Old 03-28-2017, 10:26 PM   #26
Dean'smeanmachine
Dean'smeanmachine's Avatar
Re: How i converted my '72 to Hydroboost for $35! (Lots of pictures)
So now it was time to plumb it. I dumped my pile of hoses on the work bench and started measuring and figuring
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 03-28-2017, 10:29 PM   #27
Dean'smeanmachine
I ended up using the feed line from pump to booster from the 2005 Chevy 2500 i pulled at the junkyard. it required no modifications. this line was all metric.
Dean
in God we Trust
Old 03-28-2017, 10:31 PM   #28
Dean'smeanmachine
It is always a good idea to blow out junkyard lines. A plugged line can cause all kinds of trouble
Dean
in God we Trust
Old 03-28-2017, 10:35 PM   #29
Dean'smeanmachine
I used the late 80's 1 ton line for the feed back to the steering gearbox . I cut off the metric nut on the gearbox side and slipped on a standard fitting, then double flared it.
Dean
in God we Trust
Old 03-28-2017, 10:40 PM   #30
Dean'smeanmachine
Then i grabbed the mid 70's T-fitting and made up a line for my steering gearbox return. keep in mind when running your return you want the least amount of bends as possible, and you want your bends gradual.the more bends,the hotter the fluid gets. A Steering fluid cooler is another option you may consider. I decided not to run one at this time.
Dean
in God we Trust
Old 03-28-2017, 10:48 PM   #31
Dean'smeanmachine
The finished product. I won't be able to try it out till the engine swap is done. Make sure to bleed your power steering!
Total cost: $35
Feel free to add info to this thread!
Dean
in God we Trust
Old 03-31-2017, 09:28 AM   #32
earl84
Wow, nice thread that will come in handy for a number of people. Nice work!
earl84 is offline   Reply With Quote
Old 04-04-2017, 05:22 PM   #33
cooperhw
cooperhw's Avatar
Good job and write up. I may do something similar one day.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-18-2017, 04:41 PM   #34
terrylgreenjr
great info and pictures.. Also just for some info the 87-91 blazer/ suburban gear boxes are metric threads so you can use the hoses from the newer model trucks with no mods if the length is right
terrylgreenjr is offline   Reply With Quote
Old 12-23-2017, 01:50 AM   #35
Billyburban
So you ran your original master cylinder from your factory booster c10 c20 c30 ? It’s been working just fine like that. I have a c10 but I’m running the c20 booster thought it would better braking but not much.
Billyburban is offline   Reply With Quote
Old 05-03-2019, 10:07 AM   #36
Hammered 77
Hammered 77's Avatar
Any updates on how it works?
Hammered 77 is offline   Reply With Quote
Old 08-22-2019, 10:41 AM   #37
1948ChevyDumpFixer
great writeup, thanks!
1948ChevyDumpFixer is offline   Reply With Quote
Old 08-24-2019, 01:30 PM   #38
CG
BlahBlahBlah
Last log in by OP March 2017. Hope the brakes held up!
Old 10-17-2019, 09:35 AM   #39
88Stanger
88Stanger's Avatar
Damn, i like this thread, wished he was around to ask some questions. I need to go to this due to vacuum issues. Great write up though
88Stanger is offline   Reply With Quote
Old 10-17-2019, 01:50 PM   #40
Billyburban
What was your question?
Old 11-13-2019, 08:51 AM   #41
vinnyschevy
Smile Re: How i converted my '72 to Hydroboost for $35! (Lots of pictures)
Great write up and good looking job.
vinnyschevy is offline   Reply With Quote
Old 08-20-2020, 10:48 AM   #42
coyote72
coyote72's Avatar
Great write-up. Thanks for all the pictures and info. Looking to do this soon.
72 K5 4x4 350
70 Nova 454 5spd 4-link
coyote72 is offline   Reply With Quote
Old 08-20-2020, 10:59 AM   #43
Thealien
Thealien's Avatar
What a great write up, wonder what happened to the thread starter?
Thealien is online now   Reply With Quote
hydroboost, hydroboost swap, ls swap
