Old 01-21-2021, 03:03 PM   #151
402Bowtie
402Bowtie's Avatar
Re: The build date project
72 chevy
08/71
2F307062
402Bowtie is offline   Reply With Quote
Old 01-23-2021, 12:23 AM   #152
Carl Spangler
Carl Spangler's Avatar
1970 Chevy C10 short bed found on classic.autotrader
1971 SWB step side: Original NM Forestry and then NM Fire truck
Carl Spangler is offline   Reply With Quote
Old 01-23-2021, 12:54 AM   #153
Carl Spangler
71 K10 longed found on classic.autotrader. 1Z660587
Old 01-23-2021, 12:58 AM   #154
57taskforce
All about them K’s
57taskforce's Avatar
Done. I’ve got some more I need to add from pms but I should have that done tomorrow. Carl, that last one from post 153 was added already on post 122. A for effort though! Keep em coming guys!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 02-04-2021, 03:45 PM   #155
402Bowtie
402Bowtie's Avatar
72 chevy
05/72
2S194130
Old 02-04-2021, 11:01 PM   #156
Gigem
Gigem's Avatar
This is the SPID from my 1972 GMC Sierra Grande. St. Louis built truck. As soon as I get the truck back in my possession I will look for the blue sticker with build month on it. I'm sure it's there, the truck is very original. S508014
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 02-05-2021, 08:53 AM   #157
my04
my04's Avatar
Found on FB:
Early 1970 chevy
1966 Custom Camper -327, 3OTT
1968 Chevrolet K20 - 307, 4 speed
1972 K10 SWB - 400, 3OTT
2003 Corvette Z06 - LS6 350, 405HP
2004 Tahoe LT
2015 Silverado 2500HD - 6.0L V8
my04 is offline   Reply With Quote
Old 02-05-2021, 10:13 AM   #158
Carl Spangler
deleted post........
Old 02-11-2021, 11:36 AM   #159
402Bowtie
402Bowtie's Avatar
72 chevy Blazer
2F182202
6/72
Old 02-11-2021, 08:03 PM   #160
402Bowtie
402Bowtie's Avatar
72 chevy
2B115961
10/19/71
Old 02-11-2021, 08:21 PM   #161
57taskforce
All about them K’s
Done, done, done! Great work guys!
Tyler
Old 02-12-2021, 09:07 PM   #162
Carl Spangler
another duplicate...........
Old 02-21-2021, 02:09 PM   #163
402Bowtie
402Bowtie's Avatar
71 chevy
4/8/71
1Z643246
Old 02-22-2021, 06:13 PM   #164
ChevyGuyNC
ChevyGuyNC's Avatar
Here's mine, just got her a couple weeks ago.
1972 C10, Cheyenne Super
4/1972
No build sheet visible under the seat; suspect it was recovered in past.
VIN indicates Flint Assembly
Engine stamp is V0411TDJ which indicates Flint 4/11/72 and the correct 350
A true survivor, Texas truck with 46k
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor
ChevyGuyNC is offline   Reply With Quote
Old 02-28-2021, 10:49 AM   #165
402Bowtie
402Bowtie's Avatar
70 chevy
0J110731
Old 02-28-2021, 11:08 AM   #166
57taskforce
All about them K’s
Awesome! I’ll try and get them added tonight.
Tyler
Old 02-28-2021, 10:02 PM   #167
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Here is my Oshawa 67. I believe Oshawa trucks had no build sheets. They had a line tag with the RPO codes on them and that’s all. Thanks to GM Canada all the info is available. The last pic is of a 69 GM document that would have come from the factory to the dealer.
https://67-72chevytrucks.com/vboard/...1&d=1614563483
https://67-72chevytrucks.com/vboard/...1&d=1614563574
https://67-72chevytrucks.com/vboard/...1&d=1614563652
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 03-04-2021, 11:59 AM   #168
402Bowtie
402Bowtie's Avatar
70 chevy
06/70
0S1602xx... Maybe 0S160283
Old 03-04-2021, 12:01 PM   #169
402Bowtie
402Bowtie's Avatar
72 gmc
Old 03-05-2021, 11:11 PM   #170
Gigem
Gigem's Avatar
TCE142S508014
December 1971
Old 03-07-2021, 01:31 AM   #171
57taskforce
All about them K’s
Great work guys, the fruits are starting to come forth. Gigem, great job, that last GMC was in the database, however there was no build month/year. Keep ‘em coming. 402Bowtie was able to use this list to prove a truck as fraudulent in another post as well. This is going to be an awesome resource as it grows!
Tyler
Old 03-07-2021, 11:23 AM   #172
Keith Seymore
Keith Seymore's Avatar
All of the plants used build sheets. The RPO information alone was not enough information for the operator to select the correct part, especially when there was a proliferation of part numbers within the RPO.
Any area where components were built up remotely and then conveyed to the main line in sequence would require a build sheet: front and rear axle trim, engines, transmissions, seats, front end sheetmetal, tire/wheel assemblies, etc. These are all areas with a lot of proliferation, and therefore not easy to present the material lineside, or - in the case of the seat cushions - a fire hazard (the "cushion room" was always way out in the boonies as a result). The build sheet defined the component that was to be installed, by part number or broadcast code, especially for option driven content where there was some choice as to what part was to be installed, or a remote area where there were no visual clues as to what part should be installed. So - theoretically - you would be able to find a build sheet on the motor somewhere, or above the fuel tank, or anywhere a build sheet was used.
There was no thought, guess work, interpretation or latitude on the part of the assembler: they referred to the sheet, selected the component by part number or broadcast code, and put it on.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-07-2021, 10:39 PM   #173
Canuckvetter
K
I understand your point Keith. Just I have never seen an Oshawa build/broadcast sheet. I will dig into it more and get back to ya.
Michael
Old 03-08-2021, 01:11 AM   #174
Canuckvetter
Michael
https://67-72chevytrucks.com/vboard/...1&d=1615179163
https://67-72chevytrucks.com/vboard/attachment.php?attachmentid=2087453&stc=1&d=1615179677[/url]
Here is what I found so far on the Oshawa build tags.
1-1/2”x 11” tag with partial VIN and RPO’s
The last pic is the code that GM sent out with their document package from their records when I inquired about my truck.
Old 03-08-2021, 06:46 AM   #175
Keith Seymore
Yes - those would be used in addition (as a supplement) to the more familiar build sheet.
Those alone do not have enough detail to build the truck.
K
1979-1986
1986 - 2019
