Soft topper installed/review
I ordered the Soft topper a couple of months ago and it arrived on Saturday July 3rd.
I had to open a couple (and add a couple) of holes on the bed rails. You probably don't have to do this but I wanted to use the single wall captive nuts so I didn't have to take off the inner side panels to install (or if I want or need to remove). I struggled to get the brackets installed on the rubber door and top seal. The holes were a bit off and the bracket was hitting the plastic door cap when closed. I tried a bunch of different ways and ended up cutting some of the bracket and enlarging the holes a little. Here is how it looks installed. I will post a picture with the door closed to show the interference. ![]() Here is how it looks around a closed window. I can open and close the door with the widow up. It actually fits better than the picture but I didn't have the rear straps pulled tight and it is sagging a bit. ![]() A couple of the top up. You can take the wrinkles out by tightening the rear straps and the middle straps. I was putting the Blazer away so I didn't care at the moment. ![]() ![]() And with the sides rolled up. ![]() ![]()
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Re: Soft topper installed/review
Nice
Very nice pics and write-up.
You could roll up some tan terrycloth towels with the plastic windows as well, to help protect them from abrasion, UV etc. and blend it in visually. |
I used to do that with some larger microfiber towels on previous tops that I’ve had. In the end it turns out to be more of a pain to do every time then it is to just let the window scratch. That’s just my opinion.
Your rails are mounted too far forward. That rubber block must have a 1/8-1/4 gap so it doesnt rub against the top fabric. If you leave it like that, you will eventually wear through the fabric. This should solve some of your wrinkling issue too. I would also check the aluminum bow right behind the glass. moving the rails back a bit will help, but you may have to adjust the bow also so the top edge of the glass doesn't deform the fabric so much.
Another thing caught my eye. Something just doesn't look right!
I think you need to adjust the bows. I've enclosed a pic of my softopper for comparison. |
#7 | |
I mentioned under my second picture that I didn’t have all the straps adjusted so it was sagging a bit in the picture.
The previous owner of my Blazer had modified a soft top as a half cab cover. I think it is a BES-TOP... not sure, I haven't used it in a long while. He is a pretty crafty guy and he'd trimmed the inner roof liner out of a '67-'72 to use under the soft top just behind the windshield. It makes the top contour much
smoother. The panel isn't very heavy & has trim around the edge so it isn't sharp. I can take a picture of the panel next time I'm in the shop. The half top seals pretty well and doesn't flap.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
#11 | |
Here's a couple of pictures of the metal interior roof panel. I don't have any pictures of the inside w/the half top installed. There's some more hardware for it in the loft in the shop. The complete full length top could also be attached w/a big zipper. As I said it's been a long time since I used the top. Luckily the weather is pretty predictable here & it's been a while since I got caught topless in the rain.
Looks great! Eagerly awaiting mine to show up, but they are a bit backordered. Did you screw the aluminum header bar directly to your windshield frame? For some reason I'm hesitant to do this even though I'll probably run with the top on (rolled up like you pictured) 95% of the time.
My LS Swap: http://67-72chevytrucks.com/vboard/s...d.php?t=718573 |
#14 | |
![]() Join Date: Jan 2001
The instructions say to use a 9/64 bit. The screws are pretty soft and break easily. I think if I were to do it over again I would buy better screws.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#15 | |
#16 |
The new ones don't have snaps at the front. There is a hard plastic lip on the front of the canvas that goes under the edge of the aluminum. I understand it's similar to how Jeep soft tops operate.
#17 |
I didn't realize they changed the design. Probably for the better.
#18 | |
![]() Does that not seem more like a defective sh!tty product with even sh!ttier customer support that you need to modify a brand new $1200 top by drilling holes in your bedrails that are said to line up appropriately?? Below is a pic of their brand new rail that I moved outward an inch just to show how the holes don't line up with nearly any mounting location supplied.
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint) 1969 GMC C10 Pickup SWB Stepside (heart transplant) 1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts) 1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts) |
#19 |
![]() Join Date: Mar 2009
I’m not sure but aren’t the top mounting holes different between single and double wall? I’m saying this because I have a softopper that I originally purchased for my 70 blazer that I have since switched to a 72 blazer. The holes in the rail lined up on the 70 but not on the 72. I drilled the softopper rail to match the mounting holes that existed on the 72 blazer.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
#20 | |
![]() Join Date: May 2011
#21 | |
The Softopper instructions state: **The bedrails have extra holes to accommodate double and single walled vehicles. We have provided extra nuts and washers just in case your vehicle does not have the threaded parts under the side rails** Which after reading that, it seems like you either have a single walled hard top whose holes have nuts under the bedsides, which the frame was made to fit without alteration. Or they give you nuts and bolts to drill new holes to attach the frame on your own. Does that sound more like it?
#22 | |
#23 |
The rails will fit either. They have slotted holes, and you put the bolts in where you need them. There is foam insulation that goes under the rail. I just used a Phillips screwdriver to punch a hole through the foam in the location I needed it. If you have a double wall top, you would do the same. The only difference is that you would need to thread a nut on the bottom.
#24 |
All of the mounting holes lined up on the 70 and about half lined up on the 72. I just drilled the softopper rail for the rest. I will have to check but my softopper rails didn’t have that many holes to line up with both types of bedsides.
#25 |
I didn't have to do any drilling on my 72.
