06-10-2021, 05:06 PM | #1 |
Best spray can primer/paint for chassis?
Hi all,
Looking for recommendations for what is the best primer/paint from a spray can for painting frame/chassis components. I plan on cleaning up some items by wiring wheeling and/or red scotch brite pads and clean with brake cleaner to degrease. I also have a few new parts that are just bare steel that need to be coated. Not interested in powder coating due to cost and time. Krylon ColorMaxx? or VHT Rollbar and Chassis Epoxy? I've read a few build threads that said Krylon ColorMaxx was good, but then read a fairly recent post that the formula was changed and to avoid it. Any feedback or input is appreciated. Thanks! -Dexter |
06-10-2021, 07:17 PM | #2 |
Re: Best spray can primer/paint for chassis?
ive had good luck with the higher quality krylon and rustoleum
06-10-2021, 11:33 PM | #3 |
If you are going to use a a spray can, metal prep the chassis after you wire wheel and degrees it. Your paint job will last a lot longer if you treat first
06-11-2021, 09:30 AM | #4 |
Same here. Lupo is right, preparation is the key but that is the same for any surface coating.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-11-2021, 02:38 PM | #5 |
Sem trim black
06-11-2021, 02:43 PM | #6 |
Or worth satin trim black
06-11-2021, 04:14 PM | #7 |
I'd always use a 2k epoxy. Eastwood sells it in an can that you press a plunger on the bottom and mix it if you dont have a compressor to shoot it. One time use but my brother used it with good success.
Has anyone used the Steel It paint? I keep seeing it online but never see it in person.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-12-2021, 11:11 PM | #8 |
I have always had good results for YEARS on daily drivers with clean metal, no primer, and Rustoleum brushed on.
06-12-2021, 11:18 PM | #9 | |
06-23-2021, 07:28 PM | #10 |
I brushed on agriguard, it’s hard to find though. Used rust bullet on the floor, it flows out well and seals the frame
06-26-2021, 01:03 AM | #11 |
Not planning on winter driving.
I've been thinking about using a rust inhibitor or converter on frame/mounts etc, wherever there is pitted rust that can't be cleaned up perfectly with wire wheeling, and then top coating with Krylon Satin Black. I painted the rear diff this way and hopefully it holds up. Wire wheeled it up best I could, then red scotch brite, and brake cleaner to degrease. Sprayed a few coats of rust inhibitor primer, then top coated with Krylon Satin Black. Maybe POR would be better and then top coat? |
06-26-2021, 01:05 AM | #12 |
06-27-2021, 09:25 PM | #13 |
VHT Epoxy Satin Black. Not the Rollbar paint. It's a challenge to find but it turns out pretty nice. I agree, you have to clean, treat and prime it to make it last.
06-27-2021, 09:56 PM | #14 |
https://www.napaonline.com/en/p/MSR7243 NAPA chassis black But it's all in the prep.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
06-28-2021, 04:02 PM | #15 |
VHT Chassis & Roll Bar paint is a decent and so is their Epoxy Satin Black product. Both are epoxy and claims to be chemical resistant but I can tell you from experience brake fluid will strip just about any rattle can paint right off if you don't clean it up immediately. Rustoleum appliance epoxy is much cheaper than VHT and is pretty similar $25 for 6 can at Home Depot vs VHTs $8 each. The 2K aerosols are more chip & chemical resistant but expensive. I'm not trying to win any shows so I will just touch it up on occasion. The VHT Epoxy that I sprayed on my control arms is holding up pretty good.
Made in America by Americans |
06-28-2021, 05:32 PM | #16 |
I used Eastwood's extreme chassis black. I hand stripped the chassis to bare metal and used their rust encapsulater over the bare metal. It has been rock hard.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
06-28-2021, 11:29 PM | #17 | |||
What makes it better than the rollbar paint? Anything specific? Quote:
Im up in Canada, and by the time a few suppliers bring it up, and import etc, the price becomes ridiculous. If I was down in the lower 48, Eastwood would have been my go to. |
07-15-2021, 04:52 PM | #18 | |
Here is how my spindles turned out. This is the gloss, which comes out more like a semi-gloss.
07-21-2021, 09:19 PM | #19 | |
-Dexter |
08-02-2021, 03:03 AM | #20 |
Rustoleum. It's a tough paint. Just prep your chassis really well.
08-08-2021, 06:13 PM | #21 |
Rustoleum. Wire brush/degrease/wash. Rusty metal primer and semi gloss or Satin black.
2006 Sierra RCSB V6 5 Speed RWD. |
08-10-2021, 01:43 PM | #22 |
Thanks! I think i might try one product on one side and a different product on the other and see how they hold up... or take the info and go with which ever is more cost friendly.
