![]() Join Date: Apr 2016
Used Craftsman drill and bits
I went to the flea market today and found this drill. I wonder if any of you guys recognize what sort of bits these are that were in the handle. I don't believe I've seen any like this, they have a straight slot instead of the spiral I am accustomed to seeing on drill bits.
![]() Join Date: Dec 2009
Re: Used Craftsman drill and bits
Those drills with that drill holder was used for Bronze, Brass and Aluminum.
Bronze and brass tend to pull a regular twist drill into the work-piece quicker than a person can control. Those straight flute drills don't make that long stringy chip. A trick to use a twist drill on non-ferrous material is to dull the sharp edges a little so it won't pull in as bad. .
Excellent, thanks for that info, I like to learn stuff like that.
Tags |
drill, drill bits |
