Old 10-05-2020, 10:26 AM   #1
blazer2007
78 flipped rear shock brackets, better angle ?
I have a new 9 inch rearend coming with no shock mount pads welded on so was wondering if someone has a better idea for mounts. There is such a steep angle once you have shock the extended like with shock extenders. Is a 78 blazer with a flip and mild AOL air bags
blazer2007 is offline   Reply With Quote
Old 10-05-2020, 08:51 PM   #2
HAULIN' IT
Re: 78 flipped rear shock brackets, better angle ?
Not sure where/how you have your bags located, but I made brackets & mounting both of the shocks vertical behind the axle. Dont know if this could fit with what you have or not. Lorne
HAULIN' IT is offline   Reply With Quote
Old 10-05-2020, 09:01 PM   #3
blazer2007
Did you save any pictures ?
Old 10-05-2020, 10:37 PM   #4
HAULIN' IT
I haven't bothered/figured how to post photos since the whole Photobucket ransom mess.
If you go here:http://www.67-72chevytrucks.com/vboa...d.php?t=737307 You can see the lower brackets I made. For the top, I unbolted the original studs, made a large "washer" to support the movement simply drilled a hole in the frame near the top. Hope this helps! Lorne
Old 10-06-2020, 10:16 AM   #5
blazer2007
I was looking at those style of shock mounts. This is how mine looks, this is not mine, I believe is T.V. Blazers
Old 10-06-2020, 10:18 AM   #6
blazer2007
Does it matter on shock angle ? The straighter the better ?
Old 10-06-2020, 07:10 PM   #7
HAULIN' IT
Yep! There is some information on many shock/suspension manufacturers sites, ect. about how the angle from vertical effects the dampening.
If you look at the photo you posted, that shock is spending half of the suspension travel rotating around the bushing eyes. Wrong, wrong...wrongwrongwrong
Old 10-06-2020, 08:38 PM   #8
blazer2007
So your saying that is wrong,LOL That,s why I like your brackets. Looks like it might push it out some and see where It lands up. I will find info on shock angles and see what I need. Have to remove old rear and mock up new one. Thats why I like the 9 inch ,no weight. Thanks for the help, will keep a update thru the months. Hope is a good winter for this
Old 10-08-2020, 10:11 AM   #9
SCOTI
SCOTI's Avatar
Keeps the shocks between plumb & 30°. For your set-up that's similar to the pic above, fabbed lower shock brackets are the way to go.
Check this set-up out. 3rd page, starting @ post #56: http://67-72chevytrucks.com/vboard/s...d.php?t=808341
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-09-2020, 09:09 AM   #10
blazer2007
That,s Scotti ,that perfect, just have to find those brackets. I,d like to try and make some but I don,t own a plasma cutter or know anyone with one. Trouble is with this virus is getting hard to get stuff and in Can. is harder
Old 10-09-2020, 09:32 AM   #11
SCOTI
SCOTI's Avatar
https://www.bcfab.com/Rear-Shock-Mount-Kit_p_1109.html
Maybe these would work? Not sure on the overall length but they basic bracket is there & could be tweaked for length if needed.
Can Summit Racing get things through to Canada?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-09-2020, 09:39 AM   #12
blazer2007
Summit seems to be the best one ,I did look at the ones from BC fab hoping BC stood for British Columbia , my province but no. With the shipping rates and our low dollar gets expensive to cross the boarder , but will get some some how
Old 10-09-2020, 09:45 AM   #13
SCOTI
SCOTI's Avatar
I've never been involved in a transaction out of country. Can someone ship direct from US @ a lower cost? Or is it the same $$ & hassle?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-09-2020, 04:38 PM   #14
blazer2007
It,s sorta a hassle , even if you sent it me , you have to get it and then relabel it , go to the post office, pay for it or send it collect and I won,t ask anyone to do this. Thanks thou, your always so helpful and go out of your way to help. from other threads I,ve read like the 2 link arm one and then someone sheets on your effort . I,ll get it done, even If I have to make it outta wood, LOL. I,m sure there will be more questions as soon as I get the rear end back.
Old 10-09-2020, 05:07 PM   #15
SCOTI
SCOTI's Avatar
Just a thought. Wasn't sure what it would take.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-13-2020, 10:28 AM   #16
blazer2007
well BC fab was a fail 71.00 for shipping U.S. ,add 20-25 % for Can, dollar so about 123.00 to get them ,oh well.
