![]() Join Date: Apr 2016
Window division bar felt question
I recently purchased the 8 piece door window seal kit from GMC Pauls. Before I start pulling out my old seals I thought I should ask about my division bar. It appears to have some stainless trim along the edges. The one on the inside of the passenger door is damaged as you can see in the picture. Is this part of the felt and will just go away when I remove the old or is it actually part of the division bar? The new division bar felts I got do not have any stainless edging. Do I need it? If so can it be fixed without replacing the whole division bar?
1972 GMC K2500 Super Custom Matt |
![]() Join Date: Dec 2013
Re: Window division bar felt question
stainless trim goes all the way to the bottom pull it off and forget about it . Really needs to be replaced about $30.00
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Thanks. I assumed it was just added trim and not essential but wanted to make sure it didn’t serve to help secure the felt before I started taking it out.
Thanks. I’ll keep those in mind.
