Speakers in doors
I am building a highly modified 66 C10. It is a Cgt. I am designing and installing a stereo system. Stock radio is getting converted and have couple of subs an amp and some 6.5's with tweeters. My original thought was to use retrosound kick panels to house the 6.5's but have been thinking alot of placing them in my uncut doors. I have seen our trucks with speakers and custom designed speaker grills in the doors and they look awesome. Just can't get my mind around cutting the doors. Any thought?
Re: Speakers in doors
dd
![]() Join Date: Jan 2011
Those grills look good. I have a nice set of doors for my 65 but I need to weld up the holes from some 6X9's. If you do put em in the doors roll bed liner material on the door skin. It really works good to keep the door from acting as a drum and improves the sound from the stereo.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I would go with the kick panels. That way they’re removable. Here’s a good write up on making your own:
https://67-72chevytrucks.com/vboard/...=Sonic+nirvana
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
If you do cut it, try to do it i one clean piece. That way you can save it to weld back in If you ever change your mind.
#6 | |
Moderator
![]() ![]() Join Date: Aug 2011
Or you could save your doors and put these in for the speakers - http://67-72chevytrucks.com/vboard/s...d.php?t=814630
#8 | |
https://67-72chevytrucks.com/vboard/...=kick+speakers The way I am thinking is most high end OEM audio use speakers in the doors. Going forward my truck will always have a stereo so I don't see a reason that I would have to weld up the holes. I have purchased an Audison amp and speakers and have an investment in it and want to make it sound as good as I can. The guy I bought my audio equipment from, felt the doors would be far superior for sound over the kicks in my application. This is where I'm at now. Plan to build a panel where the fuel tank once rested to house the sub woofers. The woofers will be as close to the cab corners as possible. In between the woofer boxes I plan to use as storage space as there is not much in these trucks. The 6.5" speakers will go near the front of the doors with a custom grill of my making and the small tweeters likely will go at the top of the kick panels just under the dash. I appreciate every ones input as I find sometimes just talking about a problem helps me come to conclusion. |
I'm curious. What is a CGT?
Acronym Definition CGT Capital Gains Tax CGT Carrera GT (Porsche) CGT California Guitar Trio (band) CGT Center for Globalization of Technology CGT Cellular and Gene Therapy CGT Computer Graphics Technology CGT Combinatorial Game Theory (mathematics) CGT Compensated Gross Tons (ship's capacity measure) CGT Carolina Gas Transmission (South Carolina) CGT Classic Golf Tours CGT Citibank Global Transfer (online service) CGT Code Generation Tool (computing) CGT Canadian General-Tower Limited (Canada) CGT Cummins Generator Technologies CGT City Game Tracker CGT Combustion Gas Turbine CGT Conventional Gait Training CGT Ceramide Glucosyltransferase CGT Church Growth Today CGT Certified Gastroenterology Technician CGT Communications Graphic Technology (certificate program) CGT Computer Generated Threat |
![]() Join Date: Jul 2009
Don't cut big holes in your unmolested doors. I used the kickpanel mounts and they worked out great.....
#11 | |
Moderator
x2
Active Member
![]() Join Date: Aug 2012
PLEASE, don't put speakers in your doors. JMO, never liked the idea of cutting holes. Kick panels are OK but most look like an add on.
Here is what we did in the '64 we're working on. We added speakers in the corners under the dash. Modified brackets from the dash speakers of a mid 80s square body They are only 3 1/2 inch Kicker speakers but hope they will work for now. Intend to add rear corner speakers after the fuel tank is relocated. Here are a couple of pictures. Last edited by spudder; 11-28-2020 at 06:36 PM. |
#15 |
![]() Join Date: Oct 2017
I have Kenwood 6x9 three ways in my doors done by previous owner. I put sound deadener around in the bottom of it and it actually kinda acts like a subwoofer box. Sounds great IMHO. If you are highly modifying your truck whats the difference in cutting into the doors. I also have low profile powered Kenwood sub under the seat. About to add another one under passenger for better thump. 4x6 center channel is next to round it out.
#16 |
FWIW, I installed custom made kick panels which accommodate a 5-1/4 2 way speaker. My doors were uncut, and couldn't convince myself to cut into them. I am very happy I did the kick panels, I even retained the full functionality of the vents. Additional 6-1/2 are in the rear cab corners with a 8" sub.
#17 |
![]() Join Date: Oct 2009
ah, CGT. I was wondering too.. It's only your acronym for your truck if you tell people what it means
![]() Your truck looks awesome by the way, very sharp build. I lean to the purist "don't cut it!" side of the fence pretty hard. With all the options for great sounding speakers that can be completely hidden without cutting the doors or making the kick panels look like a truck from Star Trek - in a small C10 cab, it sure seems that stealth, rather than flash, might be a very reasonable option - with all the quality sound one could ever need. My 2 cents only ![]() |
#18 |
I have to agree with the others...Brother, don't cut up your doors
#19 |
They cut long beds down to short beds & do it well enough that a person wouldn't know the difference unless told.
Dashes that are hacked can be easily repaired to stock appearance again. Rusted panels get replacement skins/patches all the time & you wouldn't be wiser on a painted truck unless the info is offered. It's freakin' metal. And, it's metal of a 'custom' truck. A custom truck as-in not a restoration or even a resto-mod truck. Cut the doors if you want speakers there. If @ some point you decide you don't want them in your doors any more, weld the holes back up & repaint that area of the door. It's been done once or twice..... @ least.
#20 |
Moderator
SCOTI your right. I just think it looks cheap and obvious.
#21 | |
I am including the link to my build so you can see what I have done. https://67-72chevytrucks.com/vboard/...=785046&page=5 |
#22 |
Possibly..... If it's a hack-job. As listed above, there are alternatives for grilles and coverings so that it CAN be tastefully done as well.
Poor execution usually yields poor results. The most common method (cut hole, drill outer perimeter for 4qty sheet-metal screws, install speakers, install standard black speaker grilles, put tools away because your done) would fall under cheap & obvious description IMHO. But, even that method of installation works just fine on a non-stock truck. A little extra effort can help w/that as well (symmetrical installation L&R, nice visual placement, better quality speaker grilles w/hidden fasteners, matching/contrasting paint, nostalgic or alternative coverings, etc). It really comes down to the end user of the vehicle & what works for them. Our/my opinion doesn't matter otherwise other than ideas & input to help w/their decisions.
#23 |
You really think the top option doesn’t look obvious? And that the bottom option looks cheap?
#24 |
The kick panel speaker set-up above looks 'cheap' vs. the in-door, color matched, retro looking speaker grille next to it. The 'retro' grille is sized correctly & follows contours of the lower door skin.
#25 |
Active Member
![]() Join Date: Aug 2015
PO of my truck had cut door panels to put speakers in them. Also had hacked up the dash for modifications. I just got done patching the dash and the the holes in the doors. Wouldn’t suggest cutting into either if it is unmolested. Don’t know how my PO brought himself to do it.
