04-30-2020, 12:45 PM | #1 |
Proprietor of Dale's Corner
Re: 69 K10 From the Field
Nice job on the fender and step.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-30-2020, 01:51 PM | #2 |
landarts
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
05-01-2020, 05:04 PM | #3 |
05-04-2020, 10:08 AM | #4 |
landarts
Thanks, really like the term de-smashed.
Spent the weekend doing K20 related items. In order to work on trucks at my house because of CCR rules, all vehicles must be in operable order. I have the 68 K20 long bed step side truck that I picked up over Easter weekend. It does not run or drive yet. Motor needs some work on it and the center tie rod link is bent so you can not turn to the left. So when I looked into what it would take to make it run I pulled plugs and squirted a little transmission fluid in each hole and when I got to plug in the 5 hole it looked really bad so I to pull the valve cover on that side to take a look see. The number five piston was missing the exhaust port pushrod. So instead of dumping money into this motor right now and chase down all the issues I decided it would be faster to drop in another motor that runs and deal with this at another time. So I spent about two hours getting all the bolts, wires, hoses, radiator and linkages disconnected or removed so it can come out. The truck also has a bent center link tie rod so i also removed that so it can be replaced. So this week I will remove the motor and install another on Monday afternoon. Make all final connections and have it running by Tuesday afternoon. Deal with the tie rod issue on Wednesday and take it over to DMV to get registration and plates. This will resolve the inoperable vehicle issue. Was able to get more sanding done on the 69 cab and a few touchups on the drivers door. Ordered all new steel bed strips and hardware to redo the long bed step side bed. Then went down to the local hardwood supplier and picked up my order of Ash wood for the bed that I placed on Friday. I will need to plan the wood down a 1/4 inch and cut to length and dado cut the grooves before I can put the finish on it and install. Also had another 71 K20 delivered by my two sons that went up to Pullman Washington area to pickup a truck I purchased a month ago. Spent the day Sunday just joy riding the truck and in the afternoon took my 16 year old son over to the foothills and taught him how to drive a stick shift. He got the hang of it pretty fast, should have got a photo of the grin on his face when he was able to shift through all gears and actually drive it with a stick shift. Pict 1 - 68 K20 getting everything ready to remove motor Pict 2 - 68 K20 getting the center tie rod removed Pict 3 - 71 K20 being towed back to the stable for a little cosmetic restoration
