Old 03-03-2021, 12:26 AM   #351
jimbosprint
jimbosprint's Avatar
Re: '72 Cheyenne K10
I need it for photos like this.
jimbosprint is offline   Reply With Quote
Old 03-09-2021, 04:34 PM   #352
jimbosprint
I dropped the extra transmission and transfer case (that came with the truck) off to get rebuilt. Once I get them back I will swap both into the truck.
Old 03-23-2021, 09:54 PM   #353
jimbosprint
I mounted some KC Hilites spread beams on the lumber rack. Wired to the relay, but I need to finish wiring the switch.
Old 04-08-2021, 03:15 PM   #354
jimbosprint
Transmission and transfer case are back from the shop
Old 04-09-2021, 10:00 AM   #355
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Attachment 2094128
Let the fun begin!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 04-09-2021, 07:53 PM   #356
jimbosprint
The fun has begun! Old transfer case is out of the truck.
Old 04-09-2021, 10:46 PM   #357
jimbosprint
Got the crossmember out too.
Old 04-10-2021, 03:47 PM   #358
jimbosprint
The fun continues...
The super greasy crossmember and torque mount are all cleaned up, and the old transmission is out.
The people at Locktite should know that their product works for decades.
Old 04-10-2021, 06:09 PM   #359
Richard
I believe many thread lock compounds transform into rust-tite after a number of years.
Richard
Old 04-10-2021, 07:28 PM   #360
Ol Blue K20
At least it wasn't gonna fall out. LOL
Dale
Old 04-12-2021, 09:46 PM   #361
jimbosprint
I think I have everything ready for install. New bolts for everything, 3 gallons of ATF, and all the old parts are cleaned up. Tracking says new cooler lines, kickdown cable, poly transmission/torque mounts, and gear oil will be here tomorrow.
Old 04-15-2021, 01:19 AM   #362
jimbosprint
I got the transmission and transfer case installed today. Column shifter, speedo cable, rear driveline are all hooked up. Fill tube and kickdown cable are installed. I need to hook up the transmission cooler lines (I have some found conflicting info on which line goes to which fitting on the radiator). And I still have to fill up the fluids.
But my main obstacle is that the twin stick shifters do not line up with the factory hole in the floor. They need to be forward and right of where they are. The website said GM NP205, but it wasn't specific about compatibility with a '72. I'm guessing it is designed for '73 up. I hope I can find a fabricator to help me modify these stainless shifters to make it work. I have it stuck in RWD HIGH without any shifter for now. At least I will be able to drive it.
Old 04-15-2021, 02:08 PM   #363
jimbosprint
The manufacturer of the twin stick has offered to modify the handles at no charge. That's what I call customer service!
I assembled it the best I could to take more pictures and measurements for him.
Old 04-16-2021, 06:51 PM   #364
jimbosprint
Bad news. I filled up the transmission and went for a drive around the block, and it leaks really bad from the servo. The person that rebuilt it says he will fix it next week, but it's a real bummer. It leaked a tiny bit after filling, but it was squirting out profusely while driving. Left an obvious nasty trail of fluid behind on the road too.
Old 04-16-2021, 08:11 PM   #365
Ol Blue K20
Attachment 2096035
Attachment 2096036
That sucks!
Dale
Old 04-23-2021, 07:07 PM   #366
jimbosprint
Darn. The modified shifter handles showed up today, but they are not going to work. They still hit the opening in the floor and can't be shifted. He's on vacation for 2 weeks, so I have to wait.
Old 04-23-2021, 07:40 PM   #367
Kronald_70GMC
Kronald_70GMC's Avatar
Darn 2 weeks. Isn't that the way it always goes. I think I'd have to modify them myself. Truck is looking awesome man! I love seeing an old survivor out there still working away!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 04-24-2021, 05:03 AM   #368
72 tigger
72 tigger's Avatar
Sorry it’s taking so long- bummer
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 04-27-2021, 01:05 AM   #369
jimbosprint
Transmission leak is fixed. Just a broken o-ring. I went to the parts store for ATF and he had it fixed when I got back. We spent more time talking and drinking a beer.
Got a couple new stickers today.
Old 04-27-2021, 07:57 PM   #370
jimbosprint
No mystery why this o-ring was leaking
Old 04-28-2021, 06:43 AM   #371
Ol Blue K20
I thought an o ring didn't have ends!!
Dale
Old 05-05-2021, 05:01 PM   #372
jimbosprint
Two wheel drive got me out to where I needed to work on the disc golf course today.
Old 05-13-2021, 11:45 AM   #373
jimbosprint
Third time's the charm. The modified handles work great. Now I have RWD, FWD, and 4WD in high or low range. Pretty darn cool.
Old 05-14-2021, 07:10 AM   #374
Ol Blue K20
They look good, my little brain would screw it up if I had them.
Dale
Old 05-28-2021, 12:20 PM   #375
Ol Blue K20
Jim it was great meeting you yesterday. Thanks again for the adapter!
Dale
ochre
