12-23-2020, 04:37 PM | #126 | |
low n' slo
Re: Doing LS Swap - I have no idea what I'm doing!
to the op, ive even read around on some people sectioning their stock pan for clearance. now, im not sure how much oil capacity is lost, and what else is involved...but it sounds like definitely a possibility.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-23-2020, 05:34 PM | #127 |
Found this one while reading through some threads...
https://www.speed-engineering.com/ls...2-ls3-ls6.html
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
12-23-2020, 06:23 PM | #128 |
I used the stock pan that was already on my Fbody engine and some simple 34 dollar motor mounts and it seems to fit almost perfect.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
12-23-2020, 06:43 PM | #129 |
low n' slo
muscle car pan kit from ebay?
https://www.ebay.com/itm/284031805242 that one u posted seems like it would work. 6" total height, believe the truck pan is 8"?
12-23-2020, 06:52 PM | #130 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
12-24-2020, 12:06 AM | #131 |
Spend the extra bucks and buy the Holley pan. Made in the USA.
12-24-2020, 01:13 AM | #132 | ||
On a side note - how long have you lived in KC area? I hid out in the basement of the Independence mall once during a tornado warning. I lived in KC for a few months around 2005 or so. I have an uncle that lives up there, in Lee's Summit. He does a lot of car shows/stuff around there, I believe. He has my great-grandfather's '66 Apache and a green T-Bucket that is Buick powered.
12-24-2020, 04:58 AM | #133 |
Yeah, no they're not! They are made in China, at least the one I had said it was. I was kind of bummed out about that. Its not something Holley specifically mentions, I wonder why?? LOL
12-24-2020, 05:00 AM | #134 | |
12-24-2020, 07:45 AM | #135 |
I believe over on ls1 tech truck doug mentioned a felabay knock off pan he picked up cheap recently with similar dimensions to the holley pan and was pleased with fit and finish.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
01-04-2021, 12:07 AM | #136 |
EagleChief,
Read thru the whole post. Sounds like you did some great research and have gotten a bunch of great ideas and help. One question, would you be willing to tell me where you got the engine/trans from? I'm not to far from Tulsa and am looking for a place to pick up one. Thanks.
Somehow, the idiots survive despite their best efforts to kill themselves. - dcozzi |
01-04-2021, 02:08 AM | #137 | |
I've been through Jennings a few times over the years. Mostly on my way to Stillwater when I was in school, and I didn't want to pay the tolls.
01-04-2021, 02:19 AM | #138 |
Guess I should give a small update... I went ahead and mounted the driver side adapter plate and mount, just to make sure they would work - they do. I think I did that right before Christmas. But, since then, it's been a crazy, non-stop whirlwind of a time. Did all the Christmas stuff starting Christmas Eve, and it lasted for 4 days - seeing all the family.
Then, on the 29th, we had our baby girl at 8:30 in the morning! Spent a few days in the hospital, came home, and now we're trying to get as much sleep as possible, when we can. I'm typing this now, as I'm getting her to fall back to sleep so I can go to bed. So, things may slow down for a little while. I'm at home this week, but then it'll be back to work and then trying to relieve my wife of all the motherly duties in the evenings. So, you guys will have to bear with me and hopefully I can still knock some stuff out every once in a while.
01-12-2021, 12:54 AM | #139 | |
I did go ahead and pull the a/c compressor and bracket off. It'll be quite a while before I try and tackle the a/c on this truck. It's not a huge concern for me, although would be a nice luxury. I got the adapter plates mounted to the block, and the engine mounts mounted on the plates. I also went ahead and pulled the exhaust manifolds off. Only 4 broken bolts that I can tell. 3 of them were already broke below the surface, 1 broke off on me at the head as I started to take it out, with hardly any pressure. So, I'll work on getting them out next.
01-12-2021, 09:24 AM | #140 |
AGH! I had some broken bolts in my 317 heads and was able to extract them. I hate extractors and gadgets that only break off on the hole you drilled and make it even harder to get them out. I drilled a small hole in them very carefully making it very straight. I pounded a hex wrench into the hole. I did my best to heat the surrounding area of the head and the bolts came right out. Pounding the hex key in does two things. It "shocks" the threads and provides a means of attachment to the bolt. I used a very high quality hex key so it would not break. It was the first time I tried this method and the first time I did not have to pay a machinist. Go to post 21 here https://67-72chevytrucks.com/vboard/...d.php?t=808928
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 01-12-2021 at 09:33 AM. |
01-12-2021, 09:51 AM | #141 |
If you are using a slider type mount you can slide the engine forward enough to make the compressor fit. It wasn't that much. If your going to use a factory compressor put the bracket on now. It's difficult to get to one of the bolts without jacking up the engine. If your going with a Vintage Air type unit don't put the bracket on now. I have an F-Body pan. I don't know with the pan you are using if this is an option.
01-12-2021, 12:12 PM | #142 | |
I mocked up the compressor bracket with the mounts in place. Marked the area that will have to get cut/trimmed out in order to fit the a/c in the stock position. I might trim it out to see if it'll work. But, I'm not too worried about having the a/c hooked up. There's a lot of other stuff that has to be done in order for it to work. Mounting it is the least of my worries about that. The pan in the kit I ordered is pretty much a copy of the Holley low profile pans that are offered. The dimensions are almost an exact copy.
01-12-2021, 04:18 PM | #143 |
low n' slo
sure that pan will work nice. i may have missed it, but are you drilling the temp sender out for the c10 ones?
01-12-2021, 11:32 PM | #144 |
I haven't made it that far in the process. I know I've read about doing that, but I'm not really sure what I'm going to do, yet. I know it can be drilled for a sender unit, but I have also read about an adapter that will work. I'd just have to find the thread again to see if the long term results were good.
01-12-2021, 11:58 PM | #145 |
low n' slo
there also was someone here in the forum taking the stock ones and machining the threads to fit the LS. not sure if he makes them anymore
01-13-2021, 09:06 AM | #146 |
As far as I've ever seen, there isn't an exact match for any other sender for a factory 67-72 temp gauge. There are some that are close, but generally only in a specific range. Depends on how important an accurate gauge is to you.
As for the machining down factory senders, that can only be done on newer trucks that originally had a much smaller sender to start with. If you try and do it with a 67-72 sender, you will hit the guts of it before you have it machined down far enough.
01-13-2021, 12:26 PM | #147 | |
low n' slo
01-20-2021, 02:37 PM | #148 |
Got my Speed Engineering oil pan kit today! Actually, it showed up on Monday to my office, but I was home sick. So, there's that. Anyway. Unboxing it, it looks good to me - no more than what I know about this stuff. Now, just find some time to get it on the motor, then I can drop it in the truck. Right?
I have gone through and removed the wiring harness. I just need to figure out whether I want to attempt to strip it down myself, or buy a harness that's ready to go. The majority of my internal debate, says to buy one ready to go. I really don't have the time to pull apart a harness, especially for a first time. The other part, says to save the money and do it - although it will take me all year to do it. I pulled the exhaust manifolds off - still have to pull the sheared bolts out. Then need to find replacement manifolds or headers. What else do I need to do before I drop it in the truck?
01-20-2021, 05:40 PM | #149 |
I not a electrical wizard so I buy a pre-made harness. I purchase the harness and computer from one supplier. They will mod the computer as needed. I like Howell and Speartech. Used both a number of times.
01-25-2021, 02:15 PM | #150 |
I'm not an electrical wizard either. That's one reason I'm leaning toward buying a pre-made harness. I just can't fathom the thought of spending $600-$1000 (depending on set-up) on a wiring harness. I see some advertised for anywhere around $250-$300 on FB and Ebay all the time. Anything wrong with those?
