Old 12-15-2019, 01:46 PM   #1
buds56
buds56's Avatar
67 GMC Pontiac powered Project
My initial goal with this truck was a low buck project that can be driven and use up some stuff I have laying around.
Bought this for $700, Longbed stepside that the cab looked pretty decent, maybe just rockers.
Rest of the truck is pretty beat but salvageable.
buds56 is offline   Reply With Quote
Old 12-15-2019, 01:50 PM   #2
buds56
buds56's Avatar
Re: 67 GMC Pontiac powered Project
First order of business was to shorten the frame, This was pretty easy.
Not sure why pics are rotated, will have to look into that.
Old 12-15-2019, 02:09 PM   #3
buds56
buds56's Avatar
I have a low mileage 400 Pontiac and 400 turbo I thought I would use it here.
Used 73 up frame brackets, with some minor tweaking, fit is pretty decent.
Sorry about the rotated pics, They're straight on my computer, Used the search function to no avail
Old 12-15-2019, 02:22 PM   #4
buds56
buds56's Avatar
Well the thought of not pulling the cab was short lived.
picture hosting sites
Rockers, supports, floor section, Cab corner.
Old 12-15-2019, 02:28 PM   #5
flashed
Im in to see more .
flashed is offline   Reply With Quote
Old 12-15-2019, 02:29 PM   #6
buds56
buds56's Avatar
Shot a little paint
Cab back on
Old 12-15-2019, 02:42 PM   #7
buds56
buds56's Avatar
Pretty much where it sits now, It definitely is not a show build but should be ok.
I'm a little hesitant to post after seeing so many beautiful builds
Dash coming together
More progress as it happens
Old 12-15-2019, 02:47 PM   #8
HO455
HO455's Avatar
Cool! So you used the 73 truck frame brackets and which motor mounts? Glad to see you posting. Keep up the good work!
RIP Bob Parks.
Old 12-15-2019, 04:26 PM   #9
buds56
buds56's Avatar
Here's the driver side, had to cut about an inch out at the top.
pass side, no cut, engine brackets 74-76 full size Pontiac
Old 12-15-2019, 05:12 PM   #10
HO455
HO455's Avatar
Wow! Good stuff!
Thanks for the photos.
RIP Bob Parks.
Old 01-25-2020, 08:37 PM   #11
buds56
buds56's Avatar
A little progress
CPP Disc brake kit, Nice kit, they originally sent the wrong rotors, but they made it right.
I moved the brake hose mount to the front side of the crossmember so the hose would fit better.
Old 01-27-2020, 12:48 PM   #12
68Gold/white
What part of the drivers side mount did you have to cut???
GMC goofed when they stopped using Pontiac engines in 59 (?)
THat 400 will be awesome in that pickup!!!
68Gold/white is offline   Reply With Quote
Old 03-07-2020, 09:22 PM   #13
buds56
buds56's Avatar
It runs,
Sounds pretty good,I'm afraid I may have let the engine sit too long,
A bit of a miss and smoke out the right exhaust.
Hopefully it will clear up after I run it some more.
Other progress, brake lines, rear brakes, E brake cables, most of the exhaust.
Some wiring gremlins to deal with under the dash.
Old 03-08-2020, 01:35 PM   #14
HO455
HO455's Avatar
Looking good! I like the blue and gold.
RIP Bob Parks.
Old 04-03-2020, 08:45 PM   #15
buds56
buds56's Avatar
A little temporary progress, I bought another car and needed to clean out the extra bay of all the truck parts so I threw some parts together
Engine coming back out
I bought this engine out of a 60k mi. rusty 72 Catalina. I figured I would take a chance.
After running the engine, it had a miss that turned out to be a flat cam, and upon disassembly there is a little rust pitting in the cylinder bores .030 should clean it up, so now I'll do it right and rebuild it.
Old 04-03-2020, 08:59 PM   #16
Corts60
Just here to tinker
Corts60's Avatar
Looks great buddy!
Old 04-03-2020, 09:02 PM   #17
Sheepdip
Sheepdip's Avatar
Wasn't that long ago if you bought a new GMC it might have very well had a Pontiac Motor in it.
Sheepdip is offline   Reply With Quote
Old 05-23-2020, 07:34 PM   #18
buds56
buds56's Avatar
Got the engine running good today,
Bored .030 pistons, bearings,valve job,mild performance cam.
I couldn't get it to run right with the old AFB, I had an Edelbrock intake and always wanted to try a Demon carb, which worked excellent out of the box.
So, I'm back to where I was in March ready to make some progress.
Old 05-28-2020, 08:41 AM   #19
HO455
HO455's Avatar
I would exactly say "I'm back to where I was in March" , cause now that engine is as pretty on the inside as it is on the outside!
RIP Bob Parks.
Old 07-04-2020, 09:36 PM   #20
buds56
buds56's Avatar
Some progress
Ran it up the gravel road seems to run good
I got the front end together.
The doors were pretty rough, so I got a set of aftermarket ones. There is a parts supplier is within 100 miles so I saved on shipping.
Took the front fenders back off
The right door went right on.
The only left door they had was a customer return
and he knocked $100 off it, so what the heck I took it.
It took me two days to get it to fit. had to drill out the spot welds on the top frame and adjust to get it lined up plus a little hammer and dolly work on one edge
Still need to work on the fender adjustments a bit
Old 07-06-2020, 11:16 PM   #21
raggedjim
raggedjim's Avatar
Nice, I've had a couple of Pontiac 400's, good engines if you don't over rev them.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 08-01-2020, 08:25 PM   #22
buds56
buds56's Avatar
A little progress, found a pretty decent hood
Old 08-01-2020, 09:38 PM   #23
Old Truck Man
Old Truck Man's Avatar
I once owned a 55 GMC with a factory 287 Pontiac engine. I have a 317 out of a 56 GMC. once I installed a 301 Pontiac in a 72 chev. I have a 67 400 with the stick bell & flywheel Been thinking about putting it in my 82 chev 3/4 ton. Im a big fan of Pontiac engines.
Old Truck Man is offline   Reply With Quote
Old 05-06-2021, 02:10 PM   #24
HO455
HO455's Avatar
Its been awhile any updates?
RIP Bob Parks.
Old 05-10-2021, 08:17 AM   #25
buds56
buds56's Avatar
Not much to report, stuck in paint jail,it's been 9 months, needless to say I am less than pleased.
