Old 10-11-2020, 04:57 PM   #26
Katrina/10
Katrina/10's Avatar
Re: Getting up the nerve to tackle A/C, need to remove the old
Nice fix on the box, I never heard of using super glue and baking soda.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 10-11-2020, 05:15 PM   #27
dmjlambert
dmjlambert's Avatar
I learned about it here on the forum. psuedopimp was wondering about fixing the broken off mounting ears of radiator shroud, and Grumpy old man gave a couple of youtube links to the super glue and baking soda trick. I have since used it on various plastic repairs and it is pretty incredible. It makes a super tough plastic. I recommend leave it to cure overnight. http://67-72chevytrucks.com/vboard/s...d.php?t=791986
Old 10-11-2020, 05:25 PM   #28
Katrina/10
Katrina/10's Avatar
That's interesting, I'll check it out!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 10-11-2020, 05:45 PM   #29
dmjlambert
dmjlambert's Avatar
Now the rust repairs. Original Air had already cleaned up and primed and painted but left the holes. I cut and bent some thin galvanized roof flashing to fit.
Old 10-11-2020, 05:50 PM   #30
dmjlambert
dmjlambert's Avatar
more
Name:  2020-10-04 17.34.37.jpg
The collection of patches
Name:  2020-10-04 17.35.15.jpg
JB Welded into place. I think this will last me another 50 years. I also replaced the fan with a new metal one from Manes.
Name:  2020-10-11 14.25.57.jpg
Name:  2020-10-11 14.26.03.jpg
Old 10-11-2020, 06:19 PM   #31
dmjlambert
dmjlambert's Avatar
Now the door. I scanned a picture of the original rubber material and printed it in actual size and cut a template. I then traced the template onto a rubber sheet and cut it out with an X-acto knife.
I was shopping online trying to figure out the best rubber sheet material to buy. My wife is a big time crafter so I asked if she had any. The answer was yes, a big ol' roll. It is magnetic on one side. For making signs, refrigerator magnets, etc. She uses it to hold steel cutting dies steady while running them through a press. Well, I wasn't terribly interested in the magnetic properties, and it is only weakly magnetic. But I tried it out on the door and it works great. I decided to put the magnetic side toward the door opening that goes to the heater core box, because when I am running the A/C I don't want any loss of air and I want to send all the air through the A/C evaporator.
I did some reading online and came to the conclusion the best glue for rubber sheet is super glue. You need to use just enough to glue it, and apply pressure while it sets. Since the area where it lives is recessed, I had to think about how I was going to clamp it down while it dried. I cut a few more of the same shape as the rubber, only this time with cardboard. So my plan was to glue the rubber sheet onto the door, and stack cardboard and then I would be able to press it down. I put a bag of fertilizer on it while it cured. I put the whole thing on some plastic wrap before gluing, and that kept it from gluing the whole door down to the table, in case I had some excess glue in some spots. I'm glad I did that, because yes I would have glued the whole thing to the table.
I am very pleased with the results. I hooked up the motor to a battery and flipped the door back and forth. It works great, and makes a very good seal and sends all the air to the A/C evaporator.
In the pictures below the metal door is painted a dark grey and is almost the same color as the rubber sheet. The rubber sheet is the one that has holes cut in it, so it fits down in the recessed areas of the door (the areas that were originally submerged in the liquid rubber back in 1969).
Old 10-11-2020, 07:00 PM   #32
dmjlambert
dmjlambert's Avatar
Original Air said if I sent the box back to them, they still would not take the rivets out, and they would make a thick closed cell foam seal and put it on the door. I did not want that, because if you have a look at how the evaporator housing is made, you can see all the air goes through a small opening. I measured the tunnel that all the air must pass through. 3-3/16 X 3-3/8 inches. I do not want that reduced by adding about 7/8 inch of foam just to make up for the door not closing all the way. Adding the door thickness, the width of the tunnel would be reduced to about 2-3/16. 30% air flow restriction, that is not something for me! I want the door to the heater core closing all the way shut and getting completely out of the way of all the air movement.
When the day comes for me to do the rsgt blower enhancement, I don't want any restriction of air flow.
Original Air did not really want the evaporator box back to work on it some more anyway. I showed them lots of pictures and explained my case, and told them I don't think the job was complete, they agreed it should not have left their shop in that condition. I suggested a partial refund, and was pleased that they agreed, and the check is in the mail supposedly.
So, I'm not completely unhappy with Original Air and I would do some business with them again. F.A.A.benny may be a better guy to send these evaporator boxes to. Whoever gets the job I do think expectations need to be understood in advance. Need to be clear on what complete disassembly means (that is a feature of Original Air's restoration they put on their website, and it was explained to me on the phone), make sure they aren't scared about drilling out just a few rivets, and a shop like theirs really needs to have rubber material on hand, or order some rubber off eBay if they need some. Of course, now that I have this much experience with this evaporator box, I think I would just do the next one myself.
Old 10-18-2020, 05:29 PM   #33
dmjlambert
dmjlambert's Avatar
These screw holes for the in-cab fiberglass heater core box were stripped out. They are for mounting the duct distribution/diverter box. After cleaning up the heater core box I did the super glue and baking soda trick again, this time to close up the screw holes. I ground the area flat and re-drilled them and tapped them using the original screws. Interesting that the head of one of the screws has concentric circles decoration and otherwise the screws are identical.
Old 03-26-2021, 11:00 PM   #34
dmjlambert
dmjlambert's Avatar
Moving on to the condenser. It is a parallel flow condenser and fits using the original condenser's mounting holes. It's really nice looking. The kit had 3 brackets that are good and the lower driver side bracket had the mount hole aligned straight down from the condenser side, so I had to make a bracket with an offset mount hole.
Old 03-26-2021, 11:07 PM   #35
dmjlambert
dmjlambert's Avatar
Mounted compressor and connected hoses. I found a local shop that crimped the ends on the hoses for $5 per hose. Then had it tested and charged up. I now have A/C going.
Old 03-27-2021, 11:40 AM   #36
Davidf
Originally Posted by Katrina/10 View Post
Usually the hinge is bad on the cable operated flapper causing the failure in diverting air from floor to dash.
On mine, I found that the heat/defrost flapper just needed a good cleaning and grease. Before, the lever would move the flapper and manual assistance was needed. Now that the old grease was cleaned and new applied (where position tang slides against inside of box) it works perfectly.
Davidf is offline   Reply With Quote
a/c, heater core
