Old 01-02-2019, 08:27 PM   #1
bigmoe
bigmoe's Avatar
'08 4L60e wiring - nss, reverse & gear?
It'll be a few months before I get to the wiring stage but does someone have a diagram of the pinouts for the neutral safety switch, etc.? for a 2008.
I'm also wondering if there is any way to wire home made gear indicator lights? I'm planning on using a floor shifter so the indicator would be cool.
bigmoe is offline   Reply With Quote
Old 01-03-2019, 10:19 PM   #2
bigmoe
bigmoe's Avatar
Re: '08 4L60e wiring - nss, reverse & gear?
Found this. Just need to figure how to wire.
Old 01-04-2019, 11:14 AM   #3
dayj1
I've done what you're asking on a 4.8/4l60E swap into a Jeep YJ. Unfortunately, I didn't keep a schematic of what I built. Basically, the trans mounted PRNDL switch grounds one or more of four outputs that are referenced as A, B, C, and P in the GM wiring diagrams. Use a voltage meter to make a chart of which wire(s) are grounded in each gear. You'll find that 3 of 4 lines are all you'll need to represent the 7 gear positions (P,R,N,D,3,2,1). Then you just need to use a network of diodes (or a single IC) to build a circuit to control LEDs (or one of the Lokar LED gear indicators). Google 3 to 8 decoder to see some examples of the circuit you'll need.
This thread shows something similar (posts #35 and #39):
https://www.67-72chevytrucks.com/vbo...=725451&page=2
It's not a particularly easy thing to do if you're not handy with a soldering iron and building your own circuits. I think Dakota Digital (and probably others) sell decoders for this sort of thing but they're definitely not as cheap as using the stock switch.
dayj1 is offline   Reply With Quote
Old 01-04-2019, 11:20 AM   #4
bigmoe
bigmoe's Avatar
Thanks Dayj1! Just what I needed to know.
