Old 04-29-2019, 03:48 PM   #26
Redneck Rydes
Redneck Rydes's Avatar
Re: Quality hose clamps
Those are the only clamps I will use now,I use to use worm drive clamps in the past,but found them to loosen of and/ or strip out when over tightening them,I have been trying to find these in larger sizes for heater hoes and rad hose applications
Redneck Rydes is offline   Reply With Quote
Old 04-30-2019, 09:50 AM   #27
Kudzupatch
Kudzupatch's Avatar
Originally Posted by Stocker View Post
^^ I like the looks of that one! Don't think I have seen them before, do you know what they came on or where they can be purchased?
GM obviously, but I searching for an image to post I saw a few on Google but didn't look to close.
Kudzupatch is offline   Reply With Quote
Old 05-01-2019, 02:17 AM   #28
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Good stuff Killer Bee.
I was looking for an equivalent of your fuel clamps for 5/8" & 3/4" hose. Came up short for new ones, because the band width is 1/2" for water pump and intake ports. New ones are 3/4" wide, though the "Corvette" replacements might fit. But then I came across these. Pulled the trigger on two pair (yikes), heater and bypass hoses. They're original I'd say, looks like a thick band.
https://www.ebay.com/itm/NOS-WITTEK-...72.m2749.l2649
Not right for this truck, but better than the average worm drive seems. Not sure about the 5/8" heater hose yet, maybe Wittek. I probably won't install tower clamps for any of the water hoses.
My truck still had the original tower clamps for power steering, flame arrestor and fuel tank. They're still nice, so I'll probably install those. All the original water hose clamps are gone, probably for good reason.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-01-2019, 09:57 AM   #29
davepl
davepl's Avatar
Sorry didn't have time to read every post in this thread, but the quality ones I've found at the Witteks (either orig or repro company) from Eckler's Corvette. The ones I got from truck and car restoration places were paper thin garbage, but the Eckler's ones, while pricier, actually worked as good clamps, which is nice!
It's actually not clear to me that tower clamps were still used on the trucks in 69/70 but the motors came from Tonawanda and should be the same as cars, so I don't know what o believe!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-01-2019, 11:31 AM   #30
Killer Bee
Killer Bee's Avatar
^^ expensive but look like good quality and OE style
as far as how late tower clamps were installed..
feb 71 longhorn all four radiator clamps
and nov 71 mfr 72 my k1500 burb gas fill hose
Old 05-01-2019, 05:22 PM   #31
rcazwillis
Thumbs up Re: Quality hose clamps
Originally Posted by Killer Bee View Post
s
they're smooth around the hose so no chafing and have a pinch bolt for positive tension..
we use a lot of t-bolt style v band clamps on DPFs and related components so I thought I'd give them a try..
they fit well, tension range was plenty for the sizes I found paired up to the hose I needed..
I like these style clamps. Only down side is they have metric heads. SAE nut drivers won't work on the ones I have.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 05-01-2019, 08:38 PM   #32
Killer Bee
Killer Bee's Avatar
yer right about that! I had to plug metric 1/4 dr sockets on my driver handle cuz my fancy nut runners didn't fit
but they do seem to work good with even tension so ill give 'em a pass on the metric heads
Old 05-03-2019, 02:30 AM   #33
71CHEVYSHORTBED402
Ah metric. My truck was metric free until I installed the Moog steering linkage. Some of their "SAE" tie rods are metric, according to they you get what you get.
I think I found a set of 5/8" hose clamps to "match" the 3/4" I ordered the other day. Parts book says they're 7/8", but also says 3/4-1". Seller says they're a 1" opening and that should be correct for a 5/8" hose, which is a pinch under 1". Book says they were used in various applications, they run back to the 50s if I recall. Hit and miss through 72 or so. Were about half what I paid for the 3/4"
Hopefully that just leaves the 1.5" lines. At this point I think near solid band worm-drives, to match things up. Otherwise I'd be all over T-bolts.
Edit: They're exactly for 5/8" ID hose
Tony
Old 05-03-2019, 10:04 AM   #34
Joesjunk
Joesjunk's Avatar
Here’s a SPID picture I saved, it lists worm gear clamps as a special order item. I had never heard of, or seen this before.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 05-03-2019, 08:58 PM   #35
Steeveedee
Who Changed This?
Steeveedee's Avatar
YESSS! "Truckster", in post #5 in this thread asked me about this after I mentioned I had seen them on an SPID here. So, one of those rare options, but really exist.
~Steven
Simi Valley, CA
Old 05-03-2019, 09:28 PM   #36
WorkinLonghorn
WorkinLonghorn's Avatar
I just worked a very long day and I can hardly believe what I am reading here.
" I'll take the 350 V8, Turbo Hydra-Matic, and OH YES, the worm gear clamps, of course!"
I never really thought about clamps. I just re-tighten my worm gear clamps occasionally, but they do leak sometimes, agreed. Good thread. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 05-03-2019, 11:32 PM   #37
Steeveedee
Who Changed This?
Steeveedee's Avatar
IK,R? That would be next choice, right after I ordered the Corvette engine with the 3/4 cam in my truck.
~Steven
Simi Valley, CA
