Old 01-03-2019, 11:56 PM   #2551
svr
svr's Avatar
Re: What did you do with your truck today, Part 3
Took a little more than 5 min but progress
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 01-04-2019, 02:00 AM   #2552
MARTINSR
MARTINSR's Avatar
Right on!
Me, did my five minutes, did a little work on my heater, ground down a little spot on it and dug out the wire so tomorrow night I can rewire the motor.
Then I am totally jazzed about this, on my evening walk I went to the local hardware store and found the PERFECT wire to put on the front of the heater! The cool part is I measured it then came home and it was perfect, right on. It's smaller version of the screen I will be putting over the head lamps from a 53 Corvette.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 01-04-2019, 11:20 AM   #2553
mikebte
Very nice, That can be time consuming but well worth it in the end. That stuff is as satisfying as popping bubble wrap once its applied.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 01-04-2019, 11:22 AM   #2554
mikebte
Originally Posted by MiraclePieCo View Post
I continued disassembly of the top of my motor. Last time I did this my back was hurting for a week from working bent over the fender so much. This time I'm limiting myself to an hour or two a day to avoid a repeat. Today I got the alternator and fan off and pulled the distributor. Tomorrow I'll have to go underneath to remove my freshly installed exhaust :-(
Didn't you literally just remove the head to remove a broken pipe plug? At least it seem like it was just yesterday?
My YouTube:
Old 01-04-2019, 04:11 PM   #2555
Janky59
Janky59's Avatar
I finished up the installation of a set of Williams split manifolds, cleaned up and painted things while they were apart, on to the exhaust shop tomorrow.
2018 BMW R1200RT
2013 Aprilia Tuono
2012 Ford Flex
2011 Ducati Hypermotard
1959 Chevy 3100
Janky59 is offline   Reply With Quote
Old 01-05-2019, 05:27 PM   #2556
Black_Sheep
Black_Sheep's Avatar
Mid 40’s in early January is almost unheard of in Minnesota. I pulled the cover off the ‘58 and fired it up to run it up to temp. There is too much salt on the roads to drive it, so this will have to do for now...
https://www.facebook.com/mark.wells....6005650103573/
Black_Sheep is offline   Reply With Quote
Old 01-05-2019, 05:33 PM   #2557
Black_Sheep
Well worth the effort though, looks real good...
Old 01-05-2019, 06:15 PM   #2558
DBS5Window
DBS5Window's Avatar
I finished installing a TCI rear leaf spring kit and a reman Explorer 8.8 rear. Next up brake lines and relocating the fuel tank. I have a Mustang fuel tank from Tanks Inc.
DBS5Window is offline   Reply With Quote
Old 01-05-2019, 06:49 PM   #2559
Trucknut57
Trucknut57's Avatar
I took it out of the garage and let it soak up some sunshine .
It really needs a bath
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline   Reply With Quote
Old 01-05-2019, 09:33 PM   #2560
MiraclePieCo
MiraclePieCo's Avatar
Got my exhaust removed today to facilitate head removal. I'm plugging away at this only an hour or two a day to save stress on my back. Plus I'm not real enthused about taking the truck apart; building them is rewarding, UN-building them not so much.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 01-05-2019, 10:21 PM   #2561
MARTINSR
MARTINSR's Avatar
Yeah, it sucks, but in a little while you will be back on the road! WHOOO HOOOOO!
Brian
1948 Chevy pickup
Old 01-06-2019, 12:55 AM   #2562
evilokc
took a short drive in the beautiful sunny 60 degree weather today. life is sometimes remarkable. 2 days ago it was snow and ice.
evilokc is offline   Reply With Quote
Old 01-07-2019, 01:30 PM   #2563
BAM55
BAM55's Avatar
Well I was able to get get her down on all 4's for the first time since I painted the cab and front clip.
BAM55 is offline   Reply With Quote
Old 01-07-2019, 10:25 PM   #2564
MiraclePieCo
I love those little victories, they're so rewarding. Looks like you nailed it!
Old 01-07-2019, 10:33 PM   #2565
MiraclePieCo
The latest in my ongoing, perpetual, unending, eternal head plug saga:
Got the head into a machine shop today. A magnaflux revealed three 1-inch cracks radiating from the threaded temp sender hole. It can't be repaired; replacement is the only option. So far everything to do with this head plug debacle has ended up as worst-case scenario :-( Moral: never remove the factory sender bung.
Old 01-07-2019, 11:46 PM   #2566
dsraven
sorry to hear the head is toast. the good thing is now you know and can move on. weird that there were cracks like that unless someone over-torqued a plug at some point. anyway, its apart now and you know what the deal is, just a matter of getting a new head just like the old one.
dsraven is online now   Reply With Quote
Old 01-08-2019, 12:13 AM   #2567
nvrdone
don't get a head just like the old one - you don't want cracks in the replacement !!
nvrdone is offline   Reply With Quote
Old 01-08-2019, 01:55 AM   #2568
MARTINSR
MARTINSR's Avatar
My five minutes was spent cutting my rear springs apart and hauling them into the garage, no kidding, this took five minutes! HOLY COW I hate to think of the mail guy or gal who had to haul those babies up tot he porch!
I then spent about three hours, no kidding, THREE HOURS boxing up some rocker mouldings I sold on ebay. What will they get it, ONE of my spring shackles! LOLOL
Brian
1948 Chevy pickup
Old 01-08-2019, 05:05 AM   #2569
MiraclePieCo
You may remember the extreme difficulty I had removing that plug, so yeah, I suspect someone over-tightened it, or maybe the removal process caused excessive stress.
Since I'm only replacing one head I'll probably have to get one just like the old one.
Old 01-08-2019, 10:25 AM   #2570
DransportGarage
DransportGarage's Avatar
So, which head do you need? (You can thank me for asking later when one shows up from the forum!)
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 01-10-2019, 12:44 PM   #2571
cmayna
https://youtu.be/fYA7CQYeIpU
The green turd earning it's keep, picking up some more tan bark for the yard.
Craig
My truck '50 Chevy 3100-5 window
If I'm not working on my truck, I'm fishing with the wife or smoking Salmon.
cmayna is offline   Reply With Quote
Old 01-10-2019, 05:13 PM   #2572
MiraclePieCo
Pretty deft loader operator too.
Old 01-10-2019, 10:05 PM   #2573
DransportGarage
A while back I got a "good deal" on a used Corvette steering wheel. (Brings up an old quote, "One more good deal and we're out of business.") Underneath the leather cover, the top of the wheel that was most exposed to the sun had turned to mush. I cut out the mushy part of the foam core, then replaced that with a split piece of garden hose. I filled the hose with Great Stuff foam. Then I used pieces of fiberglass drywall tape coated with adhesive to build up the contour so that it matched original good foam. I then wrapped the whole mess with 1/2" strips of fiberglass drywall tape, like applying a cast for a broken bone. I think it's going to be fine, if I can hand-stitch a cover...
Bob
Old 01-11-2019, 01:32 AM   #2574
MiraclePieCo
Originally Posted by DransportGarage View Post
A while back I got a "good deal" on a used Corvette steering wheel. (Brings up an old quote, "One more good deal and we're out of business.") Underneath the leather cover, the top of the wheel that was most exposed to the sun had turned to mush. I cut out the mushy part of the foam core, then replaced that with a split a piece of garden hose. I filled the hose with Great Stuff foam. Then I used pieces of fiberglass drywall tape coated with adhesive to build up the contour so that it matched original good foam. I then wrapped the whole mess with 1/2" strips of fiberglass drywall tape, like applying a cast for a broken bone. I think it's going to be fine, if I can hand-stitch a cover...
I can't wait to see how this comes out.
Old 01-11-2019, 02:24 AM   #2575
DransportGarage
Me too.
Bob
