and rear floor pan. And after that it's just a matter of cab supports and the floor will be complete!
Kyle
IG: kyle_ronald
Old 11-20-2018, 10:42 PM   #109
Kronald_70GMC
I started trying to fit the passenger side floor pan tonight. It is quite a bit of smashing it around with a bfh to make it fit I've got it pretty close now but there is still alot of finessing to go. Hopefully tomorrow evening I can get the brake re created the the front. Here's a few crappy pics.
Kyle
IG: kyle_ronald
Old 11-20-2018, 10:46 PM   #110
Originalthor
Ouch that's not a very good fit at all man. The toe kick piece looks great. That motor looks pretty but is going to be fast enough to beat my flintstone truck. Lol
Originalthor is offline   Reply With Quote
Old 11-20-2018, 11:15 PM   #111
Kronald_70GMC
Defiantly not a good fit at all but I'm not worried about it. I've got a few tricks up my sleeve if need be. I would for sure recommend buying the whole floor pan if anyone is needing similar repairs. Unless you have a ton of time on your hands And as for the motor, we'll have to see how fast it's gonna be once I pull it apart because I have no idea what it's got in it for a cam or what heads and pistons it's got.
Kyle
IG: kyle_ronald
Old 11-27-2018, 10:07 PM   #112
Kronald_70GMC
Well the more time I put into fitting this floor pan, the more I start to think I was quite lucky to have the driver side fit as well as it did. This floor pan has been quite interesting so far. I've had to make two "releif cuts" into this pan now. One wasn't so bad, only about 4 inches long and opening about 3/16 of an inch. The other one though... Well now that's a very different story. It is closer to 20 inches long and opens up at least an inch and 1/4. Whoo wee am I ever gonna need lots of beer to help me through this one. Here come so pretty hoffifying pics...
Kyle
IG: kyle_ronald
Old 11-29-2018, 12:23 PM   #113
Kronald_70GMC
A little more progress to report. I've had to rework the entire length of the recess that the rocker panel sits into at the outboard edge of the floor pan. The recess was not deep enough so I pounded on that for a good 30 minutes last night. I also could not leave the dimple in the center of the pan the way it was. It was about 3/8s out of level so I made a few small incisions and made it look right. Lots of wedges to cut and weld into place now. It is finally starting to look like the factory pan, well minus all that beautiful rust.
Kyle
IG: kyle_ronald
Old 12-09-2018, 05:52 PM   #114
Kronald_70GMC
It's starting to look like a floor pan now. I got my big splice mostly filled in and ground down. I also got my welding flange bent, just some minor tweaking on the flange and that will be ready. Now it's just a matter of trimming to fit the remaining two sides and I'll be ready to weld it home. Hoping to have this pan all welded in by Christmas then I hope the other 2 sections fit alot nicer than this train wreck!
Kyle
IG: kyle_ronald
Old 12-09-2018, 08:57 PM   #115
Getter-Done
Looking Good.
That is going to be Solid.
So many trucks I have seen repaired
with sheetmetal screws and scab patches.
You are spending the time to make it right.
84 Chevy K-20
Old 12-09-2018, 09:13 PM   #116
Kronald_70GMC
Looking Good.
Thanks for the compliment. I too have seen my fair share of scabby patches. I'm far to much of a perfectionist for that.
Kyle
IG: kyle_ronald
Old 12-17-2018, 08:41 PM   #117
Kronald_70GMC
Looks like I'm on track to have this pan finished by Christmas. Today I finished tack welding the pan into its place. Now I have one more goofey looking patch to make and I can finish the welding on this side! I also had to figure out a way to fix my own stupidity when I went to tack the edge parralel to the transmission tunnel. I must have had a few too many beers before I made that cut. So I figured, easiest way was to put a peice of 3/16 steel rod in there and weld away. That should do the trick.
Kyle
IG: kyle_ronald
Old 12-17-2018, 09:55 PM   #118
Originalthor
Looking good man. You know what they say measure twice cut once. Or just crack another and fix away. Lol
Old 12-17-2018, 10:09 PM   #119
Kronald_70GMC
I think a better philosophy is measure once, cut about 5 or 6 times starting about 1/4" inch big of the measurement. but when mistakes are made, the second option you listed is the only way!
Kyle
IG: kyle_ronald
Old 01-25-2019, 04:33 PM   #120
Kronald_70GMC
OK so as you may have guessed by now, I did not get the pan in before Christmas as planned. I ended up coming down with a wicked flu the day after my last post. Then with the holidays being busy as per usual, it was suddenly next year and I hadn't got back on it. So I jumped back into the shop early this month but unfortunately it was to build a couple of shelves we have been needing for quite some time, but at least that's one item off the honey do list. So early this week I had those shelves all polished up and done so I grabbed the old air chuck to give the work bench a well needed dusting. Then as I was attempting to coil up my air hose to hang it back on the wall (what a major Pita), just gets hooked up and caught on any little corner and edge it can find) I had a sudden realization. It was time to fork out the cash for a hose reel, and wouldn't you know it, Princess Auto had a sale starting the following day and Hey! that hose reel I had my eye on finally went on sale! So when I got it home I had another realization. That aux air tank of mine hanging up on the wall sure does lack the "wow factor" I would like it to have. So one thing led to another and next thing I know I had it all cut smooth and painted up real pretty like. So now today after almost a month I'm back welding in my floor pan! Anywho enough talk right? Here come the pictures.
Kyle
IG: kyle_ronald
Old 01-28-2019, 12:14 PM   #121
chewychevy67
Looking good. I like that tank. Looks nice!
chewychevy67 is online now   Reply With Quote
Old 01-28-2019, 12:56 PM   #122
Kronald_70GMC
Thanks! I thought it turned out good for a quick little project.
Kyle
IG: kyle_ronald
Old 01-28-2019, 03:43 PM   #123
chewychevy67
What paint did you use? Was that left over from one of the trucks?
Old 01-28-2019, 04:09 PM   #124
Kronald_70GMC
It's actually VHT engine paint. I'm going to use it on the 396.
Kyle
IG: kyle_ronald
Old 01-28-2019, 06:09 PM   #125
chewychevy67
That's a sweet looking colour
