06-13-2021, 02:35 PM | #26 |
Re: Help with no spark please
How did you determine there is no spark?
06-13-2021, 03:16 PM | #27 | |
https://performancedistributors.com/ While on the subject, here's a handy spark checker I picked up from Harbor Freight for only $3.99 - a lot cheaper than the parts stores. https://www.harborfreight.com/90-in-...ker-63593.html
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
06-13-2021, 05:08 PM | #28 |
06-13-2021, 06:12 PM | #29 |
I pulled the ignition switch to replace it just because I had already bought it. This is what I found. I really hope this is the problem. Anyone know the best way to attach a new pig tail? I just dont understand how everything went from running awesome to having this burnt out. Like I said, not sure if this will fix everything but I hope it does and will let u all know. Thanks very much for everyone's suggestions on this.
06-13-2021, 08:31 PM | #30 | |
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
06-14-2021, 11:19 AM | #31 |
Well even with the original pig tail obviously melted I put the new one in and still have no spark..I want to burn my truck to the ground at this point.ill try to double check everything I already have when I fly back home next Monday..This is killing me. If anyone has any other ideas I am all ears..thanks fellas
06-14-2021, 11:34 AM | #32 |
When you say, "no spark", are you using that term in a general sense to mean the engine isn't starting, or did you physically confirm that the spark plugs are not sparking by using a spark checker, timing light, etc?
06-14-2021, 12:48 PM | #33 | |
Was I checking for spark incorrectly? I always thought to just pull the number 1 plug from the engine, leave it attached to the spark plug wire and ground it to the engine. Maybe I did it wrong. |
06-14-2021, 03:06 PM | #34 |
Had a similar situation . Was going to put new valve cover gaskets on the 72 . Went and washed the engine at the local car wash had the engine running and it stalled got in no start. Did all the usual things sprayed inside the cap with wd40 wipped it out sprayed all the wires checked every connection at the distributor. Got a test light no juice to the distributor. The po had put in the HEI and used a fuse in line . Well the water shorted the wire a blew the fuze 30 minutes for a 10 cent fuse.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
06-14-2021, 03:30 PM | #35 | |
06-14-2021, 03:32 PM | #36 | |
06-14-2021, 04:29 PM | #37 |
I've been thinking about your problem. If I understand, you had the same issue with the old distributor. You said you are getting power at the Batt terminal on the distributor. Exactly where are you putting the test probe of your multimeter to check that? The reason I ask is that you may have a faulty connection plugging the power wire into the distributor. Did the previous owner use an actual HEI pigtail like the first picture or is it just a crimped on connector like the second picture? I have seen it before where those generic crimped female connectors miss the terminal inside the distributor and although there is power at the connector it is not making good contact to the distributor.
1972 GMC K2500 Super Custom Matt |
06-14-2021, 06:29 PM | #38 | |
I did by a new pig tail off amazon. its only 6 bucks so it's not breaking the bank. When I get home I am going to follow both those wire from the back of the distributor and see if they are fried anywhere. Obviously something happened because when I posted the pic of my ignition switch the plug was melted a little bit on the top red wires. Maybe something else is fried also. I will change out the plug and see if that helps anything. I am testing for power doing the following. Key in the ON position. Test light probe touching the bat and tach side with the distro cap removed. Both of them the light will come on when touched. |
06-14-2021, 07:28 PM | #39 |
Okay. I'm a little concerned that you are seeing power on the tach terminal. Not sure if that is correct. Someone more knowledgeable than I can chime in on that.
As for the plug on the distributor, not trying to be condescending, but is there a chance it is put in backwards? Being two pieces I don't know if it is possible. I'm thinking that could maybe be the cause of the melted terminal on the back of the ignition switch. In the attached image, the red wire is the+12V (color not important). What is important is the tang you can just make out on the backside of the plug in this image. It slides into a groove in the distributor to ensure the plug can only go in one way. The +12V terminal on the distributor is the one closest to the firewall. Unless you have a tach, the other wire doesn't need to be connected. Since you have a 2 piece plug, I would leave that terminal disconnected just to eliminate one more potential problem. Oh, also is the ground strap inside the distributor in place?
06-14-2021, 07:37 PM | #40 | |
06-14-2021, 08:24 PM | #41 | |
PM sent if you wanna call me.
06-14-2021, 08:39 PM | #42 |
Your right. My thinker wire of the two is the yellow wire, but it is plugged into the slot where the yellow wire above goes in the picture above. The Red wire goes to the red position but it is not as thick as the yellow wire. I would say that might be the problem but I have been driving my truck for almost 2 years and it has been running great. maybe that is why the ignition switch finally burnt out. I don't know. I will trace the yellow and red wires when I get home and let you know where they both go. I would love to take you up on that phone call next week when I fly home if I cant get this figured out.
06-14-2021, 08:45 PM | #43 |
Sure, call anytime. I'll be out of phone service June 25-July 5 (taking a friends boat from Bellingham, WA up to Juneau) Aside from that, I'm free.
06-14-2021, 08:52 PM | #44 | |
This is the set up I took out and the original when I bought it. worked great up until last week. |
06-14-2021, 08:58 PM | #45 |
I suggest trace where the yellow and red wires actually go. Find out exactly where they connect in the cab and verify they don't connect to some other wire on the way to the cab, for example you don't want the power wire connecting to a white cloth covered wire in the engine wire bundle. The white cloth covered wire is a resistor wire. I've seen some cars and trucks where one wire is spliced onto another wire for a couple feet, and then spliced to yet another wire, and sometimes there are bad crimp connections, or wire nuts used, and other stuff like that.
Don't connect the tach wire to the distributor at all while trying to figure out why your distributors won't fire. Just connect the power wire. If you have a short in the tach wire or problem with the tach, or if you have a kill switch somewhere in your truck that connects the tach wire to ground, the truck won't start. If it has a locking clip on the connector, make sure that clip is clipped onto plastic housing of the distributor. Power should come from the 12 gauge pink wire that comes from the ignition switch, or from IGN UNFUSED connector on the fuse panel. If power comes from somewhere else let us know where. You had the plastic coil cover off for one of your pictures and you mention how you tested for voltage, but I'm not clear on exactly where or how you tested. Inside that cover you have the metal strips that run from the connectors to the coil. Use an alligator clip test wire to connect your volt meter to the metal strip closest to the firewall, and connect your power lead to the underside connector on that same strip. Verify you get voltage with the key on, and during cranking. The negative lead of the volt meter should be connected to a good ground. Last edited by dmjlambert; 06-14-2021 at 10:30 PM. Reason: add info |
06-14-2021, 10:21 PM | #46 |
I thought of this on my way home: I agree with dmj. Trace the wires and check the connections. Somewhere there may be a poor connection or splice. Carries enough current to see 12v on your multimeter or your test light, but not enough current for the distributor to operate.
06-15-2021, 10:59 AM | #47 | |
I testing for power twice. Once with a test probe and once with my multi meter. Both my probe an meter have the standard needle points end. So I put the Red on the Batt wire and the black on the steel bolt for my master cylinder. With the key on I had the necessary voltage, But when I crank the engine the voltage would drop to 0. With the key on same thing with the test light. It showed power to both the Tach and Batt metal clips. I also checked the OHMs before the distributor was installed. I test for low and primary resistance. Everything was with in specs from what I had read and researched. I think that tracing the wires I might find what is going on. I should have done that first. My brain was stuck on mechanical issue because it had been running so good prior to this, it didn't occur to me that it could be wiring. Thanks for everyone's help on this. As soon as I get her back and running I will post. If I cant find anything with the wires then i'll keep on it. Thanks again. |
06-15-2021, 12:23 PM | #48 |
Make sure that you intake manifold is grounded to the firewall and the firewall is grounded to the frame and your engine block is grounded to the frame.
Next time you are at the junkyard pick up an HEI module or two and keep it in the glove box for spares. Best if you grab one from a wrecked car, since you know it was functioning when the car crashed . The old factory OEM HEI modules are way better than any of the aftermarket ones.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
06-15-2021, 01:38 PM | #49 |
Did your new distributor come with a new coil or did you use your old one? You could have a bad coil, but yes you should trace the 12V wire back and look for any issues. Did you check the underside of your cap to make sure the center pin is still there that touches the rotor. Good luck, keep looking you will find the issue it just takes time.
06-15-2021, 06:26 PM | #50 | |
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
