#4526 |
Re: What did you do with your truck today, Part 3
I actually got something done on my truck! WHOOOO HOOOO! It was a screw up mistake that I had done but it's corrected, been bugging the crap out of me.
The door now fits! Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#4527 |
OEM front bar installation continues. Cleaned up the last bracket and installed the bar into the clamps using modified '67 Camaro rear bar bushings. The OE end links are junk so I straightened a set of 94 Wrangler links. Today I took some time to modify aftermarket shock studs so they would fit into the bar. Tomorrow I need to come up with a bushing so the top link can attach to the frame properly.
As a side note the front bar from a 94 ish YJ Wrangler could be a good match for our trucks. If this small OE bar doesn't work out I'm looking at switching to the Wrangler part. Last edited by 1project2many; 07-05-2020 at 08:53 AM. |
#4528 |
I don't know if this counts but I got my new lathe set up. I have been working the last few weeks on building shelves and moving stuff to storage. I also have raised the elevation on my scrap pile. I have been working on parts for over 2 years and am very close to starting on the girl. I have never run a lathe but that never stopped me before.
#4529 | |
Today I hooked up a vacuum line to my OEM windshield wiper motor. I was really reluctant to drill a hole in my firewall on which I spent so much time filling holes. The studs go back-and-forth nicely, but we'll see how the 70-year-old motor does with actual blades installed. Still waiting for those via mail order.
1951 Chevy Panel Truck |
#4530 | |
https://www.amazon.com/How-Run-Lathe.../dp/1614274746 |
#4531 |
so a few weeks ago my fuel gage quit working - it all ways showed full. after running multiple tests I found there was a damaged wire in the harness going to the rear mounted tank. so time to fix it. made a new harness to fix the problem. got it hooked into the dash tonight & run back to the rear end. so more work tomorrow. hopefully will have it finished by this weekend.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
#4532 | |
#4533 |
![]() Join Date: Oct 2016
I finally got the front bumper all lined up and mounted. I didn't have the front horns at the right angle on the 77 Nova front clip, so it has been interesting!
#4534 |
Looks sharp, great color on that truck.
![]() What did you decide on the emblems?
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. |
#4535 | |
#4536 |
I now have WWW - working windshield wipers.
#4537 |
#4538 |
I'm making a cover plate out of 1/8" 5052 aluminum for my Tremec TKO 600. Primarily this is to solve a housekeeping problem. It's all sealed up but I figure a polished plate will have much better aerodynamics. My etch-a-sketch skills aren't what they used to be.
#4539 |
Well after moving 700 miles and flipping my world upside down I am back to my truck in my garage. I got the hood sectioned started (cab is sectioned 2.5 inches and chopped 3.5) just tacked back together, none of the real fine tuning or planish welding or anything like that. This was a year ago, it kicked my butt getting it to this point. Tonight I spent literally a few hours looking at it planning my attack. I am not kidding, I have chopped many cars, some very complex. Did suicide doors before there were kits to do it. I chopped a VW Bug once in one day, from the first cut to primer, no kidding. And this wasn't rat rod stuff, we are talking show car stuff. I only say this, not to brag or say I know everything because that is the point, I DON'T. This hood sectioning is spinning my head! It makes chopping the top look like making a friggin peanut butter and jelly sandwich! Ok, I think I have it to move forward, wish me luck.
Brian
#4540 |
They can be useful!
Brian
#4541 |
I worked on my cover plate for a couple of hours. It's really hot here. I just need to polish it now. I also spent my normal couple of hours chasing parts. When I get this done I can paint the tranny and turn the engine back upright.
#4542 |
#4543 |
Well I guess it's official. Ryan Falconer Racing Engines is packing up my head for shipping. This is for my 292. It's an aluminum cross flow head with 24 valves and 24 ports. It's been quite a journey. I hope this counts as working on the truck. I don't have anyone to tell.
#4544 | |
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
#4545 | |
Brian
#4546 |
Got home and did a real five minute a day plan job, (well maybe 10) cleaned up and painted these front motormount pieces. The rod you see them hanging on I made Sunday. Welded tabs on the ends and painted it so I could put it up in my side yard and it wouldn't look trashie. I needed somewhere to hang things like this when painted and this worked out well.
This was yesterday, let's see what I can get done today! ![]() Brian
#4547 |
I finished the cover plate for my transmission. I tapped the unused holes to bolt it in. I'm happy with it and certainly much more aerodynamic.
#4548 |
Very very nice looking truck. love the color!!
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#4549 |
My "five minute a day plan" today. I got the bracket removed for the spring and screwed into place testing the fit. Looks right on, I will weld that bracket to the hood reinforcement right there a bit higher than it was originally. I will put another fixed nut in the firewall to lower the hinge down. I didn't want to have to modify the inner fender as I had them powder coated. So this looks good, I can sleep tonight.
![]() Brian
#4550 |
I'm not real likely to punch it in the rain anyway. Last time I did that, the tires broke loose on the wet pavement, the back end came around, and I nearly put it in the ditch!
1951 Chevy Panel Truck Last edited by MiraclePieCo; 07-16-2020 at 05:31 AM. |
