02-19-2019, 01:29 PM | #1 | |
Moderator
Re: TH 700R4 TCC lockup wiring
C is unused... D is the EGR ECM terminal. Your harness doesn't have a wire in C or D. That doesn't matter. The picture is not needed. I have the uncompressed scans and a 50" 4K monitor.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
02-22-2019, 08:58 PM | #2 |
So the brake switch and the low. vac. switch unlock the tcc but what locks it?
02-23-2019, 05:43 PM | #3 |
To explain how it works, the brake switch, and low vac switch cut the power to the lock up solenoid inside the pan. Now a detailed description. In the trans there are 2 or 3 pressure switches and a solenoid. Power flows from the fuse panel, through the brake switch, then through the low vac switch and into the trans. If you throttle hard on the motor it's vacuum signal will decrease for for a brief time, causing the low vac switch to break the circuit and cut power to the lock up circuit until one of the switches inside the trans detects pressure in the 4th gear oil circuit. The brake switch works in a similar way, during braking or panic braking it cuts the power circuit and unlocks the torque converter, and remains unlocked until the 4th gear pressure switch detects pressure again. These same connections on the brake light switch also double as a cut off signal for the factory cruise control if equipped.
