12-11-2020, 02:35 PM | #126 | |
Re: The build date project
Reading some suggestions above, especially dates, you might consider a different format. Don't get me wrong, this effort by the two is outstanding, I'm reminded of the effort put into indexing the assembly manual, all we had to do was number 500+ pages
Perhaps this is a usable format. You can sort by any column and I think easier to manager by the task force. Edited: Date (zero=no day): March 0, 1971 Factory: Fremont71 (the reason for the year is for sorting - I like how you guy's separate factory & year & this will do that. See example below if interested.) Year: 1971 Perhaps redundant if year is added to factory, but strikes me valuable as a sort option) Chevy/GMC (gay man's chevy): Chevy, Suburban etc. (See post 119, might be better to add Suburban, Blazers as a note or as another column to sort by, e.g. "Other"). Vin: Zxxxxxx (Not sure you need "Z" but it sorts anyway). Notes: 71Chevy402 is a bum Flint70 Flint71 Flint72 Fremont70 Fremont71 Fremont72 On a side, if using Excel for example, the shorter the better. Sometimes it's necessary to put columns between columns to paste right, using symbols. For example: 01/01/1970...Fremont70...1970...Chevy...Z123456...Blank*...71Chevy402 is a bum. *Blank is a spot for Suburban and that, because blanks will throw off your paste. N/A maybe, but it's not as if you're registering every type. Edited again, cough). The list of your factories/years and that is a nice placeholder so to speak, but I wouldn't add them to your chart until a truck comes up. Just some suggestions, I'm a bum but long edgeucation in data structure & reports was enough to be happy to leave, with CDO and perhaps PTSD too, them (*&(*)&^ are crazy especially meetings. Quote:
We need a forensic to pipe in, there's got to be a chemical some sort.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-11-2020 at 04:12 PM. |
12-11-2020, 04:28 PM | #127 | |
I'm wondering if there are multiple layers of your sticker that maybe could be separated at the "date" corner. Perhaps the clear (that's no so clear now) top layer could be separated enough to reveal the next layer? It sorta looks like the layers became separated in that corner in your pics. Perhaps this could risk more damage than it's worth, so proceed with caution if you decide to do this at all. And I agree, it looks like a 3. |
12-11-2020, 06:15 PM | #128 | |
PM sent Last edited by geunther; 12-11-2020 at 06:23 PM. |
12-11-2020, 07:11 PM | #129 |
All about them K’s
That’s what it looks like to me as well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
12-11-2020, 08:12 PM | #130 |
My 72 C10:
A149453 With my truck being an Atlanta built truck and member Pro299 truck being an Atlanta truck built 3/72, I would assume mine could possibly also have a build date of 3/72. |
12-11-2020, 09:23 PM | #131 | |
Just touching it some flaked off.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-11-2020 at 10:06 PM. |
12-13-2020, 08:28 PM | #132 |
This sticker is on a door I bought recently from a classic car wrecking yard just a few miles up the road from where I live. The date looks like 2/71 and the last six digits of the VIN look like 625107. Can't see the rest. Seems likely it is a Fremont truck.
12-13-2020, 08:43 PM | #133 |
Does it have the metal vin on the driver door jamb or the SPID on the glove box you could verify the last 8 of VIN?
12-13-2020, 08:44 PM | #134 |
12-13-2020, 08:48 PM | #135 | |
From post 2: 1Z624290 = 1/27/71 (Build Sheet)
1971 SWB step side: Original NM Forestry and then NM Fire truck Last edited by Carl Spangler; 12-13-2020 at 09:34 PM. |
12-13-2020, 08:54 PM | #136 |
Here's the build sheet from a 72 Cheyenne Super I used to own.
CCE142Z148035 09 03-06-72 |
12-14-2020, 12:12 AM | #137 | |
All about them K’s
Tonight I Added some pm’d info as well as what has been posted up in the last few days. I’ve got a little more pm’d stuff to add in the coming days. Thanks everyone!
12-14-2020, 01:26 PM | #138 | |
If a five day work week that factory punched out 450ish trucks per day at the time.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-21-2020, 10:40 AM | #139 | |
You'd have to know the specifics surrounding the timeframe you are studying - or - feed the information back in based on an activity like you are constructing here. Basically - Flint (Line 1) and Fremont were your high volume plants, typically around 60 jobs per hour. St Louis and the other plants were typically a little slower, like 45 jph; Flint Line 2 was normally around 36 jph. Fremont passenger car side (and Pontiac Motor Division, passenger cars) could be as high as 70 jph and three production shifts - but trucks would not run three shifts as far as I know. So - on the low end, at 60 per hour, you might have 60 jph x 8 hours = 480 trucks per day for one production shift. More typical might be 60 jph x 8 x 2 = 960 for two production shifts. Wide open throttle would be 60 x 10 x 2 = 1200 units for two 10 hour production shifts. Similarly - at St Louis, you might have 45 jph x 8 = 360 trucks per day for one 8 hour shift; 45 x 8 x 2 = 720 per day for two 8 hour shifts; wide open would be 45 x 10 x 2 = 900 for two 10 hour shifts. *scheduled overtime is just that: you know going in your are going to be working 9 hours, or 10 hours (ish). On the other hand, you might be scheduled to work 8 hours but, if you've had a particularly bad day due to repair or mechanical breakdowns, plant management might make the call to run a bit longer in order to recover some of that lost production. The production office would dictate the new hours (ie, 8.2, or 8.5 hours) and the new stop time would be communicated up and down the assembly line, both officially by phone but also more rapidly via the rumor mill. And - it varies based on location within the assembly plant. So while final line might go 8.2 hours, body shop/paint might go 8.5 or 9 hours in order to fill all the buffers. The goal is to always keep the final line running. Feeder lines and upstream activities can stop for a while as long as there is enough product in the buffers to keep the final line going. If the final line stops - that's when you are going to see some excitement.
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-21-2020 at 10:49 AM. |
12-21-2020, 11:48 AM | #140 |
All about them K’s
Thanks a ton Keith, that is very valuable info for this project and gives us at least a rough idea of what we can likely expect. We’ve got enough in right now that we can get a really good estimate of some days or months, I hope to see that trend continue.
12-27-2020, 04:37 PM | #141 |
I have an update to the build info for my 1971 stepside SWB C10. I was shocked to find the very tattered build sheet still under the seat.
1Z622515. build sheet date of 01-21-71. This truck was shipped to Santa Fe Motor Company at 418 Cerrillios Rd Santa Fe NM. It originally went into forest service use and then was transferred to a volunteer FD in a small NM town. I purchased the truck from the volunteer FD guy.
1971 SWB step side: Original NM Forestry and then NM Fire truck Last edited by Carl Spangler; 12-27-2020 at 07:50 PM. |
12-28-2020, 12:17 AM | #142 | |
12-29-2020, 09:25 AM | #143 | |
All about them K’s
01-13-2021, 01:04 AM | #144 |
70 chevy
0z155555 4/13/70 Last edited by 402Bowtie; 01-13-2021 at 01:11 AM. |
01-13-2021, 01:31 AM | #145 |
Hope this helps. side note: notice the engine I.D. tag 202 hanging off the exhaust bolt matches the build sheet.
01-13-2021, 09:30 AM | #146 |
All about them K’s
I’ll get them added. I’ve got another I found in person to add as well.
Arctic man, that’s a pretty sweet find with the engine tag.
01-14-2021, 06:01 PM | #147 |
From BAT:
1970 CST/10 longbed Chevy. CE140Z155555. with a build sheet date of 04/13/70
1971 SWB step side: Original NM Forestry and then NM Fire truck |
01-14-2021, 06:22 PM | #148 |
Ahhhhhh, I only posted it because it wasn't in the first page list(s).
01-14-2021, 07:01 PM | #149 |
All about them K’s
Sorry guys I’m a little behind. Been a busy few weeks. I will get them updated this weekend. I’ve got a few pmd updates that i will post up at the same time.
01-15-2021, 06:08 PM | #150 |
1967 gmc
ce2590dzc1502b 07-11-1967
1967 GMC 3/4 ton custom. 283 4 speed unrestored |
