Motor swap
Hey guys,
This is my first time swapping an engine and need some advice. I bought the mounts from some fab store off ebay. My question is that the motor looks like it's sitting very unlevel. I've looked all over the internet and cannot get a straight answer. Look at my pictures and tell me what you think! Any advice would be greatly appreciated! Last edited by Seth2789; 10-12-2020 at 09:00 PM. |
Re: Motor swap
Where’s the pics?
Re: Motor swap
Check it out!
![]() Join Date: Feb 2016
Re: Motor swap
Which direction are you concerned about side to side or forward to aft? Engines in our trucks always have the front of the engine higher than the back.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Re: Motor swap
Front to rear. It just seems like it's sitting very high in the front.
Re: Motor swap
That’s normal.
Carbed motors sit down at the back. About a 4 to 6 degree slope. Carb intakes are made so the carb sits level. Fuel injected motors also sit like that. Not as critical. Down in back gives lower trans tunnel needs as well as driveshaft angle not as severe. Put an angle finder on the tailshaft to see what it is. |
![]() Join Date: Mar 2003
Re: Motor swap
To me, it looks like the nose of the crank is sitting too high in relation to the engine in my truck. Wonder where the center of the water pump will be with the radiator
Re: Motor swap
Looks like it needs the trans mount on it to know for sure what the angle will be. Once you have a trans mount, then put an angle finder on it.
Re: Motor swap
Also looks like your upper A-arms are on the wrong sides.
72 C10 lwb fleetside -stock 350/350 combo |
Re: Motor swap
Good catch on the A arms. Looking close at the pics it appears his center link is in backwards also
Re: Motor swap
I can't tell for sure, but you may be right on that centerlink
Re: Motor swap
Man thanks so much for catching that. This is my first rebuild ever and I've learned a lot. Man I feel stupid for messing that up!
Re: Motor swap
Do the lower ones look right?
Re: Motor swap
#15 |
Re: Motor swap
The lower ones have to be right because of the shocks. What about the centerlink?
#16 |
Re: Motor swap
The tie rods have to come from the back so the castle nuts are forward. Meaning that the center part needs to be swapped from pitman to idler so the tapers come in from the rear
#17 |
Re: Motor swap
No reason for you to feel stupid, it happens to ALL of us
#18 | |
Re: Motor swap
Pay special attention to your drive line angle. |
#19 |
Re: Motor swap
Nominal GM tilt is 3 degrees. Some may have more, some less, but the pad on a q-jet intake is machined at 3 degrees.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
#20 |
![]() Join Date: Nov 2008
Re: Motor swap
Good advice so far. Put the trans mount in and then put an angle finder on it. Roughly between 3-5 degree. You can put shims under the transmission mount to lessen the angle if it comes out more severe once you measure it.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
#21 | |
Re: Motor swap
Some swap kits will tilt everything down more in order for the trans to clear the floorpan. Then leave you with the headache of working out driveline angles. I'm still working on my first C10 build, so I have no idea how much space there is to work with, but keep in mind there may be a limit to how much you can shim the trans up without hitting the floor pan (of course there also may be miles of room, I honestly don't know). Just something to consider if the cab isn't on the frame. |
