#1026 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: What did you do to your Blazer/Jimmy today?
looking very good
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#1027 |
![]() Join Date: Nov 2014
Thanks! Few details left and she’ll be ready for a new owner.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#1028 |
![]() Join Date: Feb 2009
Prepped the front floor pan and the bed pan. After the front floor pan was fitted by the gy doing my metal work, I brought it home, shot it in epoxy primer, then coated the bottom side in Rustoleum Semi-Gloss, reduced with acetone and used an alkyd enamel hardener. It came out glossier than I would have liked. The top of the front floor is Kirker Semi-gloss Synthetic Enamel with a hardener. The rear bed floor is just in epoxy primer.
BTW, I'm tempted to paint the rear bed pan while it is out. I will be replacing both bedsides. Do you think I can paint it now, then mount it and install bedsides without too much damage to the paint? It is hard for me to reach the middle areas to paint... ![]() ![]() ![]() This is the expected body color, TCP Global Jet Black. I shot it the other day while painting my son's bike. ![]()
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
#1029 |
Refinished the center console and installed a radio inside.
#1030 |
Replaced the rear wheel center caps with new stickers.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 05-16-2020 at 10:08 PM. |
#1031 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Swapped incandescent for LED courtesy lamp bulbs.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#1032 |
![]() Join Date: Jan 2018
#1033 |
Primed, blocked and primed again!
Pat |
#1034 |
Carpe manana
I’ve been doing a lot of tinkering lately with the doors open so wanted bulbs that didn’t get as hot. The light is a lot brighter.
#1035 |
![]() Join Date: Nov 2015
New shoes for 2020
#1036 | |
![]() Join Date: Jan 2007
Washed and “waxed” today with some Meguiar synthetic product...I probably should have clay bar/waxed it instead. Hosed out the interior....K/5’s are awesome! ![]()
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
#1037 |
Paint day!!!
All that prep work finally paid off! Looks straight and correct! Pat |
#1038 |
Carpe manana
Loaded onto a flat bed for trouble shooting a new ticking sound coming from the original 350, which hasn’t yet clocked 600 miles. Looks like a sheared valve keeper and a chipped valve. Doh!!
What’s likely fix? Pull engine, pull head, replace valve?
#1039 |
Damn! That sucks Pete!
I know I sure seem to have a lot of problems with newly rebuilt motors too. Most of my problems have centered around comp cams roller lifters. Sorry you're going through this! Pat |
#1040 |
Carpe manana
Thanks Pat. This too is a roller hydraulic cam. Hope to have more info later today.
#1041 |
Man that sure does suck. Is there a warranty from your builder?
#1042 |
![]() Join Date: Jan 2013
Found a lowered bench seat bracket for my 2wd blazer years ago.Readjusted the pas seat to match. Valve fix=make a sparkplug to air fitting then tdc and 100 lbs.push the spring down replace the retainer (maybe new) and cross your fingers,not to much to loose. I'v done it with a gismo that bolts to the rocker stud.
#1043 | |
#1044 |
#1045 |
Just got my auto wrecker Steelies and Dog dishes on. Widened to 8 inches, painted and 10.5 x33 BF Goodrich.
Posted via Mobile Device |
#1046 |
Carpe manana
Dale thanks. Clock ran out on that a while ago. I’ve been talking with the owner of the machine shop though. He’s a genuine guy and every bit the old, old school machinist you can imagine. Were I still in ABQ I’m sure he’d work with me to make it right.
#1047 |
Carpe manana
Looks great!
#1048 |
#1049 |
#1050 |
New grille and trim rings.
