Re: TA_C10: Stage 1
More Dash Work - Ignition Hole
The PO also took a screwdriver or something and hammered under the bezel of the ignition I guess because he didn't know how to properly remove the ignition bezel.... So I filled it with metal and tried to straighten the hole best I could... Cut up with large gouges basically. Are there supposed to be 2 or 3 tabs in the ignition hole? .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
