04-11-2021, 07:49 AM | #1551 |
Re: A '54 named Busty
it was a long day, so I just sat there in the end and stared her down sum
04-12-2021, 12:47 AM | #1552 |
doing this part felt really good, my bro got me that license frame
04-12-2021, 07:59 AM | #1553 |
i've seen welded pitman arms on offroad race rigs take a BEATING and never have an issue ... i've seen ppl break em with a hammer installing them too. cheap insurance to get a new one! also agree on the matchy matchy TREs, at least it was local and not mail-order.
04-12-2021, 08:42 AM | #1554 | ||
here is another kicker though, both of the TREs come with Zirc fittings yet only one of them has a hole to screw it in, the other is the "zero" maintenance kind NAPA Right Front - Tie Rod End Inner - $15.74 Part #ES443L why is this an "L" even the NAPA guy was confused NAPA Left Front - Tie Rod End Inner - $16.64 Part #ES442L I don't know what I'm going to do now, I may just spring for two matching MOOG ones and have an entire MOOG linkage, what you all think? Last edited by Gregski; 04-12-2021 at 09:35 AM. |
04-12-2021, 08:52 AM | #1555 |
MOOG is the only thing i buy for TRE and ball joints. i used to use anything cheap and i'd burn thru a set every year in the Jeep on the trail. the MOOG lasted like 10 years after i finally paid up for them. just don't buy the cheaper MOOG, they do have a "Chineseium" line too.
04-12-2021, 09:22 AM | #1556 | |
came across this fun read: Where are Moog parts made? The answer may surprise you! Last edited by Gregski; 04-12-2021 at 09:49 AM. |
04-12-2021, 10:03 AM | #1557 |
the comedy continues - just ordered all MOOG steering linkage parts on the jungle website, and was greeted with this nonsense, I sure hope they actually ship it here
04-12-2021, 04:03 PM | #1558 |
this prop 65 BS is on EVERYTHING. i don't think i've purchased something in months that wasn't stamped with it. hell, bare steel has the warning!
04-12-2021, 06:19 PM | #1559 |
Looks like fun. Too bad I forgot you were so close I could have stopped by on the way or down from Jan since she lives in Yuba
My build a 49 5 window ls1 4l60e on a TCI chassis http://67-72chevytrucks.com/vboard/s...d.php?t=754926 My travel blog The Wong Winding Road-Adventures of The Chinese Cowboy https://thewongwindingroad.blogspot.com/ |
04-13-2021, 10:31 AM | #1560 |
04-13-2021, 11:10 AM | #1561 |
me going to work on the truck wiring while I wait on the steering parts to show up
04-13-2021, 11:46 PM | #1562 |
today we took on the brake lights, but first a Unicorn sighting
yup that's a clean workbench |
04-13-2021, 11:50 PM | #1563 |
we got our wiring constructions, let's see how closely an abandoned truck siting in a desert has follow them, ha ha
it appears from the diagram there are two ways to do this: 1. Brake lights and Tail lights only no turn signals (and of course trucks back then had no reverse lights) ~ OR ~ 2. Brake / Turn Signals and Tail lights we are taking baby steps, so we will go with Option 1 Last edited by Gregski; 04-15-2021 at 11:33 AM. |
04-13-2021, 11:53 PM | #1564 |
I love the simplicity of this truck, the stock fuse block had only two fuses in it (one for the brake lights and one for the tail lights), we are going to go crazy and replace it with a six fuse one
04-13-2021, 11:55 PM | #1565 |
mandatory stare and compare
04-13-2021, 11:56 PM | #1566 |
look at all those neat yellow hard plastic connectors it came with
04-13-2021, 11:58 PM | #1567 |
and this is the stock headlight switch, I was hoping to use it but it looks like the springie thingie is broken, darn it
the headlight switch does play a role in the brake circuit, why I don't know but it does |
04-14-2021, 12:01 AM | #1568 |
I figured I would mount the fuse block somewhere to get a proper gestimation of the wire length runs from the headlight switch to it etc.
I thought it and the drive by wire throttle box could share a flat |
04-14-2021, 12:03 AM | #1569 |
gonna mount it above the trans tunnel way up high where it's difficult to get to
04-14-2021, 12:06 AM | #1570 |
I crimp, solder, and heat shrink all my terminals and connectors
04-14-2021, 12:08 AM | #1571 |
so the first thing we do is bring the Power red wire from the ignition key switch to the P terminal on the headlight switch
04-14-2021, 12:11 AM | #1572 |
then for brakes all we have to do is send that power on the Orange wire from the Stop "S" terminal to our fuse block like so
04-14-2021, 12:12 AM | #1573 |
if we were wiring up the Tail lights we would simply send the power on the T terminal of the Headlight switch
Note: I hate it that they use a black wire for the tail lights, black is usually ground Last edited by Gregski; 04-15-2021 at 11:34 AM. |
04-14-2021, 12:24 AM | #1574 |
so to have brake lights and tail lights our headlight switch would look like this
again, the black wire is not ground it is for the tail lights, the orange wire is for the brake lights, and the red wire brings the always on power from the ignition key switch, meaning even with the key off or no key in the ignition at all, the headlight switch still has power going to it, that's why you go to Kmart and leave your lights on in the truck Last edited by Gregski; 04-15-2021 at 11:36 AM. |
04-14-2021, 07:58 AM | #1575 |
You are going to be done soon. Also, agree with the crimp, solder and heat shrink everything.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
