#201 |
![]() Join Date: Jan 2015
Re: slammed 57
Went with Marman clamps to change out the mufflers (if I get tired of it being to loud) and also cut the old style exhaust flanges out ( Always had issues with the exhaust flange gaskets or the flanges them selves bending and not sealing right) So I cut the ends off and putting Marman clamps there as well. They seal great and last a long time. also going with these industrial flex fittings
#202 |
Re: slammed 57
practiced tig welding with silicone bronze and making some pie cut fittings so i can get the exhaust over the rear axle and out the back. I may try some 308L ss tig rods to see the difference
#203 |
![]() Join Date: May 2007
Re: slammed 57
looking good!
#204 |
Re: slammed 57
Hey my friend, great to see you're back. good work Mike
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#205 |
Re: slammed 57
#206 |
Re: slammed 57
Thanks morrie
#207 |
Re: slammed 57
before I install the exhaust system , I decided to stiffen up the frame mid section and fabricated a trans mount as well.
#208 |
Re: slammed 57
I like the additional support. 2x6? Post some more pics of the other end if you could. Your exhaust going to tuck up along the bottom of it?
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#209 |
Re: slammed 57
I went with 2x4 and centered it on the 2x6 rails so it would leave a inch above and below so I can run air lines, brake lines and electrical in a continuous straight line
#210 |
Re: slammed 57
whole new respect for the guys that build exhausts for a living. this was my first time building a exhaust system . tried hard to go over the axles but there was now way of doing so with out raising the bed more that what it already is. but its done. next on the list is gas pedal and firewall brake and clutch assembly.
#211 |
56 - autocross
Re: slammed 57
Nice work!
#212 | |
Re: slammed 57
#213 |
Re: slammed 57
Had cut into the recessed fire wall and section out a little area for the lokar gas pedal would only reach 1/2 throttle. After the sectioned area I have full throttle no problem. Also installed the pedal assembly. I also ordered today wilwood front and rear discs/calipers as well the master cylinder. So Iam lookin forward for it to get here.
#214 |
![]() Join Date: Mar 2011
Re: slammed 57
Looks good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#215 |
Re: slammed 57
Looking good man, everything is looking really good.
#216 |
Re: slammed 57
Nice job!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#217 |
Re: slammed 57
Awesome job as usual Slammed..
Lokar makes some nice stuff. JT from SC |
#218 |
Re: slammed 57
#219 |
Re: slammed 57
thanks bam. hows the truck coming along?
#220 |
Re: slammed 57
Yes sir they do. thanks so much
#221 |
Re: slammed 57
the work as usual is great, nice pedals to Mike. Is that all billet??
#222 |
Re: slammed 57
Hey morrie... they are from lokar , not sure if they are billet or not.... could be
#223 |
Re: slammed 57
nice forward thinking on the planning of things. stuff unbolts and room left for brake lines etc. a lot of guys forget that little stuff.
#224 |
Re: slammed 57
Thanks bud, I agree. but no matter how much I try to pre plan ,something comes along and i say " crap I didnt think of that" lol
#225 |
Re: slammed 57
The wife says” why you keep starting at them, they’re only brakes” big sigh, she’ll never understand. I always wanted a set of these, needless to say I’ll be busy all day tomorrow putting them on
