70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I'm done and cant fight myself anymore..
I have been on the fene for a lot of years on whether or not to lower my truck. i wasn't planning on a knucklke dragger or air bag thing but a slight 2 1/2 inch spindle and 4 inch spring rear drop just to level the truck out and give it the look... I bought the pictured rims ( 17 x 8 ) and was gonna put them on my 99 Cop Tahoe but they are too big for the front of it with the factory 3 inch lower job on the front. So scrolling through Mecums upcoming March 11-14 Glendale Arizona Auctiuon I see the pictured truck with the rims that are very similar to mine and the slight drop on the truck and well I was done and crossed the line and am going to lower mine 2 1/2 - 4 and put my 17's on it. Now that ECE is done anyone have any recommendations other than CPP to get the lowering parts.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: I'm done and cant fight myself anymore..
Rear coils? Nice wheels, they will look sharp.
My '69 long bed has McGaughey's 2-1/2" drop spindles in front and 4" drop springs on the rear. You can get them from Summit with free shipping.
I like the stance on your truck and its what I want. Did you use the shock relocators and adjustable panhard bar as well ?
Already Gone,
Your truck will pop with those wheels and the drop you are looking at. I used McGaughey's 4" drop, progressive springs on the rear of my truck along with a shock relocation kit and adjustable bar. I have not started on the front yet. Possibly start the tear down in the next few weeks and determine who I am going to get my drop spindles and such from soon.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
![]() Join Date: Aug 2018
I buy most of my suspension parts from Performance Online.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Don't want to hijack the thread, but I have a question for Itdmstr. What size tires are running and do you have any rubbing issues. Your trucks stance looks great, that is the drop I am looking to get as well.
No hijack as that is a relevant question.
U might want 2 check into a drop block and spring set up. The more drop from the spring the ride will tend to b a little rougher. Drop blocks can go up to 2 inches. You shouldnt need an adjustable panhard bar due to drop not being more than 4 inches.
![]() Join Date: Oct 2010
This is 2 1/2 and 4 drop. Drop spindles and 4" drop springs in rear.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Just FYI in regards to the wheels if they are American Racing. I have similar set on my LS6 swapped 98 Jeep Wrangler. They have over 10 years of mall crawling and summer time use and they still look great. The best part is the center black spokes and polished rims are powdered coated so zero maintenance other than wash and dry.
![]() ![]() Join Date: Sep 2008
This was a 2 1/2, 4 drop. I used ECE so I don't know about sources for parts. I used their shocks but didn't do anything to the panhard bar and no shock relocators. Rides great.
![]() Join Date: Jul 2015
Being one from the never look back crowd what would one do if you did not like the drop?
One of the great things about these model year vehicles is the availability of parts. What happens when the supplier of aftermarket parts goes out? I would keep every part off your rig for sale purposes. Found this about a week ago, check out the article on the Camaro. https://www.historicvehicle.org/nati...vrolet-camaro/ I grew up in the Motor City realizing at an early age how life in America changed tremendously when the common car came about. It would be very important to be able to put the vehicle back to stock with little to no modification. |
#15 |
Wheels are Wheel Vintque 15x8 with police style hubcaps from Coker Tire. I'm not sure of the offset. Tires are 275/60-15 on the rear and either 245/60-15 or 255/60-15 on the front (truck is at my shop right now but I can check in a couple days if you want me to). Everything fits fine. Body and fenders are all stock and I have no rubbing or clearance issues at all.
#16 | |
#17 |
Truck looks great, so you used ECE's shocks for lowered trucks with a 2 1/2 inch drop spindle and 4 inch dropped spring ?
#18 |
I'm thinking you have 17 inch tires on your truck and are they 8 inches wide ? Also what size tires on the truck ?
#19 | |
Here it is with 17 X 8 wheels.
#20 |
![]() Join Date: Aug 2004
davischevy;
What tire size are you running? It looks great with the 17s
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
