Old 02-09-2020, 02:08 PM   #1
clay68c10
clay68c10's Avatar
Tilt column
SOLD
$425 local, $475 shipped.
Please respond in thread only per board rules, first "I'll take it" gets it.
Selling a painted and converted motorhome tilt column. From a mid 80s GM chassis
It has the straight shifter arm like a truck tilt
Also has the metal gear indicator
I moved the NSS down so it's a bolt-in for your 67-72; I used my multi-meter to adjust it, you may need to fine tune it after install.
Turn signal and tilt levers are new from GMC Pauls
Turn signal switch is new
Includes the cancel cam
The gray illumination wire is full length with the green end
Includes a long pigtail for the Neutral Safety/Reverse switch
Tilt mechanism is tight and smooth.
The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight.
Tilt pivots were cleaned and lubed when removed to tighten the bolts.
The bottom bearing was cleaned and greased
The upper bearings were cleaned and greased
The shift indicator bulb was replaced and tested OK, it has the green shade on it.
Shifter lever end (inside column) is good, pivot is good
Shift arm has nice chrome, it shines up well.
The finish on it is base/clear coat gloss black.
The shift arm is metallic silver and includes the rubber bushing and metal sleeve
New firewall and dash gaskets from GMC Pauls
I will include a new GMC Paul's gear indicator
Also can swap out the indicator lens for an OD version at the same price
You will need to add your metal firewall plate.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-09-2020, 02:12 PM   #2
clay68c10
clay68c10's Avatar
Re: Tilt column
More pics
13 Tahoe LTZ
Old 02-09-2020, 02:15 PM   #3
clay68c10
clay68c10's Avatar
Re: Tilt column
Last one
13 Tahoe LTZ
Old 02-09-2020, 02:41 PM   #4
SoCoC10
SoCoC10's Avatar
Re: Tilt column
I’m happy w/my tilt Clay restored. This shouldn’t last long. A great buy!
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 02-09-2020, 02:43 PM   #5
clay68c10
clay68c10's Avatar
Re: Tilt column
Thanks Troy
Are you sure you don't need a pretty one??
13 Tahoe LTZ
Old 02-10-2020, 03:10 PM   #6
robpp
robpp's Avatar
Re: Tilt column
im looking for a tilt floor shift for my 70 C10, local to you.
Thanks,
Rob
robpp is offline   Reply With Quote
Old 02-10-2020, 03:26 PM   #7
4x41971SWB
Re: Tilt column
I'll take it
4x41971SWB is offline   Reply With Quote
Old 02-10-2020, 03:57 PM   #8
clay68c10
clay68c10's Avatar
Re: Tilt column
Sold to 4x41971swb
PM sent
13 Tahoe LTZ
Old 02-10-2020, 04:38 PM   #9
4x41971SWB
Re: Tilt column
Originally Posted by clay68c10 View Post
Sold to 4x41971swb
PM sent
Payment sent.
3 speed indicator
Old 02-19-2020, 11:45 AM   #10
4x41971SWB
Re: Tilt column
Recieved this the other day and opened it up last night.
All I can say is WOW!!
It looks amazing and thank you for the more than fair price!
Old 02-20-2020, 04:51 PM   #11
clay68c10
clay68c10's Avatar
Re: Tilt column
My pleasure. I can’t take all the credit, my buddy Dave does great paint work.
13 Tahoe LTZ
tilt, tilt column, tilt steering column
