06-10-2021, 06:40 PM | #376 |
Re: '72 Cheyenne K10
I finally finished wiring the KC flood light and rear cargo light switches. I made the bracket from an old bent grill support (and smashed two fingers in the process).
06-11-2021, 07:34 AM | #377 |
Proprietor of Dale's Corner
Looks pretty good, I hope your fingers are ok
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
06-29-2021, 03:13 PM | #378 | |
landarts
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
06-30-2021, 10:59 AM | #379 | |
06-30-2021, 11:03 AM | #380 | |
landarts
07-25-2021, 11:31 PM | #381 |
My truck living the easy life hauling my kayak to the river.
07-26-2021, 08:46 AM | #382 |
That sounds like fun. Especially with the heat we've been having. How's the smoke in your neck of the woods?
07-26-2021, 10:32 PM | #383 |
Smoke is not bad in the valley, noticeable up in the foothills. I hope they can stop the fire soon.
07-27-2021, 06:08 AM | #384 |
I hope they get them stopped soon too!
08-01-2021, 02:01 PM | #385 |
After my kayak trip last weekend I noticed a pretty big puddle of transmission fluid under my radiator, but I couldn't find the leak until today. Every time I looked it was clean and dry around the fittings. Today I ran the engine and shifted between all the gears in the driveway and it was clearly leaking from the upper transmission line.
I tightened it as much as I could, cleaned it up, and topped off the transmission fluid. I'll check again next time I go for a highway drive to see if the leak is fixed. Fingers crossed! |
08-01-2021, 06:49 PM | #386 |
I had a similar leak but on the transmission end. FYI, it only leaks while driving. So, it will leave a very small puddle when you park it, but will be a continuous drip while driving.
Hopefully it was just loose. In my case it had been previously overtightened and the line was ruined. I bought a new line and replaced it and all is good now. |
08-02-2021, 07:39 AM | #387 |
I hope you solved it...
11-19-2021, 03:31 AM | #388 |
I took my truck on its first real four-wheelin adventure to the High Lakes today. It died on me a few times on steep technical section, but it did fine with the transfer case in low. A boulder in the middle of the trail customized my passenger side rocker a little bit. Fun day. I'll be going back for more.
11-19-2021, 08:35 AM | #389 |
Where's the High Lakes? I can see a burn scar in the pic's. Dang boulders, they like sneaking up and biting...
11-19-2021, 10:56 AM | #390 |
11-19-2021, 01:50 PM | #391 | |
11-20-2021, 07:39 AM | #392 | |
12-01-2021, 03:17 PM | #393 |
Sometimes it's fun to be a graphic designer / printer
12-02-2021, 06:25 AM | #394 | |
12-06-2021, 12:09 AM | #395 |
Helped out a friend today picking up a slant six for his 65 Dart.
12-06-2021, 09:57 AM | #396 |
It looks like you had nice weather. We were in the fog most of the day. Your truck doing what it was built for.
12-12-2021, 02:03 PM | #397 |
I just picked up this AstroVan Hydroboost for $50. Just have to figure out how to get it installed into my truck. Looks like Captainfab from this site makes an adapter bracket.
12-13-2021, 05:33 AM | #398 | |
71 C10 72 K20 72 K10 Super Kirk |
12-13-2021, 10:21 AM | #399 |
That will be nice. I hear good things about hydro boost.. Keep us updated on the progress, I'm curious how it comes together.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul Last edited by Ol Blue K20; 12-13-2021 at 11:01 AM. Reason: auto correct mistake |
12-26-2021, 08:49 PM | #400 |
Took my truck on a ~450 mile round trip to San Jose this weekend. No problems, but 63mph in the slow lane the whole trip was a first for me. Santa got me a used canoe and patio set.
Tags |
ochre |
