Old 12-02-2020, 10:26 AM   #1
Tmend
Tmend's Avatar
73-87 wing/vent window
Question are 73-87 wing/vent windows same for trucks and blazers . Thanks much for help
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 12-02-2020, 10:33 AM   #2
TKCR
TKCR's Avatar
Re: 73-87 wing/vent window
They are, but not all the 73-87 are the same. I believe they went from 73-80 and then 81-87. And also not all 81-87 are the same. There is the 2 piece seal and 1 piece seal. Now this only comes into play if you plan on replacing your seals. You need to make sure you get the right ones for your vent windows. If you do a search on this forum for vent windows, you will probably get more correct info on these. I’m no expert, but that much I do know, just not certain on the year of the switch over.
TKCR is online now   Reply With Quote
Old 12-02-2020, 11:41 AM   #3
Tmend
Tmend's Avatar
Thanks for this info. Yes I’m looking for some for a 74 and a 79 k5 just want to make sure the ones from c series trucks will work.
Old 12-02-2020, 02:22 PM   #4
TKCR
TKCR's Avatar
They will as long as they are in the same year, or close. They did change just a hair, glass thickness and something else. But as long you stick close to those years, your good. And also, not sure if you know this. But you can always send them to Precision to be restored/rebuilt. I had my done from them. About a 2 week turnaround and they come back looking new.
Old 12-03-2020, 07:42 PM   #5
69Tom
69Tom's Avatar
Definitely a bit different, but all suck to rebuild.
69Tom is offline   Reply With Quote
Old 12-03-2020, 08:14 PM   #6
TKCR
TKCR's Avatar
That’s why I let Precision do mine. Let the experts do it, it was worth the money.
