Old 08-15-2019, 12:11 PM   #26
landarts
landarts
Re: is Tip and Flip cab dolly available?
Getting closer, was able to get the bottom and diagonal braces welded in. Also added the four bottom diagonal supports for the legs. Drilled the holes for the supports and started getting it ready for some paint. Second pictures shows the dimensions I used for the cart so that the cab will properly. I drilled the holes larger than needed to adjust for some wiggle room.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 08-18-2019, 05:24 PM   #27
landarts
landarts
Finally got it done and testing today with the K10 cab. Next I will need to test the tilt function. Really like the working heighth of the cab now and works well for my lower back issues.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 07-14-2020, 02:04 PM   #28
Patch
Patch's Avatar
I know this thread is a bit old, but how did it all turn out? Tip function work okay? I'm in the planning stages on building mine and like a few different ideas from each one I've seen.
Patch
Patch is offline   Reply With Quote
Old 07-14-2020, 02:22 PM   #29
landarts
landarts
It has been working great. the tip function of the cart has really worked out good. I am now getting geared up for phase two of the build on the cart. I am building additional implements to mount doors, fenders etc for body work and painting.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 07-20-2020, 07:36 PM   #30
Patch
Patch's Avatar
So I am going to go with the original tip & flip design and ordered my metal today. His plans show the wheels getting welded directly to the main frame. There's no reason why I can't weld a mounting plate to that frame so I can bolt and unbolt a wheel in case of failure is there?
Patch
Old 07-20-2020, 07:46 PM   #31
ThreeQuarter
ThreeQuarter's Avatar
I ended up using the casters he spec’ed, and I can’t remember if the bolt holes were wide enough to clear the width of the tubing they were welded to. Sorry, I can’t check mine because I sold it, but it would be something to verify before you bought/cut the flat metal for this. At worst you could tack the casters and grind them off in case of failure.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 07-21-2020, 01:59 AM   #32
gmc684x4
You could weld plates to the tube so you can bolt the caster wheels to yhe cart if tubing narrower then caster plate
gmc684x4 is offline   Reply With Quote
Old 07-22-2020, 10:30 AM   #33
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I have the metal cut for mine, need to start the welding process. why did you use rubber wheel casters? I would be hesitant because of the welding sparks blowing the tires. No problems?
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-22-2020, 02:06 PM   #34
landarts
landarts
I used pneumatic tires because I can wheel it to my side yard where there is gravel. If it was only staying in the garage on concrete I would gave used hard rubber. Welding sparks are not an issue, did all rust repair and grinding and it was not an issue.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 09-10-2020, 11:36 PM   #35
rx78nt1alex
rx78nt1alex's Avatar
Landarts, so do those mounting plates that the cab mounts to, are those removable, as it looks like they insert into the top of the dolly. If so, then making this into a dolly cart easy for the bed.
I’d like to roll the bed sideways to work on it.
1968 Chevrolet Fleetside C-10
1971 Chevrolet Fleetside C-10
rx78nt1alex is offline   Reply With Quote
Old 09-11-2020, 08:10 AM   #36
landarts
landarts
Yes they a removable. I have made a few other arms to go on it to hold doors, bedsides, fenders etc., next time I have it in that configuration I will post some pictures.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 10-16-2022, 10:34 AM   #37
indianpride77
indianpride77's Avatar
Did they happen to make these for the 73-87??
indianpride77 is offline   Reply With Quote
Old 10-16-2022, 11:29 AM   #38
Getter-Done
Getter-Done's Avatar
It would not be hard to make one if you have the tools and equipment.
Here is a thread with some dimensions.
Link: https://67-72chevytrucks.com/vboard/...ight=cab+dolly
84 Chevy K-20
