Old 05-26-2021, 02:38 PM   #26
HO455
HO455's Avatar
Re: Control Arm Rubbing tire - solution 101 - found
I solved the same problem on my S10 by using a pair of 3/8" wheel spacers. Over 100k miles without issue. I had them made by a local machine shop with proper hub centering and wheel stud sizing. No generic parts house spacer.
RIP Bob Parks.
Old 05-26-2021, 03:11 PM   #27
67C10Step
67C10Step's Avatar
Originally Posted by Grumpy old man View Post
No , They are advertised as the only drop spindles that don't increase the width , I'll get some more pictures and get a measurement of the width of the rotors side to side. I'm using stock A arms and 255 x 70 x 15 tires
I am running the exact same setup as Grumpy and just couldn't resist. I am now interested to see his photo and measurements. This is how my lower control arm looks compared to the wheel. 2-1/2" drop spindle, 15x8 rally, 255/70-15 tires. Plenty of room.
Now I am aggravated as I noticed a split in the outer tie rod boot and the one on the passenger side is totally split. WTH? These things aren't a year old.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 05-26-2021, 03:35 PM   #28
Grumpy old man
Grumpy old man's Avatar
Turn the wheel full left and full right , Check clearance again , Sorry , I'm in the middle of hand sanding my firewall .
I hate hand sanding ! For the 3rd time ... rain tomorrow need to prime it again tonite .
Old 05-26-2021, 03:52 PM   #29
70cst
70cst's Avatar
Could this part of my problem...
I have a P245/60/15 tire? Is the size a little to big adding to my issues?
I am just trying to look at all possibilities.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-26-2021, 05:04 PM   #30
SCOTI
SCOTI's Avatar
Tire size should be moot.... It's the wheel lip that interferes w/the a-arm gutter.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-26-2021, 05:12 PM   #31
70cst
70cst's Avatar
True ... I am low on coffee
Old 05-26-2021, 07:10 PM   #32
gmc684x4
The reason behind the one drop spindle mentioning does not increase width that is for stock 67 70 drum front brake measurement
71 72 disc is slightly wider so is the rear axle is slightly wider as well
gmc684x4 is offline   Reply With Quote
Old 05-26-2021, 07:30 PM   #33
Grumpy old man
Here's a pic of mine , ignore the dust everything in the shop is covered in dust.
Old 06-02-2021, 04:21 PM   #34
70cst
70cst's Avatar
Ok ... so if I understand it correctly:
I have a 4" BS and if I go with a 3" BS it will pull the tire another inch outwards? Thanks
Old 06-02-2021, 06:09 PM   #35
SCOTI
SCOTI's Avatar
Yes. It will move the barrel of the wheel out vs the hub centerline. Doing so widens the track width if not going to a narrower wheel.
The more aggressive you get, the harder it is on wheel bearings as a result from the additional weighted leverage of a steel wheel. Just a maint related item to keep in mind.
Again..... Trimming the rain gutter is very common for the minimal clearance needed. It just needs to be done w/care in mind.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2021, 12:13 AM   #36
lil hoodlum
lil hoodlum's Avatar
Maybe I'm wrong but it seems that if you go with less backspace, in this case an inch, wouldn't it bring the face of the hub inwards an inch? So if you wanted more clearance from the back side of the hub, 4.5" backspace would gain you a half an inch clearance?
lil hoodlum is offline   Reply With Quote
Old 06-03-2021, 12:19 AM   #37
lil hoodlum
After further review, I see that your control arm is hitting the bottom outside the wheel. So I do believe that decreasing the back spacing of the rim would provide more clearance between the control arm and the bottom of the wheel.
In other words, maybe my above post is incorrect.
Old 06-03-2021, 12:28 AM   #38
lolife99
67-72 parts collector,…
lolife99's Avatar
Backspacing is just like it sounds.
It’s a measurement from the wheel mounting surface to the inside edge of the wheel.
Less backspacing moves the wheel out.
Keith
Convert to disc brakes.
Old 06-03-2021, 07:12 AM   #39
70cst
70cst's Avatar
I just might go with a 7" wheel/tire combo in the front and 8" in the back. That would solve my problem plus I could decrease my BS without it going to far outwards.
Old 06-03-2021, 09:03 AM   #40
SCOTI
SCOTI's Avatar
Exactly. This is another reason many utilize the staggered front to rear combos.
Be prepared because even 7" wheels sometimes get close enough that it requires a little clearance work on those porky a-arm gutters. The OE disc brake 6" wheels are usually the ones that clear w/o issue. Aftermarket 7" wheels w/spec'd back spacing should be good.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2021, 02:03 PM   #41
70cst
70cst's Avatar
Thats my thinking - mabve add about a 1 1/2" BS with the 7" wheel should solve my issues.
Old 06-03-2021, 02:33 PM   #42
SCOTI
SCOTI's Avatar
You need to get your nomenclature down for these discussions.
ADDING back-space means the wheel barrel would be moving closer to the source of your contact issue. Reducing back-space would mean moving it away from your contact issue.
You want a 6-7" wheel w/less BS than your current 8" wheel. That shifts the contact point @ the wheel lip farther away from the a-arm gutter while keeping a similar outer track width.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2021, 02:42 PM   #43
70cst
70cst's Avatar
Yes ... I presently have 4" BS on a 8" rim and I will go to about a 3" BS with a 7" rim
Old 06-18-2021, 11:45 PM   #44
lolife99
lolife99's Avatar
Did you ever resolve this issue?
Keith
Old 06-19-2021, 03:19 PM   #45
70cst
70cst's Avatar
I ordered two 7" rims with 3" BS. The tire dealer said I can use the exisitng tires on either a 8" or 7" rims.
