72 K-10 Chevy Truck
What problems will I have in trying to install a big block engine in a K-10 Chevy Truck
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 72 K-10 Chevy Truck
You can set a big block where a small block goes. It will be tight but can and has been done. You will need a truck oil pan, not a car one. You won't be able to use tall valve covers, and putting a HEI in requires a little massaging of the fire wall other wise it will rub the firewall. The exhaust routing is different as well so you will have to change or replace that. You will need to get all the brackets and pullies from a big block truck or hope they come on your donor engine. You can move the engine cross member forward one bolt hole to gain some firewall clearance but that seems to be a preference thing as well.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
Everytime I see a "big block engine" thread I feel such remorse for getting rid of my '79 Suburban back in the late 90s. I remember finally being able to buy a new car for the 1st time (Explorer 4x4) and couldn't have been any happier giving her over to the dealership (for only 1 grand). I wished I could go back into time and slap myself in the head!
.... walks away and cries some more .....
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
The only problem I see is spending more time at the gas station
