Old 09-16-2020, 06:19 PM   #26
mkmc69
mkmc69's Avatar
Re: 67 lwb w/ 292/3ott/OD and A/C
Originally Posted by 68bowtie View Post
It got another shot at life, like I had hoped. It’s changed hands at least twice since this thread, got cut down, and became a driver. It was listed locally recently by someone (not me), I saved a pic from the ad...
Attachment 2048610
At least it still lives on. Was hoping you still had it though. Need some reference pictures of what the kickdown switch and brackets look like for the OD.
mkmc69 is offline   Reply With Quote
Old 09-17-2020, 07:28 AM   #27
old51sedan
old51sedan's Avatar
I love this truck, but curious about the part number posted for the water pump pulley. Is this number 3906343 for a double pulley or the 3 grove like is on this truck? Either way I need one 2 or 3 grove. Thanks
old51sedan is offline   Reply With Quote
Old 10-13-2020, 10:30 AM   #28
old51sedan
old51sedan's Avatar
Here's a pic of the WP pulley setup. I'll get some part numbers next...
Attachment 1998271
Check it out!
Attachment 1998273
Here's a pic of the cable that goes from the 'T' handle down under the trans. Let me know if you want any other pictures.
Attachment 1998274
Appears to be a regular fan. I'm not sure on the shrouds, maybe someone else can chime in. I think certain options with the I-6 had a shroud instead of the little finger guard, but I'm not positive.
My truck came out of CA, had a 250/auto with the original smog pump mounted on drivers side of motor, I removed it and installed PS in it's place. It also has a 3 core radiator with a fan shroud, not the finger guard. I have since installed a 292,200-R4, PS and vintage air.
Old 10-14-2020, 12:25 AM   #29
'68OrangeSunshine
'68OrangeSunshine's Avatar
Old51 -- where did you source your 292 A/C bracket?
Old 10-15-2020, 08:30 AM   #30
old51sedan
old51sedan's Avatar
I bought the air conditioning kit from Vintage Air, they supplied it. You can see pictures of it on there web site. I believe they out source it from another company.
Old 10-15-2020, 12:31 PM   #31
'68OrangeSunshine
Thanks.
