01-07-2021, 11:15 PM | #1 |
Junior Member
To wet sand or not.
I’ve been really wanting to wet sand the C10. The truck has an old paint job and the clear coat is hideous. I did a small spot tonight on the fender and it shined up really nice, plus made the clear look way better. The only catch is that the former owner had pinstripes put on by Art Himsl back in the 90s and its on top of the clear coat. I tried a small spot to see what would happen and it came off super easy with the 3000. Obviously I would love to just repaint the truck and get the pinstripe redone, but with two small kids and limited funds, that’s not really an option right now.
Should go for the wet sand and sacrifice the pinstripe? Any ideas that might allow to keep the pinstripe? Last edited by 71step35035012C10S; 01-07-2021 at 11:22 PM. |
01-08-2021, 12:11 AM | #2 |
Re: To wet sand or not.
It’s hard to see what you sanded, and what the difference is.
Being on a budget, I’d loose the pinstripes And make it look as presentable as possible Whatever technique you use. Looks like a nice truck !! |
01-08-2021, 12:12 AM | #3 |
Oh yeah
Please post a picture of the spid Thanks |
01-08-2021, 07:02 AM | #4 |
Sand and buff, l wouldn’t be concerned about the pinstripes
71 C10 72 K20 72 K10 Super Kirk |
01-08-2021, 07:22 AM | #5 |
Sand and buff.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
01-08-2021, 07:45 AM | #6 |
Can you put tape over the stripe and avoid just the striping but all the rest or will it be too obvious?
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
01-08-2021, 08:38 AM | #7 |
If I had the elbow grease handy and the time, I would polish the brightworks, but that's not your questions (by the time you freshen up the paint you'll be inclined to do that too)...lightly wet sand the hideous areas, blend those areas in with the rest with a good buffing, and then wax it. You might loose some pinstriping, but your truck already has a great lived-in look to the finish. Start with the open and free-of-pin-stripe-areas and work into the stripes. By the time you get to the striped areas, you will have learned how to finesse the finish and just might be able to pull it off. If it does not work out for the stripes...you have your answer by default. You might even end up with some ghost stripes...that could be cool too!
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
01-08-2021, 10:41 AM | #8 | |
My only additional thought is that you could just tape a large band around the pin stripes and deal with the failing clear coat around the pin stripe if they're that important to you. At least takes photos to document the pinstripe thoroughly before you go anywhere near it. Art's work is legendary, you might as well take a photographic record of it in case you lose it in the future, through your fault or someone else's, God forbid.
1968 GMC C2500 Long Bed Fleetside |
01-08-2021, 12:04 PM | #9 |
I don’t think this is a candidate for buffing ?
That works on single stage paint But I think on a gloss clear paint job, the color coat underneath will not shine You might need to clear coat the thing after you sand off the old clear Just a thought, I’ve never been able to make patina’d gloss clear look that good More pics please..... ......spid |
01-08-2021, 01:43 PM | #10 |
There are a couple of factors at play here.
1. Your clearcoat is failing in some places. There isn't a way to "correct" that short of new paint. You can sand it out, just realize that what you're left with is essentially a single stage at that point as you'll have no protective clear where you've removed the failed clear. Just trying to ensure you don't have too high expectations. I've had people come to me with similar paint to correct and I usually talk them out of spending the money . 2. Start with the least aggressive methods and then go more aggressive if you're not getting the results you want. 3. Not really a good way to keep the pinstripes AND correct the paint under/behind it. That's why you generally want to have the art done after base, before clear. If the stripes were spaced out more you might be able to get in there with a 1". At this point you're talking about having to use a dremel with tiny polishing tips if you really want to keep the stripes. At this point you might be ahead to wait, save up $500-1k for even a cheap Maaco job, and then spend the elbow grease wet-sanding and correcting that job. Even a cheap single stage is going to provide more protection than what you likely have now. |
01-08-2021, 02:53 PM | #11 |
Just took time to look at the first pic, that’s kind of a mess. Better get Maaco
01-08-2021, 04:12 PM | #12 | |
That's what I'd do if a full paint job is not desired. Clean it up some, try to save the pin striping, wax it to help preserve it until new paint is an option and look good cool all the while!
01-08-2021, 04:28 PM | #13 |
I'd get two car seats and ride.
Scott |
01-08-2021, 06:33 PM | #14 |
Most base coats have no uv blockers . I say most because sometimes clear is painted over a single stage paint. Once the base is exposed to uv it goes fairly quickly so anything you do is just a bandaid .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
01-08-2021, 08:58 PM | #15 | |
Junior Member
I wouldn’t be so hard up on keeping the pinstripe if it wasn’t Art Himsl. Who doesn’t love a new paint job, but I also appreciate the patina/ “lived-in” look and not opposed to go in that direction. If that was the case I’d keep the pinstripe for sure and clear coat the whole truck as is. Plus, I’d really like to keep the ability to actually use my truck and have it look pretty cool too and I know a new paint job is going to deter me from haphazardly chucking objects in the bed or letting my boys climb on the stepside etc. I went digging around and found out today the original owner of this truck operated a welding shop next door to Art’s in Concord, CA. Putting that with SPID. I’m guessing he went to Art about redoing the factory stripe after the repaint and Art talked him into more. Last edited by 71step35035012C10S; 01-08-2021 at 09:06 PM. |
01-08-2021, 10:59 PM | #16 |
Very Nice truck
And pretty rare Good luck, which ever way you go If you ever end up in the north bay ( Sonoma) Hit me up |
01-08-2021, 11:06 PM | #17 | |
Junior Member
Your absolutely right. I’ve never had so many women comment on a vehicle until I started driving the truck. |
01-08-2021, 11:11 PM | #18 |
BlahBlahBlah
Id take what ever piece it is that you showed the striping with Himsl's sig (hood?) and use if for wall art. Then do whatever it takes to make the truck the truck you actually want.
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
01-08-2021, 11:54 PM | #19 |
I don’t know if this helps, but I had an old motorcycle gas tank that was in similar shape as your paint. I wanted to retain the original pinstripes and esthetic of the worn stripes, so I taped them and then sanded and puttied where I needed to, then I sprayed with some flat black and then finished it with 2k clear which you can buy in a can. I think it works well. If i was going for a straight patina look, I may have just sanded the clear coat and sprayed with 2k clear, but had a lot of scratched and putting to do. It sprays a really fine nice mist.
01-09-2021, 02:53 AM | #20 | |
Junior Member
01-13-2021, 11:56 AM | #21 |
Junior Member
I went through and did the passenger side. I had to go down to #600 to get the clear smooth. Im wondering if I need to remove all the clear coat or can I clear over what’s here and polish/buff.
01-13-2021, 12:56 PM | #22 |
You need to get rid of the failing layer before painting over it. Your bond to the body is only going to be as strong as the weakest layer. So putting paint over a layer that is warping/pulling away is going to be a short-lived success in my opinion.
01-13-2021, 01:18 PM | #23 |
Junior Member
Agreed. Is it possible to just knock down the failing layer of clear to a point where it is smooth and will adhere?
