Old 10-02-2019, 04:10 PM   #26
straight6chevyguy
straight6chevyguy's Avatar
Re: possible clutch problem?
Here is the those pics of the old clutch parts.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 10-02-2019, 04:14 PM   #27
straight6chevyguy
more...
Old 10-02-2019, 04:19 PM   #28
straight6chevyguy
And for the pilot bearing...(Whats left of it any way)
I used the grease and bread with a ground down bolt method to remove it by the way.
Old 10-02-2019, 04:22 PM   #29
Killer Bee
Killer Bee's Avatar
well never mind then LoL - good luck with the rest!
Old 10-03-2019, 08:33 PM   #30
AussieinNC
Moderator
AussieinNC's Avatar
That pilot bush has also worn the tip of the input shaft....
I usually replace the bronze bush with a roller bearing unit from Dorman....
https://shop.advanceautoparts.com/p/...0&gclsrc=aw.ds
Suggest you bleed release bearing system with a pressure bleeder...
Good luck...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 10-07-2019, 02:48 PM   #31
straight6chevyguy
Well, I got it all back together.
Installed the clutch wednesday, put the tranny in thursday evening (with help from my Dad and my brother) (no transmission jack)
and buttoned it all up friday.
So far so good... clutch works much better, I only have taken the truck for a short test drive but so far I can say it is way improved.
Old 10-10-2019, 02:31 PM   #32
straight6chevyguy
Smile Re: possible clutch problem?
My first clutch replacement is a success!
Spent some time in town with the truck the other day...
Clutch engages much more smoother now and the truck does a lot less jerking.
Replacing the clutch/components was a really good idea lol.
I still have my clunk noise from time to time when I disengage the clutch, but I think it's coming from the transmission.
Not going to worry about it for now.
Thanks goes out to all you guys for your helpful input and suggestions!
Old 05-30-2021, 12:56 PM   #33
straight6chevyguy
Well it's been a while but I wanted to do an update on this.
So the new clutch helped for a while but it's pretty much gone back to how it was with the old clutch maybe even worse I don't really know it's been so long.
Truck still shudders/clunks when I hit the clutch under load (mostly noticed when backing out of or pulling forward in a parking space)
(I think this is slowly getting worse over time)
Truck does not take off smoothly (shudders)
Strangely it seems to take off smoother in 2nd gear????
All shifting is semi ruff sometimes not to bad other times bad.(if I work the clutch just right it's not to bad but it seems to me it should not be so sensitive)
I think 1st to 2nd & 2nd to 3rd are the worst.
I'm begging to wonder if I have an engine/lack of power problem that is playing a part in this but not really sure.
BTW I have checked the u joints and they seem to be fine.
And there is no noticeable vibration while driving.
As soon as I get my 76 c10 on the road (witch could be a while) I'm going to park this thing and tare into it.
Untill then however I'm going to be driving it till it blows up I guess!
If anyone has any thoughts please comment.
Old 05-30-2021, 05:41 PM   #34
Just call me Sean
Just call me Sean's Avatar
Sounds like maybe broken motor mounts.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 05-31-2021, 12:21 PM   #35
1976gmc20
Or you could have worn it out again already depending on how you drive ???
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 06-02-2021, 12:17 PM   #36
crsgmc
I read the entire thread and had to reply. About 5 years ago I purchased a 1996 K1500. It was a real fixer upper. The body was great and very little rust. I have been driving standard transmissions my hole life, but driving the 1996 was really difficult. The foot pressure to push in the clutch was really extreme. If you tried to let the clutch out in first gear with any slippage the whole truck would violently shake. I found that if you let the clutch out slowly at idle and then applied the throttle it would not shake. The truck would almost stall so the timing was really critical. I decided with the problems in the engine, that I would replace the engine with a new GM crate engine. When I had it apart I noticed that the fly wheel was scored badly, and the pressure plate had some of the fingers bent. I installed a clutch kit, including pressure plate, clutch, both bearings, slave cylinder etc. I also replaced the pressure plate. Both engine mounts were broken and were replaced with new polyurethane engine mounts. Transmission mount was also broken in half, that was replaced as well. After the install was completed, the clutch petal force needed to press in the clutch was reduced by at least 70 percent. The whole shaking thing was fixed as well. I am afraid that I am not going to be of much help with sorting out your problems. I changed so much stuff that I don't know what parts fixed which problem. I suspect that the pressure plate made a big difference. Engine had a bad main seal leak that I think was blowing some oil on the pressure plate. The engine and transmission mounts probably amplified the problems that the clutch had. I think the heavy clutch had to do with the damaged pressure plate.
crsgmc is offline   Reply With Quote
Old 07-04-2021, 12:21 PM   #37
straight6chevyguy
Thanks for you're input guys.
Just read the last two comments today, did not get my email notification for some reason.
