Old 08-05-2020, 12:37 PM   #1
Astro-Balls
Astro-Balls's Avatar
Calculating Transmission plastic Gear
How to determine proper speedo gear?
Need to change out the transmission speedo cable drive gear. NP435
Just replaced the rear end to a 3:54 Eaton TruTrak and now speedo is off.
Tire size is P255/75 R16
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 08-05-2020, 12:52 PM   #2
MJN
MJN's Avatar
Re: Calculating Transmission plastic Gear
Check with the guys at transmissioncenter.net , they'll either have the correct gear or you'll need the ration adapter gearbox to correct your speedometer. They custom built one for me and its dead on.
https://transmissioncenter.net/?prod...edometer-gears
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 08-05-2020, 01:01 PM   #3
Astro-Balls
Thanks very much, Will Do.
Old 08-05-2020, 01:14 PM   #4
Boog
laying low
Boog's Avatar
https://www.tciauto.com/speedometer-gear-calculator
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-05-2020, 01:25 PM   #5
notsolo
notsolo's Avatar
Also need Color, or number of teeth on drive gear.
notsolo is offline   Reply With Quote
Old 08-05-2020, 06:03 PM   #6
my67c20
By a whole set and mix and match until you get close enough to a GPS. I tried the calculators and asking others and in the end it was trial and error and close enough. Of course my speedo cable snapped a few weeks ago, so not its anyones guess how fast i am going
my67c20 is offline   Reply With Quote
Old 08-05-2020, 06:33 PM   #7
kwmech
What ratio did you swap from?
Old 08-05-2020, 07:06 PM   #8
OregonNed
OregonNed's Avatar
I did this and got it right on the second speedo gear I tried.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-05-2020, 08:50 PM   #9
Astro-Balls
Previously had 4.56
Old 08-05-2020, 11:33 PM   #10
Boog
laying low
Boog's Avatar
ten
Mitch someone posted this a while back.
Boog
primer is finer
Old 08-07-2020, 02:42 AM   #11
Bob B.
Wait a minute, if you have a NP435, they DO NOT use the colored plastic gears that a Hydra-Matic and most GM manual transmissions use. This is not a GM manufactured transmission. NP435's have a drive (transmission output shaft) worm gear and a corresponding metal driven pinion gear/cable adapter assembly that must be changed in pairs together to get the proper ratio. Don't bother looking, they are all obsolete and there were DOZENS of combinations. Best way to correct for an axle ratio change is to use a mechanical ratio adapter gearbox as MJN pointed out and leave the existing drive and driven gears alone. They are available from several vendors, you provide them with information like how fast does the speedometer say you are going when you are actually going 60 (easy to verify with GPS). That way you will even correct for whatever tire size you are using.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 08-07-2020, 10:23 PM   #12
Astro-Balls
Thanks very much, I have contacted https://transmissioncenter.net/?prod...edometer-gears
awaiting response.
Old 09-25-2020, 11:47 AM   #13
Astro-Balls
Thanks, good info,
Do you know what vendors would carry a mechanical ratio adapter?
Old 09-25-2020, 12:04 PM   #14
geezer#99
geezer#99's Avatar
It’s right there in post #2.
https://transmissioncenter.net/home/
Old 09-25-2020, 07:04 PM   #15
Astro-Balls
Contacted them, No help.
Old 09-25-2020, 07:13 PM   #16
geezer#99
geezer#99's Avatar
One like this.
https://transmissioncenter.net/shop/...ratio-adapter/
Or they don’t have one for your transmission.
