Old 02-05-2020, 05:40 PM   #301
KMC3420
KMC3420's Avatar
Re: 1971 Stepside LS Build
Originally Posted by 1971Stepside View Post
I ran two lines. One for the rear and one for the front. The front line hits that t-block you see in the above picture. It then runs to both front lines from there. That first pic is a little tricky in that the line to the passenger front brake is not installed yet.
It looks nice and clean regardless, but I did notice that extra line going past the T block. I was referring to the two "FO" front out ports on the bottom of the Prop valve. Did you just plug one of the "FO" ports? I haven't seen an instance where two front brake lines were ran to the separate front brake calipers I don't suppose.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 02-10-2020, 10:24 AM   #302
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Didn't get a lot of shop time this weekend. I am working on cleaning up a lot of little projects that need to be done on the build. One of them is the support bracket for the cold air intake. I have a bad habit of leaning over the front of the truck and laying my arm on the intake and it slowly sinks down. So, I made this bracket that uses the factory holes on the alt bracket tower. Turned out pretty clean.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-10-2020, 10:52 AM   #303
MDPotter
MDPotter's Avatar
It's all in the details! I took the same approach, but mine isn't as low-key/hidden as yours. Now I'm gonna have to redo mine...
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 02-10-2020, 05:07 PM   #304
1971Stepside
Almost Satisfied
Ah, sorry. I did just plug one of the holes on the prop valve.
Old 02-10-2020, 06:58 PM   #305
KMC3420
KMC3420's Avatar
I thought so, no worries. Nice job on the intake tube holder...nicely thought out.
Keagan
Old 02-10-2020, 07:53 PM   #306
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Would you be able to tell me what radiator hoses you used? I was able to see the upper in one of your posts. It looks like a Gates 21439. Can you confirm and tell me what you used for the lower? Thanks a bunch. By the way... nice idea on the intake support!
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-11-2020, 10:24 AM   #307
1971Stepside
Almost Satisfied
Upper Radiator Hose = Gates 21439
Lower Radiator Hose = Gates 20687 had to cut the end off
Old 02-14-2020, 12:41 PM   #308
1971Stepside
Almost Satisfied
The AC puzzle continues...but, I'm making progress. I wish I had purchased the polished compressor now. Happy with how it is coming together so far.
Old 02-14-2020, 01:00 PM   #309
TA_C10
TA_C10's Avatar
That looks really good man. I really like the bulkhead connector. I wish I knew about those before I got started. And tell me about your hose routing under the compressor, did you just want those tucked under compressor? I'm trying to figure out how your gaining anything tucked so far under when the rest of hoses will be coming across the inner fender. I like where your going with that is what I'm trying to say. And maybe you can just polish the compressor yourself? I wouldn't think it would be too hard? Or perhaps sell yours and get the polished. Cuz I agree, all that shiny would look sweet.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 02-14-2020, 01:19 PM   #310
1971Stepside
Almost Satisfied
I'm not sure where I'm going with this yet! LOL That is the problem. I want the four hoses to lay as close to the frame and inner fender as possible so I am trying to get the down in that direction. I may end up rolling the compressor back up and see where the fittings land. The only hose I see giving me fits right now is the one that runs to the condenser. I thought about sending this compressor back to summit and ordering the polished one. I assume they would take it back. I may try to sell this one...dunno. Polishing this one sounds like a lot of work
Old 02-15-2020, 10:26 AM   #311
derotoreut
derotoreut's Avatar
I did the same as you. Ordered the same compressor, but I wanted the standard finish because I thought it fit better with the look of my engine bay. My alternator and accessory bracket are not polished and I thought if I had a polished compressor, it would be too much. I kind of wished a bought it with a rear exit head though and not the type that you and I have. I had mine oriented like yours and I just flipped it up. I know for proper operation, they don't like to have them turned to where the ports are facing down. I think it's OK sideways, but I got a little nervous and just flipped it up. I bought the Vintage Air, 35137-VUG-A (non-polished) line kit. Looks like that's the way I'll go. I'm also using VA's EZ clip system and planning to route my lines out of the fresh air vent. Struggling with that now.
~ Dan
Old 02-17-2020, 10:40 AM   #312
1971Stepside
Almost Satisfied
derotoreut first let me say how good your truck looks!
I rotated my compressor back up right and took a look at hose alignment and opted to rotate it back on its side. VA told me that it would be fine at this angle and the hose kit was made for it to be tilted. I mocked up the hoses and of course need a couple different fittings, but overall I think I am going to like this.
I also planned to run behind the fender into the vent, but realized that in order to make the bulkhead plate work there I was going to have to cut open the cab again. I didn't want to do that. I also feel that having the bulkhead on the firewall balances the brake booster out some.
Old 02-17-2020, 10:53 AM   #313
derotoreut
derotoreut's Avatar
Hey it looks really good. I'm glad VA confirmed the operation with the side way mounting. The firewall bulkhead looks real good too. I kind of wish I went that route now, since I'm running into a few issues, but I'm too fare into it and already got my firewall insulation installed. Keep up the good work and appreciate the comments.
~ Dan
Old 03-02-2020, 10:58 AM   #314
1971Stepside
Almost Satisfied
Haven't been able to get a whole lot done on the truck. I did get the hydro/pwr steering hoses sorted out and the AC/Heater hoses routed. I now need to get them all crimped. Have a pretty good list of things to get done prior to paint in early June.
Old 03-02-2020, 12:14 PM   #315
MDPotter
MDPotter's Avatar
I'm curious to see how you did your hydro/power steering hoses.
Old 03-02-2020, 12:31 PM   #316
derotoreut
derotoreut's Avatar
Nice work. It looks great. It looks like you used 90-degree molded heater hose lines. I'm doing the same on mine. Keep up the good work. I just posted some of the AC/heater hose mounting on my K10 build thread. It's a challenge for sure.
~ Dan
Old 03-02-2020, 02:02 PM   #317
sprint_9
sprint_9's Avatar
The bulk head and lines turned out great. Keep up the good work.
sprint_9 is offline   Reply With Quote
Old 03-04-2020, 11:15 AM   #318
1971Stepside
Almost Satisfied
Here you go.
Old 03-04-2020, 11:18 AM   #319
1971Stepside
Almost Satisfied
Added an additional fitting into the AC to allow the PCM to control the idle and the fans. This came with the BP Automotive harness. It forced me to change one of my hose routing and now I'm pretty close to the header. Something I will have to monitor to see if it gets it too hot. Overall, the engine bay is a little busier than I wanted, but I am happy with how it is turning out.
Old 03-04-2020, 02:15 PM   #320
MDPotter
MDPotter's Avatar
Is that a sensor or a switch to sense the line pressure that in turn will tell the PCM to increase the idle when the compressor is engaged or turn on the fans when the pressure gets high?
Old 03-04-2020, 04:02 PM   #321
1971Stepside
Almost Satisfied
This is an AC pressure transducer. It tells the PCM to turn on fans and increase idle.
Old 03-05-2020, 12:17 PM   #322
Custom 68
Custom 68's Avatar
You are coming along great on this. It is sure shaping up.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-05-2020, 01:01 PM   #323
bman67
bman67's Avatar
I would like to see this truck in person as you have provided so many ideas that I will be incorporating into my build when time permits. This is one of my favorite builds to follow. Keep up the great work and can't wait to see it finished.
bman67 is offline   Reply With Quote
Old 03-05-2020, 04:44 PM   #324
1971Stepside
Almost Satisfied
Thanks Dave! Would love to show the truck to you in person.
I don't know what to say! Post like this sure help keep me motivated. I appreciate it and glad it is helping others.
Old 03-05-2020, 07:31 PM   #325
TA_C10
TA_C10's Avatar
I'm glad you went with the transducer. I will be curious so see how this all turns out as I may end up using that module as well. So did you end up using the VA binary switch for the compressor as well? In your last picture I see something installed but can't tell from binary to trinary.
"It's only money".
