06-29-2021, 10:12 AM | #101 |
Re: Soap on a Rope
Man... Very nice build
07-02-2021, 05:43 PM | #102 | |
Re: Soap on a Rope
I didn't get itchy at all. I'm using black thermal wrap on the tail section mainly because I already have two rolls on the shelf. So well see if there is a difference? |
07-02-2021, 05:46 PM | #103 |
Re: Soap on a Rope
07-02-2021, 05:55 PM | #104 |
Re: Soap on a Rope
Just a before shot, before I put the cab back on to do some wiring. The slow painful process of wiring is not my cup of tea. but I want to get it prewired now so there's no hiccups later.
07-02-2021, 06:02 PM | #105 |
Re: Soap on a Rope
Just found this one. Very nicely done!
07-11-2021, 12:57 PM | #106 |
Re: Soap on a Rope
07-11-2021, 01:17 PM | #107 |
Re: Soap on a Rope
I've been busy this last week! I spent the week getting the truck together to prewire before I attempt the last bit of metal work and body work. Then I spent Friday and Saturday At the SETN show where I was picked to be a judge. So.... my back is killing me now ! But there is work to be done so I'm at the shop trying to find a suitable job.
Also, I'm looking for an original painted front bumper, if anyone knows somebody? Last edited by lunatic1968; 07-11-2021 at 02:17 PM. |
07-11-2021, 01:26 PM | #108 |
Re: Soap on a Rope
Couple of pics...
07-11-2021, 08:10 PM | #109 |
Re: Soap on a Rope
Badass!!
1979 C30 Single cab Dually, 454, th400, dropped on 19's. |
07-31-2021, 12:08 PM | #110 |
Re: Soap on a Rope
07-31-2021, 12:27 PM | #111 |
BlahBlahBlah
Re: Soap on a Rope
I like how you spaced the tailgate letters out a bit. Another cool look with a lot of other really neat tricks youve done with this truck.
07-31-2021, 01:22 PM | #112 |
Re: Soap on a Rope
Thanks man. The tailgate is my favorite part so far..
07-31-2021, 01:42 PM | #113 |
Re: Soap on a Rope
Well, I have been busy...but I seem to be all over the place , as I run into issues I stop and work on something else while I think about the other issues. The truck is nearly together again. I started getting the wiring done, with the help of friends. A couple years ago I decided I wanted cannon plugs for my wiring to go through the firewall. I thought it would be cool to disconnect a couple cannon plugs and be able to remove/install the body quickly. Half of it is done but now I have to pin the firewall side. I have to say right now, I don't like my placement of the plugs. and the time that it has taken to do this mod has taken a long time, too long. I sometimes think about starting over. It was a risky move and a lot of thought went into it. First item was cutting my brand new engine and trans harness in half. Another warranty voided. I am pre-wiring the whole truck with connectors, everything will have connectors for ease of installation later and I will be able to remove the harness and wrap it head to toe.
Anyways I am tired of wiring and I keep adding things such as power windows, push button start, RFID security, auto start, and power door locks. I need time to think what else I want to add before finalizing the wiring. So I have moved to the front of the truck into the engine compartment. Attempting to make my radiator support and wheel wells. They will be pretty simple as I don't have an English wheel or bead roller,but they are definitely on my list of tools I need. but I think I can whip up something with out them. What I do have is dimple dies so this one trick pony is going to dimple die the hell out of whatever I make under the hood. Ive gotten pretty far but its not coming out symmetrical as I would like because of the intake tube on the drivers side and the radiator cap ..... idk what I'm going to do for access to it. Ive seen beautiful metalwork done on engine covers but alot of them cover the access to serviceability to the radiator cap or oil fill without taking off covers to get to them meaning removing bolts to get to something. I am hoping I can make something serviceable. Any ideas? It's just mocked up with tape and clecos right now but you can see the direction Im going. |
07-31-2021, 01:52 PM | #114 |
Re: Soap on a Rope
I forgot to mention the wheel wells will be removable with quarter turn fasteners around the perimeter. Once I figure out how to do it, ha. Its a work in progress.
07-31-2021, 02:27 PM | #115 | |
Re: Soap on a Rope
07-31-2021, 03:37 PM | #116 | |
Re: Soap on a Rope
08-15-2021, 02:01 PM | #117 |
Re: Soap on a Rope
Couple of pics of what I been working on.
08-15-2021, 02:06 PM | #118 |
Re: Soap on a Rope
All is mocked up with tape, nothing is done, just playing around with different ideas for the engine cover/throttle cable cover. Last one is a piece of oak that matches the center console and bed floor.
I'm trying to think of something to cover the fuel rail and injector wiring . Stay tuned....? |
08-15-2021, 02:16 PM | #119 |
Re: Soap on a Rope
And one more without tape
08-15-2021, 04:57 PM | #120 |
Re: Soap on a Rope
I'll admit I'm not a fan over the engine covers but I like what you've done so far.
As far as covering the fuel rails/inj's, add to whats there or make some that attach to the coils (if they're not relocated) or to the v.covers to avoid the center piece from getting to big. I hope that makes sense.
08-16-2021, 09:58 AM | #121 | |
Re: Soap on a Rope
08-16-2021, 10:52 AM | #122 |
Re: Soap on a Rope
I'm into the engine cover, gives it some height. Also makes it one of a kind. Very nice work!
08-16-2021, 02:40 PM | #123 |
Re: Soap on a Rope
Great Build so far! Thanks for sharing!
08-18-2021, 04:16 PM | #124 |
Re: Soap on a Rope
Thanks, I've spent the last two days just staring at it trying to figure out how to fasten it. My plans were to use magnets for easy removal and that is still the plan, just having a hard time determining how and where. So I'll leave it alone for now and find something else to work on in hopes that it will come to me. I did make two pieces to hide the wiring and the fuel rail, don't know if I'll use them or not. But it looks pretty good. I'll post a pic in a few.
08-18-2021, 04:16 PM | #125 |
Re: Soap on a Rope
