Old 07-31-2021, 06:47 AM   #1
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice 1972 K20 Fire truck up for auction in Scott Kansas 8/10
Is anyone near this that could go check it out or go to the auction? It looks like a very nice truck that started out as an original K truck cut and lengthened. It would be cool to get more info on it. I'd love to go down and try to buy it but it just isn't in the cards currently.
https://www.commercialtrucktrader.co...K20-5017182049
Ryan
1969 Chevy milk truck
Old 07-31-2021, 07:29 AM   #2
Re: Very nice 1972 K20 Fire truck up for auction in Scott Kansas 8/10
That's a cool custom-built truck. stretched frame and they added some vintage speed equipment on the engine. I wonder what's inside. I bet a hotter came at least. The reversed Budd wheels seem odd to me. I wonder if the ran the inners originally
Old 07-31-2021, 07:49 AM   #3
Jiggers72-GMC
Jiggers72-GMC's Avatar
Very nice
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 07-31-2021, 09:06 AM   #4
Dieselwrencher
I was wondering if it had a cab chassis rear end in it since it had those wheels but IDK. A pic of the spid would be cool to see what it says. Probably nothing to do with the fire truck side of it I'm guessing.
Ryan
Old 07-31-2021, 10:45 AM   #5
yuccales
yuccales's Avatar
Were they still using the HO diff in 72, or am I seeing things. I do like this truck!
yuccales is offline   Reply With Quote
Old 07-31-2021, 11:36 AM   #6
Dieselwrencher
Yes sir they were. The HO52 was the only rear axle offered on the K20s as far as I know.
Ryan
Old 07-31-2021, 11:44 AM   #7
57taskforce
All about them K’s
57taskforce's Avatar
True; most Chevy’s got the 52, and GMC’s used the Dana 60.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 07-31-2021, 12:48 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for posting it. Would be neat to see the SPID. Interesting it has optional lower trim, chrome front bumper, and hub caps but not factory cab marker lamps.
Old 07-31-2021, 01:01 PM   #9
57taskforce
All about them K’s
I found the cargo light and automatic interesting as well. I’ve never paid much attention but I would think most of the custom trim trucks would have been more likely to have come with 3 or 4 speeds. Just my own thinking not really something I’ve observed, obviously you could order them however you wanted.
Tyler
Old 07-31-2021, 01:18 PM   #10
Dieselwrencher
Good to know. I've never had a GMC 67-72 K20 and didn't know they used D60s in them. That's pretty odd.
Ryan
Old 07-31-2021, 01:19 PM   #11
Dieselwrencher
I found the bolt through the center of the hub cap strange too.
Ryan
Old 07-31-2021, 10:20 PM   #12
68Gold/white
Studded snow tires, Wow!
68Gold/white is offline   Reply With Quote
Old 07-31-2021, 10:32 PM   #13
Killer Bee
Killer Bee's Avatar
woefully inadequate srw 3/4t chassis for a fire/brush rig that size..
reminds me of a similar rig that responded to a brush fire on the farm - buried to the frame before getting anywhere near the fire
cool hobby truck possibly tho
Old 08-01-2021, 12:16 AM   #14
lil hoodlum
lil hoodlum's Avatar
I find it interesting that it has an AM radio and the cigar lighter delete option. C'mon man, how else are firefighters suppose to light their cigarette's?
lil hoodlum is offline   Reply With Quote
Old 08-01-2021, 12:25 AM   #15
57taskforce
All about them K’s
I was trying to figure that out myself, I can’t come up with any logical explanation.
Tyler
Old 08-01-2021, 08:21 AM   #16
va72longhorn
va72longhorn's Avatar
I wonder if they had some type of backup bell bolted to the rear caps, similar to what you’d find on construction equipment before the electric beepers came out?
va72longhorn is offline   Reply With Quote
Old 08-01-2021, 03:48 PM   #17
factorystock
factorystock's Avatar
Wow, that is bad form! Mounting the wheel on backwards. IMO, they should have installed wide base 9.75x16.5 wheels on 12-16.5 tires, next best alternative to duals.
factorystock is offline   Reply With Quote
Old 08-01-2021, 05:26 PM   #18
I see now the rear wheels aren't Budds, they are standard wheels reversed. The truck probably had an Arrowcraft DRW conversion on it. The kit used four standard wheels, both facing normally, with a barrel spacer that bolted up to inner lug nuts with outer wheel bolted to it. The center bolt holds the hub cap on and is threaded into the axle flange
Old 08-01-2021, 06:10 PM   #19
72c20customcamper
72c20customcamper's Avatar
I have two sets . Both the 72 and 68 had them I kept them cause I planned on using them on my 07 Dodge just to plow the driveway but I bought chains
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-02-2021, 02:14 AM   #20
68Gold/white
That’s the only way the hubcap could be retained, there’s no nubs on the inside of a wheel to retain it.....
Old 08-04-2021, 07:23 AM   #21
Dieselwrencher
Yeah, a bad idea on top of another bad idea.
Ryan
Old 08-06-2021, 08:59 AM   #22
va72longhorn
Tim, how you pick up on that stuff is beyond me, buddy.
Old 08-06-2021, 05:35 PM   #23
Maybe I do but I miss more
Back to the HO52 used in '72s where it was already answered "yes", I just want to add that '72 was the last year. So the 67-72s were the last trucks to run them. The 14-bolt came out in '73 and ran till... I dunno. A really long time, too . Without checking, I believe the HO rears began use in '38 or so. Maybe early '40s
Old 08-07-2021, 07:30 PM   #24
57taskforce
All about them K’s
The full floater 10.5” 14 bolt as we know it is still made by AAM for use in GM 3/4 ton trucks with out the Duramax. My ‘18 Sierra 2500 has one. The biggest change is the addition of disk brakes. Not to be confused with the 11.5” 14 bolt used in the duramax and ram trucks which is similar but not the same.
Tyler
Old 08-07-2021, 08:41 PM   #25
LockDoc
The Older Generation
LockDoc's Avatar
The 11.5” 14 bolt Rear Axle was also used in the trucks with the 8.1L gas engine & Allison 1000 5 speed automatic Transmission (RPO - GT5 - G80). The 2003 Chevy 2500 that I just dismantled had one in it. (4.10 Posi.)
LockDoc
Leon
