Old 12-02-2020, 11:49 AM   #126
Green Monster
Green Monster's Avatar
Re: Headers to 2.5" Ramhorns
Thanks for digging that info up, Pete. I picked up a set of flat spark plug heat shields from ebay that, while not original, come with bolts (attached) that can get me by until I get correct bolts. I posted a picture of the tented heat shield you shared with me and I purchased two of so folks have a visual reference.
The last two photos are used stove and heat shield sets designed to work with the ram horn manifolds we have been referencing. There are slight differences in these sets (two tented shields vs one) and stoves with no holes vs two holes. I've seen plenty with one hole but from what information I gathered the stove with two holes was specific to CA trucks subject to CA emission standards. I could be wrong so please correct me if I am misleading folks here.
Green Monster is offline   Reply With Quote
Old 12-02-2020, 11:57 AM   #127
Green Monster
Are the spark plug wires routed around the sides and under the manifolds? My plug wire retainers are gone so I could use some direction on where these wires should be routed and what retainers should be used to work with ram horn manifolds. The attached photo seems to show two small spark plug retainers.
Where would these go? I presume these go somewhere halfway on each side since they hold only two wires each.
Old 12-02-2020, 04:09 PM   #128
DeadheadNM
Carpe manana
DeadheadNM's Avatar
If I'm reading the parts manual correctly, there are three examples each w a different part numbers for 71-72 small blocks: 3919807 left front, 3917664 right rear, and 3817657 left rear and right front. I'll edit this post later w photos that illustrate each.
I've not been able to locate a p/n for the heat stove. Definitely, the CA emission trucks used the two-hole version. It seem though that there are more two-hole versions floating around fwiw. I suspect the two-hole design was also used on at least some non-CA emission motors. I'll look through my base line photos of the 350 that's now in my K20 to see what it had. This engine came totally complete from a running survivor K20 Suburban w ~50k miles on it. Also, I'm wondering how well the repro vette pieces will fit since I believe these are designed for 2.5" outputs rather than the 2" for K trucks.
EDIT: Engine photos here. Not best angle but stove appears to lack the holes http://67-72chevytrucks.com/vboard/s...7&postcount=20
Mine are off in winter storage. I need a separate garage.
Plug wire routing is a great topic that I need to know more about. I'm thinking there may be existing threads on the specific topic we can dig up and bring to life.
Old 12-06-2020, 08:44 AM   #129
Green Monster
Great info and the photo is a really nice reference to see what else is missing and where it should go, thank you.
The repo ram horn exhaust manifold a I picked up are 2.5” straight dumps (probably cast from trimmed Corvette manifolds). I'm curious how they will fit too.
Old 12-06-2020, 09:48 AM   #130
jaros44sr
jaros44sr's Avatar
Here's a pic of how I mounted mine, I used a stud for ease of mounting the 2 pieces of shield and spark plug wire mount, but the mount for wires will only fit 7 mm wires, plus being bare metal leaves a lot to be desired, you could plastic dip them
WIN_20160921_10_03_04_Pro by [url=https://www.flickr.com/photos/97391199@N06
Went through all my pics, and this is the only one I have of that area, the wires come straight down from the spark plugs to the clips you have shown, then to the clips on the oil pan clips, and then up to the brackets on the block by the distributor
I'm pretty sure the corvette wires are 7 mm,IIRC
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 12-07-2020, 07:23 PM   #131
Green Monster
Thanks for providing a photo and explaining. This might be an obvious answer but what are U shaped washers(?) behind the manifold bolts designed for? I don't have them. Are they necessary?
Old 12-08-2020, 08:56 AM   #132
jaros44sr
jaros44sr's Avatar
Imho, they are the best way of preventing the exhaust manifold mounting bolts from getting loose( OEM )
Usually, you would run 2 or 3 heat cycles, then bend the small tabs over, locking the bolts in place
SAFETY FIRST
AS usual, off topic
Jim
Old 12-08-2020, 10:30 PM   #133
Green Monster
Ahhh... I see the tabs now. Makes sense. Thanks!
Old 12-10-2020, 08:25 AM   #134
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Corvette parts suppliers like Zip carry those French locks for the manifolds.
Old 12-10-2020, 12:54 PM   #135
Green Monster
Found them, thanks Pete.
https://www.zip-corvette.com/66-80-3...stainless.html
Good you sent me there- I noticed something about the exhaust manifolds when comparing them to the set I purchased.
Zip-Corvette shows exhaust manifolds that have the correct raised flat fins on top while the set I purchased from Assault Racing do not. The set from Assault appears to have had a lot of material removed from the outside and have been smoothed. Not sure what effect this will have long term (cracking) or if the stove assembly will fit properly on the Assault manifold.
Old 12-10-2020, 01:02 PM   #136
Green Monster
There are so many choices... which are the right ones for our trucks?
https://www.zip-corvette.com/68-82-c...manifolds.html
Old 12-10-2020, 03:50 PM   #137
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You bet. The Corvette suppliers carry a lot of overlapping parts and I wish I had gone to these sources years sooner.
To me, the image depicts a combo of repro and GM manifolds. The example in the upper left corner looks correct for both sides for a non-AIR engine. I believe pickups had a 2" outlet. A quick search should turn up the correct p/n's for the manifolds.
Old 02-18-2024, 09:25 AM   #138
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Headers to 2.5" Ramhorns
Originally Posted by DeadheadNM View Post
I believe the parts manual lists two p/n's for the heat shields for at least 71-72 FWIW. I have both in NOS form on my Blazer and believe the flat examples were all notched and had the same part number, which differed from that for the LH anterior head. I'd have to revisit the parts manual to confirm. These shields were certainly used for other SBC applications and as such are sort of generic rather than C/K or K5 specific.
What I'm struggling to remember is the style that's located on the RH rear head and favor the "tented" design to clear the send unit for the TCS system. Here's an example set presumably correct: http://67-72chevytrucks.com/vboard/s...56&postcount=1
Old thread but good info nonetheless.
I just replaced the wire heat shields on my 1970 Blazer 350, and it used two 3919807 "tented" shields with the hole for clearance of the temp switch/sensor. One of those is the RH rear position and the hole is for the TCS high temp switch, and the other is LH front for the temp switch/sensor for the temp light or gauge depending on optional equipment. This is contrary to all of the GM parts books which state that the 3919807 shield is solely for the LH front position. Both front shield positions have the separate small steel two wire looms 3744408 for proper spark plug wire retention. The other two "flat" shields used on my application are 3817657 or 3917663, which fit the LH rear and RH front.
3817657/3917663:
3919807:
3744408:
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
