Old 05-13-2021, 08:21 PM   #1
bennylava
bennylava's Avatar
Different air controls for an 87 (with AC)
Hi all, I'd like to ditch the factory air controls for my 87 truck and get something more modern. After 12 years of owning the truck (never gonna sell it) I find that I just don't like those old levers. I guess I never liked em.
Is anyone aware of something with buttons or knobs that would fit in the factory slot? Instead of those old style levers. Who knows, maybe there's even something out there with a digital readout of some kind. Doesn't have to be though. Just something that will fit, that I can hook up all the factory air stuff too. I do have air conditioning so that might affect which one I can get.
Maybe an odd request I know, but I just don't like those things.
Thanks!
bennylava is offline   Reply With Quote
Old 05-14-2021, 09:40 AM   #2
v30crewcab
v30crewcab's Avatar
Re: Different air controls for an 87 (with AC)
don't know of any direct fit, unless vintage air has a different panel for their system.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-14-2021, 02:01 PM   #3
Keith Seymore
Keith Seymore's Avatar
Thanks!
Whew!
I'd like to ditch the controls in my '04 and go back to something like in my '87!
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-14-2021, 02:21 PM   #4
bennylava
bennylava's Avatar
I've heard that just about any will work once you adapt the fittings. So that leaves only the size. Which means I'll have to find a way to get measurements on different ones. Might just have to take mine to the junkyard and ask the guys working there which ones are the same size.
I'm guessing not many, but there's bound to be something out there. The modern ones are probably all somewhat larger.
Old 05-14-2021, 07:13 PM   #5
Bloodhound
Keep in mind that any modern setup the controls are electronic and yours are vacuum operated.
Bloodhound is offline   Reply With Quote
Old 05-15-2021, 02:20 PM   #6
Axle
Axle's Avatar
I did this with a ford, I spent a few days pouring over vacuum manuals searching for newer vehicles that had the same vacuum logic tree as the original and in my case, had a cable controlled blend door. Then I went to the autowreckers to find said vehicles and see what would potentially fit.
I'd start with having a close look at the next generation gm trucks or whenever they went to dials and see if they still operated the blend doors the same way. If so, you're golden. Just a matter of patching the old and new together.
Axle is offline   Reply With Quote
Old 05-16-2021, 10:59 PM   #7
SunSoaked
SunSoaked's Avatar
Do what I did, tear every last piece of the OEM system out and install a modern plug and play system in. I'm using Vintage Air surefit and it works perfect. Do the entire system, r134 Sander compressor and all. Second best thing I ever did to my truck.
SunSoaked is offline   Reply With Quote
Old 05-16-2021, 11:58 PM   #8
Bloodhound
Same here.
Old 05-17-2021, 04:03 AM   #9
bennylava
bennylava's Avatar
Did you get a new air control unit with the vintage air stuff?
Old 05-17-2021, 12:29 PM   #10
Bloodhound
Yes, and it's all electronic like modern vehicles.
Old 05-17-2021, 02:06 PM   #11
Just call me Sean
Just call me Sean's Avatar
The next gen control would probably fit, but it wouldn't control anything without the motors that move everything.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 05-17-2021, 02:33 PM   #12
SunSoaked
SunSoaked's Avatar
Vintage Air is the way to go. You also lose all the junk on the firewall. It all fits inside the cab. I live in Yuma AZ. Its 120 plus here in the summer. It blows 43-45 degrees out the vents. No rotted vacuum hoses, sticky cables, stuck relays, blah, blah blah. It's the 2nd best thing I've ever done to my truck.
Old 05-17-2021, 03:49 PM   #13
Just call me Sean
I never had any problems getting the factory system below 50 degrees.
Old 05-31-2021, 02:52 PM   #14
bennylava
bennylava's Avatar
How much did you pay for everything in total?
Next question - Looking at that pic of the control unit, how do you turn on the AC itself?
Old 05-31-2021, 06:18 PM   #15
Just call me Sean
Probably by moving one of those levers you don't like.
Old 05-31-2021, 07:26 PM   #16
Bloodhound
Yup. The levers are connected to the computer contained on the below dash unit. Just slide towards cold and it turns on.
Old 05-31-2021, 08:24 PM   #17
SunSoaked
SunSoaked's Avatar
Exactly.
Old 06-01-2021, 07:48 PM   #18
83GMCK2500
Hoping someone from VA or one of the other companies with an update kit see this: YOUR CONTROLS DO NOT MATCH THE OEM LOOK. They look like complete ASSHOLE when placed side-by-side to stock controls.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is online now   Reply With Quote
Old 06-01-2021, 09:05 PM   #19
SunSoaked
SunSoaked's Avatar
The look is subjective. The function and reliability is spot on. Choices.
Old 06-02-2021, 04:40 AM   #20
Bloodhound
Well, it's not OEM, so why would it.
Old 06-02-2021, 06:30 AM   #21
bennylava
bennylava's Avatar
Does that create any new noises inside the cab?
But what if you want to use the coldest setting, but not the AC? In texas, we have long shoulder seasons. Spring and fall last for months. It's a great time to just use the outside air, and save gas and have a bit more power. Those controls look like you don't get a button to turn the AC on or off. Given that, I'd have to pass on that one. Kinda lacking in features imo. I'd probably use the rest of the vintage air system, just not the controller.
Old 06-02-2021, 06:40 AM   #22
SunSoaked
SunSoaked's Avatar
You're over thinking it. Probably better off sticking with the old stuff.
