09-06-2021, 10:49 AM | #2076 |
Re: A '54 named Busty
I must say The Filling Station ships right quick
09-06-2021, 09:05 PM | #2077 |
Literally Nobody:
Me: so you wanna know what's in the poster tube, well here you is: these long metal sticks turned out to be the wrong parts, they are for the bottom of the glass instead of being the vertical retianers Last edited by Gregski; 09-12-2021 at 10:06 AM. |
09-06-2021, 09:23 PM | #2078 |
so got one triangle out, now what?
09-06-2021, 09:35 PM | #2079 |
Don't drill out the pivot. Take the rubber out and drill out the rivets under it.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
09-07-2021, 01:10 PM | #2080 |
so looks like once again a Weekend Project is going to take a month, ha ha
09-07-2021, 01:13 PM | #2081 |
this vent window is kicking my butt, but it needed doing as the rubber has perrished and is rock hard
unfortunately to get the L shaped rubber piece in we need to drill out this rivet and remove the glass Last edited by Gregski; 09-12-2021 at 10:07 AM. |
09-07-2021, 02:24 PM | #2082 |
I've done those, quite the PITA!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
09-07-2021, 02:32 PM | #2083 |
they are a huge PITA, that is why I suggest cutting the seal on the inside, to avoid separating the vent window frame. (that's my 2 cents)
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
09-07-2021, 02:54 PM | #2084 |
Oh I hear ya, but I couldn't get the rest of the hard as a rock rubber weather strip out without removing the vent window and then drilling 37 holes in the hard black rubber to chip it out 1mm at a time
09-07-2021, 04:35 PM | #2085 |
so it appears like WE ordered some wrong parts, WE ordered the rail for the bottom of the glass instead of the vertical ones that were rotted out, so whilst we wait for the new parts to show up we decided to stay busy
so got the cab weatherstrip in on the driver side, and am very pleased with it |
09-07-2021, 04:38 PM | #2086 |
I also tried the left over door panel trim on this lip around the windshield and really like how it turned out so I plan on running it all the way around the perimeter
09-07-2021, 05:15 PM | #2087 |
Cab weather-strip looks good. Does that go in the little channel that runs on the inside of the opening?
09-07-2021, 06:12 PM | #2088 |
thanks, yes sir, exactly, I used a little silicone lubricant spray and started at the B pillar and ran one direction straight down, then started in the other direction above the door and down the A pilar, they give you a strip that is about 8" too long just in case
09-08-2021, 08:35 PM | #2089 |
so more black licorice showed up
09-08-2021, 08:36 PM | #2090 |
so we threw it on there cab, like so...
just like the one that runs above the windshield it has two pinch welds on either side (where the vertical line is) so you can back cut the molding a 1/2 inch or so to get it on there flush or just have a tiny bump there on the front one above the windshield I just so happened to have a perfect length strip to fit in between those pinch welds so I just ran three pieces, a middle one of about 2 feet and then the ones on either side above the doors Last edited by Gregski; 09-12-2021 at 10:11 AM. |
09-08-2021, 08:38 PM | #2091 |
... and like such
09-08-2021, 10:17 PM | #2092 |
ok, looks like you dont have the metal strips that hold the center of the headliner to the top of the cab or the strip that holds the rear of the headliner to the back of the cab.
In some ways I like your idea better. Just hope the headliner doesnt fall down when you are driving.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
09-08-2021, 10:48 PM | #2093 | |
09-09-2021, 09:19 AM | #2094 |
sorry - didnt see that you had painted the inside of the cab roof. Looked like maybe a pvc headliner
09-09-2021, 09:54 AM | #2095 |
09-09-2021, 10:29 AM | #2096 |
so our Mission For Today (MFT) should we choose to accept it, is to applicate and stickanate this door weather stripping to the doors of our '54
Item # K-124 1949-55 TRUCK DOOR SEAL KIT-THICKER 11/16" this is the thicker one they also offer it a thinner 1/2" CAUTION FROM THE FUTURE ME: this proved to be an Epic Failure and a waste of money. I could not get the doors to shut with this weather strip on no matter what I did. I even tried only running it above the windows and still had to push on the doors with both hands while standing outside the vehicle to finally get them to latch, not the way you wanna haul your girls around. and once again, Dr. J will be our tour guide 1947-55 1st series Chevy Pickup Door Weatherstrip Installation Last edited by Gregski; 09-17-2021 at 12:31 AM. |
09-09-2021, 11:59 AM | #2097 |
If your not careful, you'll have a complete truck soon....
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
09-09-2021, 12:11 PM | #2098 |
09-09-2021, 12:17 PM | #2099 |
I need to put my door rubbers on as well but it seems like the only way to do it correctly is to pull the doors off. I'm a little hesitant to do that but I think people have done it with the doors on. Only problem with doing that is getting the door edge clean enough. Looking forward to your progress and how you did it with either doors on/off.
09-09-2021, 12:23 PM | #2100 | |
1. you can't clean the glue and grime from the previous weather strip properly behind the hinges, with the doors off you can use a wire wheel on an angle grinder and shoot some spray paint to cover the bare metal if any 2. you can't get your fingers in there to squeeze it to the door in order to get it to stick properly taking off the door is no big deal, here is a top tip for doing it the first time, put a towel on a floor jack and gently support the door from the bottom, they won't fall off put they like to sag a tad more importantly the door may not want to slide forward off the hinges because the door inner sheet metal got pressed in ever so slightly around them three holes at each hinge, you may need to pry it out with a flat screw driver a little bit and finally maybe shoot some WD-40 or PBBlaster inside the doors at the hinges the night before Last edited by Gregski; 09-12-2021 at 10:14 AM. |
