Old 12-22-2020, 01:52 PM   #426
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC Project
Originally Posted by 1971Stepside View Post
You have came this far. Re-section the floor and make it perfect. You sound like me and if that is the case it will drive you nuts to do anything but the right thing....you are just way more patient than I am and a better welder, a better grinder, and better rust repair guy
Haha thanks man! Your right, I dont think I'd be happy with anything else.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 12-23-2020, 11:57 PM   #427
Kronald_70GMC
Well I did it again guys. More splicing..... I think I might have to call this truck "Splice" soon. I hope all this splicing turns out alright in the end. Its starting to look a little ridiculous.
Kyle
IG: kyle_ronald
Old 12-24-2020, 11:31 AM   #428
TA_C10
TA_C10's Avatar
You might as well just cut the cab in half and extend it 4" for more room while you're at it.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 12-24-2020, 12:08 PM   #429
Kronald_70GMC
at this point it would probably have somehow made this easier
Kyle
IG: kyle_ronald
Old 12-30-2020, 02:47 AM   #430
Scurry67
Metal work is looking great man. Are you waiting to have all the metal work done before spraying your primer?
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 12-30-2020, 01:30 PM   #431
Kronald_70GMC
Thanks! I will probably prime areas as I finish them. I think ill do half the cab once it is ready and the other half later.
Kyle
IG: kyle_ronald
Old 01-07-2021, 12:39 AM   #432
Kronald_70GMC
Well its not alot of progress but I have one of the splices welded up and ground down. I dont have any play by play pictures, just the finished one. I mean it is probably a good thing, you guys must be sick of seeing the same thing over and over. Also happy new year to all!
Kyle
IG: kyle_ronald
Old 01-13-2021, 11:23 PM   #433
Kronald_70GMC
Some more welding down on the rocker repair. Im really starting to get a lot more confident in my welding skills.
Kyle
IG: kyle_ronald
Old 01-21-2021, 05:18 PM   #434
Kronald_70GMC
Well it seems that every time I have a day set to get out into the shop, it just doesn't work out. So progress has been slow for sure but I promise there is a reason. Life is going to change come May so I have really been busy in the house getting the rest of the renovations done in the bedrooms. I went a little over the top painting in the baby's room but it turned out awesome! I have saturday set aside though so I can get back on track. If all goes to plan, the passenger rocker will finally be welded in by the end of the day.
Kyle
IG: kyle_ronald
Old 01-23-2021, 11:33 PM   #435
Kronald_70GMC
Well I should have known by now. I was out in the shop most of the day but did not make it as far as I hoped due to another issue. I noticed that the floor just up from the inner rocker had a 1/4" bow when compared to the top lip of the rocker. I went back and forth on wether it would be a real problem or not and in the end I decided that I would be pretty choked if I had it all done and you could see a hump on the sill plate. So out came the grinder and another Splice was made. It seems that name is going to stick. So after all evening of welding and grinding, the inner rocker is ready to accept the outer!
Kyle
IG: kyle_ronald
Old 01-24-2021, 04:32 PM   #436
TA_C10
TA_C10's Avatar
Nice work on that room! And the c10 of course
"It's only money".
Old 01-24-2021, 08:21 PM   #437
Kronald_70GMC
Thanks man! I just finished up baseboards in the room today. Now we just have to fill it up with furniture. As for the truck, the rocker should be installed Wednesday evening.
Kyle
IG: kyle_ronald
Old 01-24-2021, 10:53 PM   #438
72 tigger
72 tigger's Avatar
Nice work on everything!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 01-24-2021, 10:55 PM   #439
Kronald_70GMC
Thank you!
Kyle
IG: kyle_ronald
Old 01-27-2021, 04:47 PM   #440
Kronald_70GMC
Well would you look at that. I managed to sneak out in the shop last night and finish the prep on the rocker. I didn't like the way they made the front of the rocker with the lapped metal and large hole which is extremely in accessible so I cut that all up and welded it in nice and flush. The only thing left to do before I weld the rocker in is spray the weld through and hang the door for proper alignment. I plan to have it done tonight!
Kyle
IG: kyle_ronald
Old 01-27-2021, 09:27 PM   #441
chewychevy67
Awesome!
chewychevy67 is online now   Reply With Quote
Old 01-28-2021, 12:11 AM   #442
Kronald_70GMC
It is in!
Kyle
IG: kyle_ronald
Old 01-28-2021, 11:56 AM   #443
Chevys4life
Nice Work!!!
Chevys4life is online now   Reply With Quote
Old 01-28-2021, 04:29 PM   #444
Kronald_70GMC
Originally Posted by Chevys4life View Post
Nice Work!!!
Thanks for the kind words! I'm very stoked with how well it worked out even though it took alot of extra work to get there.
Kyle
IG: kyle_ronald
Old 01-29-2021, 12:32 AM   #445
gmc684x4
Very nice work i would like to invite you over for a visit my truck needs some of that love too
gmc684x4 is offline   Reply With Quote
Old 01-29-2021, 12:22 PM   #446
Kronald_70GMC
Thanks for the compliments! Too bad its quite the journey to get there
Kyle
IG: kyle_ronald
Old 02-15-2021, 12:44 AM   #447
Kronald_70GMC
No progress on the truck to report but I have been cleaning my shop. I got myself a bolt bin which will be nice. Now I won't have to spend half my evenings looking for bolts and such. I also got a bunch of stuff off the floor by building a recycling/garbage center. That should greatly improve cleanup time in the future. I also found myself a computer monitor that I have hooked up as a small TV in there now. I am still doing a major deep clean at the moment so probably won't have any progress for another week or so but it sure feels good to have a clean shop.
Kyle
IG: kyle_ronald
Old 02-21-2021, 09:53 PM   #448
Getter-Done
Getter-Done's Avatar
Sometimes a break is the best thing
Flip for Ya.
84 Chevy K-20
Old 02-21-2021, 10:32 PM   #449
Kronald_70GMC
Hey right on man! I wasn't aware that they can be flipped. No clue how though. I have my bolt bin all filled up now. Just about done with the deep clean. Just the toolbox left to sort out now.
Kyle
IG: kyle_ronald
Old 02-24-2021, 11:37 PM   #450
Kronald_70GMC
Update on passenger side rocker. I ground down all my plug welds and the difficult to grind seam at the back edge tonight. I also started to weld the door seam the rest of the way. Couple more evenings on this side and I should be able to jump over and start the driver side rust repair.
Kyle
IG: kyle_ronald
