Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-09-2021, 02:27 PM   #1
BBPanel
Paint Wand for Inaccesible Areas
There are some areas of my Panel I can't get to but would like to shoot some POR15 in there - I know there is some surface rust present. Is there a wand attachment for a spray gun or maybe something used with a pressure pot? Probably want something to shoot 360 deg.
BBPanel is offline   Reply With Quote
Old 09-09-2021, 02:52 PM   #2
BBPanel
Re: Paint Wand for Inaccesible Areas
Well, maybe I answered my own question - anyone use one of these? Neither have very good reviews - perhaps the viscosity of the undercoating is why they have such poor results?
https://www.amazon.com/TCP-Global-Pr...213174&sr=8-37
https://www.amazon.com/Eastwood-Repl...dDbGljaz10cnVl
Old 09-09-2021, 03:19 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
Cavity Wax
https://www.amazon.com/KBS-Coatings-...84244139&psc=1
Internal frame coating
https://www.amazon.com/Eastwood-Inte...0MROX1J4&psc=1
Old 09-09-2021, 05:52 PM   #4
mongocanfly
mongocanfly's Avatar
What Warren said x2
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-12-2021, 09:01 AM   #5
ItWillBeSlow
ItWillBeSlow's Avatar
Ive used a couple cans of the eastwood internal frame coating. It works well, the metal tip at the end of the wand does a decent job of spreading out the spray. Make sure you clean it after you use it or it will be one and done.
Ive taped the hose to a coat hanger to make it easier to use in hard to reach areas.
1972 C20
ItWillBeSlow is offline   Reply With Quote
Old 09-12-2021, 09:21 AM   #6
BBPanel
Originally Posted by ItWillBeSlow View Post
Ive used a couple cans of the eastwood internal frame coating......
Yes, I ordered some of the Eastwood - should work well for my app if it does what it says it'll do.
Old 09-12-2021, 10:45 AM   #7
lupo
You can spray coatings and rust removers in the back side of panels with an engine cleaning gun from Harbor Freight . They cost $9 and will blow paint and rust remover 3 feet . I've used them for years. If you decide to go with POR 15 or any other moisture cured uses silver not the black or clear. Silver formulation is your true airtight seal use multiple coats about 3 hours apart.
lupo is offline   Reply With Quote
Old 09-14-2021, 11:41 AM   #8
_Ogre
_Ogre's Avatar
glad to see you used the paint and not wax. my son's 68 elco had wax undercoating. any time we welded on it, the wax would catch on fire. out of fear of a run away fire, i chained my dodge 4x4 locked in 4 low to it when welding. the elco was on stands with all wheels removed, i figured it would be easier to fix the barn wall, than to watch the barn burn to the ground. never did need to use my fire exit strategy, but we did have a few times where the hose came in handy.
never use cavity wax
shop air compressor timer
Old 09-14-2021, 11:46 AM   #9
BBPanel
Originally Posted by _Ogre View Post
...never use cavity wax
Yeah, not sure why I would ever use it either.
Old 09-14-2021, 08:45 PM   #10
richards72chevy
richards72chevy's Avatar
The cavity wax would probably work better.The por15 requires a lot of prep.How will you get in there and prep it?
richards72chevy is offline   Reply With Quote
Old 09-15-2021, 10:47 AM   #11
eager_adventurer
I need that too!
eager_adventurer is offline   Reply With Quote
