Old 01-21-2019, 01:52 PM   #1
sick472
sick472's Avatar
In Lieu of the Hood Brace Pads?
I am looking for ideas to add support to the 1/2 acre of sheet metal that we call a hood.
My hood has a tendency to oil can easily (on both sides), but has good shape when in the outward oil can position. The braces are not the same distance from the hood sheet metal from front to back (or sides to side) which means the replacement pads will only help at one end which leaves me worried that the hood will become a noise maker at highway speeds. I am currently preparing to do the skim putty work and would also like the extra support so that I do not exercise the oil can effect while block sanding.
I know I can cut rubber/foam material strips of different thickness and apply them as necessary (step the thickness up as the brace gets further from the sheet metal).
I do not want to try and bend the braces to improve the gap consistance for fear of permantly warping the hood.
I am currently toying with the idea of intalling jackbolts (#10 machine screws or similay) in the braces which would allow me to apply the "proper" pressure along the braces. These jackbolts would be backed by a strip of shetmetal that could be extra wide for extra support and be glued to the underside of the hood as well. This concept may also help adjust out any slight warpage prior to skim putty.
What's everybody doing with regards to hood support?
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 01-21-2019, 04:39 PM   #2
Red71gmc
Re: In Lieu of the Hood Brace Pads?
I have seen on this forum where a member put a cross brace between the two that run front to back. Basically making an H pattern and reinforcing the currently unsupported middle. He made it from the original brace material from a donor hood. It looked good
Red71gmc is offline   Reply With Quote
Old 01-21-2019, 05:23 PM   #3
tinkerdad
spray foam insulation
tinkerdad is offline   Reply With Quote
Old 01-22-2019, 04:12 AM   #4
Grumpy old man
Grumpy old man's Avatar
Spray foam insulation will hold moisture . Lay a clean bead of windshield urethane between the hood and braces let it set up over night and your done, it will also sound better when you close the hood .
Old 01-22-2019, 09:20 AM   #5
Sheepdip
Sheepdip's Avatar
^^^^^^^^^^^^^^^^This^^^^^^^^^^^^^^^^^^^^^^^^
Sheepdip is offline   Reply With Quote
Old 01-22-2019, 02:51 PM   #6
sick472
sick472's Avatar
I like the urethane caulk plan and the extra bracing as a back up. I still might tinker with the jack bolt/screws to fine tune the pre-puttied contours, but once the urethane is in place, remove the screws. I assume urethane dries pretty stiff unlike silicone that cures with a fair amount of sponge to it?
I considered the foam approach, but felt like the foaming action could push out on the hood too much as it expanded. I did not think about it holding moisture.
I am still open to any alternate ideas as I will not get to this work until next week, but, at least, I have a comfortable plan.
1972 C10
1985 K20
Old 01-22-2019, 03:21 PM   #7
turp mcspray
turp mcspray's Avatar
Don't glue the braces to the skin. When the hood skin warms in the sun, it expands. Where it is glued to the braces, it will not, and be low spot, looking like a dent. I use the hood bracing material. And bend the braces as necessary, if the gap is too large.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 01-22-2019, 04:28 PM   #8
sick472
sick472's Avatar
I would like to hear more about the bending techniques please. I imagine twisting or torqueing the rear brace and/or the rear skin while trying to equalize the brace to hood spacing. I have thought about blocking up the hood at the rear and along the front and pushing down on the braces so that the larger gap at the rear could be reduced, but I think the rear brace would want to twist as well.
My real fear is that, typically, when I put my weight into a body panel to "fix it"...It ends up getting worse rather than better.
1972 C10
1985 K20
Old 01-22-2019, 09:31 PM   #9
turp mcspray
On the braces that run front to back, I just set a 2x4 against the brace, and smack with a big hammer. Do as needed, until the bracing pads hold the skin up. The back brace has a much wider gap. Menards has different sizes of weatherstrip. I put it all the way across the back. It really helps stiffen up the skin.
Hope this helps.
Turp Mcspray
Old 01-23-2019, 09:41 AM   #10
Grumpy old man
I've used it before and it worked for me , YMMV , So answering the op's question "In Lieu of the Hood Brace Pads? " I suggested urethane , There are products available today just for this purpose but they are 2 part and pricey ( $ 20.00 - $50.00 ) requiring a 200 ml gun ($50.00) and urethane is cheap ($8.00 ) and just about everyone has a caulking gun . Without a picture to see just exactly what's bent anything that's cheap and fast and permanent may be better than time consuming jack bolts or adding extra bracing ? The op said "I do not want to try and bend the braces to improve the gap consistance for fear of permantly warping the hood ".
Reduces Noise, Vibration and Harshness in Vehicles
For collision repair jobs where minimizing NVH (noise, vibration and harshness) is important, the 3M NVH Dampening Material is an excellent complement to flexible or pillar foams and factory dampening materials. This two-component material applies smoothly and easily between roof skins and roof bows, door skins, door intrusion beams or other areas using non-structural type foam materials. Unlike many seam sealers, this material goes in soft yet remains very sturdy, allowing for expansion and contraction of automotive sheet metal. Yet it has no solvents so it won’t shrink and pull the metal in after installation. It minimizes application time and cleanup – it applies right from the cartridge without added mixing time, and provides up to a 1” thick layer of flexible material on vertical and overhead surfaces.
http://www.tcpglobal.com/FUS124.html
https://www.amazon.com/3M-04274-NVH-.../dp/B005IU2IPM
Old 01-23-2019, 12:17 PM   #11
sick472
sick472's Avatar
I am probably overthinking the step of my build, but that's what I do. So, I appreciate everyone's input to no end. Anything that make me think is a bonus.
I have attached a photo from before much of the de-rusting that best shows the gap changes from front to back. It's a bit hard to see, but the gap is much narrower towards the front. I did some pushing around on the braces last night and I think I can improve the gaps with some muscle without jeopardizing the niceness of the outer surface.
Part of me says...get the brace to hood gaps (center and front and back) supported with something like padding, weather-strip, edging or urethane, then do the outer finish work accordingly. There is slight waviness to the outer skin, slight, which would require the usual putty work. Now, part of me wants to add temporary shims to finely wet sand the primer to get a shine going on (it's remarkable how much shine you can get from primer by wet sanding with 600 to 1000 grit which makes body waves stick out like a fat thumb - just dont forget to rough the primer back up, paint does not like to stick to shiny primer - don't ask how I know that), then add the jack-bolts to compensate for some of the wave. Adding urethane at this point holds the finessed shape hence reducing the putty work. I am also thinking that I could wrap the braces with a heavy plastic before the urethane is applied and then trimmed away afterwards leaving the outer skin to be free to move independently.
I will argue that the efforts of all this may be about the same as other more common approaches...maybe I'm in this for the journey more than the results. Anyhow, I appreciate the conversation just the same.
1972 C10
1985 K20
Old 01-23-2019, 02:10 PM   #12
bs46488
I had the same problem when I started to block sand my hood.
I used SEM 39357 flexable urethane foam and bought one of those special caulk guns Grumpy mentioned off of ebay. It worked well.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 01-23-2019, 02:29 PM   #13
webfoot
The windshield urethane idea sure sounds like a winner to me.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 01-24-2019, 06:37 PM   #14
B. W.
B. W.'s Avatar
Just ran across this, thought I'd share. Putting a regulator in a 2010 Expedition, I'm guessing these little balls are similar to the anti-flutter foam that Grumpy posted a link to.
http://www.tcpglobal.com/FUS124.html#.XEo8rFVKjIU
B. W. is offline   Reply With Quote
Old 02-11-2019, 10:45 AM   #15
sick472
sick472's Avatar
I have another thread in the Paint and Bodywork section that inquires about filler putty and the hood's low spots where I show my attempts at siffening up the hood, but thought it best to add to this one as well for those interested. The bodywork thread is here if you want to get into the discussions revolving around laqcuer primer and filler options...
http://67-72chevytrucks.com/vboard/s...d.php?t=780912
Anyhoo,
I put 3/16” x ľ” bar stock at the side supports, drilled and tapped for #10-32 screws every 5 inches with matching holes in the support. The bar stock gives the screws something to push on and the aluminum flats (about 0.060" thick by 5 or 6" wide) protect the under side of the hood from the screws and evens out the pressure. The center support was made from ˝” x 1” x 1/8” thick channel, drilled and tapped for the same screws.
1972 C10
1985 K20
Old 02-11-2019, 10:46 AM   #16
sick472
sick472's Avatar
I will be applying widow urethane tube caulk through the holes (Red Arrows) in the braces to create supports about every 5 inches along ALL the supports, front, back, sides and center, and the jack screws will be removed. The urethane will adhere to the aluminum and keep in in place once the machine screws are removed. (you can not see it, but there is a thin strip of aluminum under the center channel brace) The aluminum is not glued to the underside of the hood. This should allow for some shifting between the two if any shrinking and expansion should occur. The long machine screws in the side braces used for "jacking" the hood will be replaced with shorter ones to keep the bar stock in place which will serve as additonal siffeners for those braces. The first and last screws on the center brace will also be relaced with shorter screws to hold the channel in permantly. Then the final sanding and filling will be performed.
1972 C10
1985 K20
Old 02-11-2019, 10:54 AM   #17
sick472
sick472's Avatar
SIDE NOTE: I measured the widest rear width of the hood to be 71-1/2” before the addition of the supports and jack screws. Once the hood was “jacked” the 71-1/2” dimension remained, meaning the hood kept its form…thank goodness!
The picture below shows the problems I was dealing with before the stiffeners...
I'll explain the situation: The outer-most high parts (OUTER BLUE LINES) of the waves are directly above the two supports that run front to back on either side. As if the hood was once supported well with the foam spacer pads at the metal supports (I removed the foam pads and they were loose as you would expect, but not by much). It appears as if the center section (with the front-to-back ridge) and the outermost sections have "flopped in the wind” long enough to stretch the metal. The ridge is high, like it's supposed to be, then it dips down (RED AREAS), then back up (over the supports), then back down (OUTER RED AREAS) until it evens out and approaches the side of the hood where it bends down to make the sides. Most of the wave is towards the front. Using a straight edge, (and my imagination because its all curved one direction or another) it appears to only need that 1/16” of fill maybe a bit more.
1972 C10
1985 K20
Old 02-11-2019, 10:56 AM   #18
sick472
sick472's Avatar
The results of adding the stiffeners are show below…the Green Stripes represent what used to be low areas that are now flat. I can see no light between the hood and a straight edge. I still have some low spots (Red Circles) to deal with. These areas are associated with the dings that have been hammered out. These areas will require some filler, but minimal, I hope.
1972 C10
1985 K20
Old 02-11-2019, 11:11 AM   #19
sick472
sick472's Avatar
I feel like this work has beefed up the hood a great deal. The sides beyond the side supports are still bit unstable, but much improved over stock. I hope that the epansion and contraction of the hood panel from sun heat does not come back and bite me.
I will likely be wet sanding the acylic enamel paint job down to a dull finish when it's all said and done so any slight warping will be masked due to its lack of shine. I am going for a old oxidized look as if the truck has been sitting, unused, since 1972. Kinda like Gringoloco did, but without the sand-through to the prmer (hopefully)...Look at post #363...
http://67-72chevytrucks.com/vboard/s...444746&page=15
Thanks for all the ideas and concerns so far!
1972 C10
1985 K20
Old 10-30-2019, 09:13 AM   #20
sick472
sick472's Avatar
Just a follow up post to show the final outcome. The extra bracing and the ability to tweak and adjust the pressure along the lengths of the braces really helped reduce the low spots which in turn reduced the amount of skim filler needed. All in all, the hood salvaged very nice and I have decided to leave a gloss finish on the truck to avoid dirt and such working into the dull finish.
Thanks for all the ideas and support folks!
1972 C10
1985 K20
Old 10-30-2019, 09:43 AM   #21
cornerstone
cornerstone's Avatar
Looks as smooth as still calm water. Well done bud.
Brian
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 10-30-2019, 09:57 AM   #22
sick472
sick472's Avatar
Originally Posted by cornerstone View Post
Looks as smooth as still calm water. Well done bud. Brian
Actually, that is "still calm water". I took that photo after the final wet sanding was done to the primer before the rinse water started to run off and dry. The actual paint job turned out well, but not THAT nice...it's the WET look!
Here's the dry primer look...
1972 C10
1985 K20
Old 10-31-2019, 12:55 PM   #23
72bowtiestepper
Thanks for the great ideas guys....I have this same problem on my 72 C-10 hood....oilcans when block sanding.
72bowtiestepper is offline   Reply With Quote
Old 03-23-2020, 09:16 AM   #24
Stover93
Getting ready to tackle this issue as well. I was at a loss as to how to try to block sand these hoods. I like the simplicity of grumpys urethane fix.
Stover93 is offline   Reply With Quote
Old 05-17-2021, 01:24 PM   #25
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Okay, so my hood brace pads will not stay in, these are all new. One of the little ones actually fell out and landed on my ram exhaust - what a smell! The long ones work their way out too. I am always stuffing them back in, which makes me feel they aren't doing much of anything. Other than driving me crazy!
Seeing my hood is all painted and all what about this Urethane Windshield Adhesive (3M that I can pick up from O'Riley's)? I kind of feel Grumpy wouldn't lead people astray but the comment from turp mcspray has me concerned for the long term. Last thing I want to do is paint myself into a corner and make something worse. I really don't see taking a hammer to these long braces or putting extra braces between them.
Anyone can chime in on using Urethane Windshield Adhesive on the long braces? If so, you to just put little blobs of dots up/down the brace or run a line from top to bottom?
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
