![]() Join Date: Feb 2004
14 bolt differential number, does it tell me axel ratio?
Just wondering if I can tell the axel ratio with this number? K G0252
![]() Join Date: Mar 2003
Re: 14 bolt differential number, does it tell me axel ratio?
Not really, have a glove box sticker. RPO for the gearing will be a G something
![]() Join Date: Oct 2016
I don’t think the 14 bolts have anything like the BOM on the Danas. I have learned the hard way not to trust those anyway. The pinion and ring gear tooth counts will be stamped on the rim of the ring gear though.
![]() ![]() Join Date: May 2015
Yeah, I was gonna add,pop the cover and get the numbers off the ring gear
Be a good excuse to change the oil also
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-07-2021 at 06:32 AM. |
![]() Join Date: Dec 2009
Years gone by and things change.
As Greg stated pop that cover. Look at the # That is the only real way to know for sure. ![]() Count the teeth and divide ![]() .
About how much fluid does it take? 80-90 ?
Thanks |
About a gallon.
If you have had the axle out and the wheel bearings are dry maybe more. Make sure to jack each side of the axle up and let the oil flow to the bearings. If not a gallon will do. ![]() .
my 14b sf held less than a gallon after i put the truetrac in
Thanks guys
